10-20-2010, 11:33pm | #1 | ||||||
Gameroom Barn Bucks: $992
Lifter going?
Recently changed my oil and had a sound that i never heard pop up afterwards. Im thinking i have a lifter going bad sounds exactly like this. It does not go away after the car warms up so im pretty sure its not piston slap as the video is titled. Any others heard anything like this? Just want some other opinions before i either start tearing it down or taking it someplace to get it tore down.
http://s58.photobucket.com/albums/g270/BillD64/Seat%20Belt%20Pics/?action=view¤t=C5Z06PistonSlap.mp4 ( i borrowed the link from CF forums)
01 z06 |
10-21-2010, 3:12pm | #2 | ||||||
Gameroom Barn Bucks: $100431
Did it happen right after the oil change or has it been a few miles?
50th Anniv. Quick Silver Z06 OBX LT's, Haltech Stinger P1SC waiting to go on |
10-21-2010, 6:07pm | #3 | ||||||
pretty much right after the oil change.. if was right before that week long storm we had a couple weeks back i changed the oil and it pretty much sat for a week and then i noticed the noise.
01 z06 |
10-21-2010, 10:48pm | #4 | ||||||
I missed the storm. I am in Iraq right now. The barn is one of the only public sites I can visit in my down time.
What oil did you put in it? Did you notice anything wierd in the used oil? What is the current oil level? Its odd that it would show up almost over night with nothing more then an oil change.
10-21-2010, 11:37pm | #5 | |||||||
01 z06 |
10-22-2010, 4:19pm | #6 | ||||||
Gameroom Barn Bucks: $2288
Sure "sounds" like lifter click. Could just be dirty with varnish. get it to operating temp and hold it at 4-5,000 for a few seconds [ or higher] and see if click changes
10-22-2010, 7:41pm | #7 | ||||||
If you start thinking build up it might not hurt to seafoam the car.
10-23-2010, 5:28pm | #8 | ||||||
Did that and took it on a spirited drive still there, Still pulls like a raped ape and oil pressure is good. guess its time to take it in to get a tear down. Thanks for your input tho
01 z06 |
10-23-2010, 5:29pm | #9 | ||||||
seafoam in the oil or through the intake? did the oil, will try through the intake tomorrow.
01 z06 |
10-24-2010, 12:09am | #10 | ||||||
I meant the oil. Before you start tearing anything apart you need to find out where the noise is coming from. I can not see the video but a tick can come from dozens of things. First figure out where EXACTLY the sound is coming from. Then go over the side/area for anything loose missing or making contact with something it shouldn't. If you can pin point it is under a valve cover only pop that cover. If its to hard to tell get a mech stethescope to assist you.
Check the bolts on the headers, vaccuum lines, everything. You dont want to get into a huge shop bill or parts bill until you are positive it is needed.
10-24-2010, 7:20am | #11 | |||||||
01 z06 |
10-24-2010, 4:48pm | #12 | ||||||
So run it with the cover off. Just lay down some thing to keep the oil from making a mess. A dead lifter will be obvious there will be little to no oil coming out of push rod at the rocker.
10-24-2010, 4:57pm | #13 | ||||||
ill give that a try and see what happens
01 z06 |
10-31-2010, 5:31pm | #14 | ||||||
got the driver side cover off and started it little to no oil came out of the exhaust valve pushrod on number 3 cylinder. guess its time to take it apart. Going to do some upgrades while its apart, upgrading to roller rockers worth it? Other upgrades im going to do are long tubes catted xpipe, 1/4 ceramic coated tunnel plate, rsd c6 snap shifter, new wires and plugs, halltech stinger intake. Thinking about some heads but not sure even tho now would be a good time to upgrade since im pulling the heads off.
01 z06 |
10-31-2010, 7:59pm | #15 | ||||||
Well crap... sounds like you've pinpointed the issue. I had Yella Terra ultralights on it at one point. They're nice pieces, but many tuners swear by the stockers or the stockers with a trunion upgrade because they're so light.
As for lifters I think the popular replacement are OEM LS7 units. No need to go nuts with anyhting aftermerekt. For a bit the popular unit was Cadillac racing lifters, but not sure if those are still available. |
10-31-2010, 8:07pm | #16 | |||||||
01 z06 |
10-31-2010, 8:55pm | #17 | ||||||
The pushrods are hardened ones that came with the cam kit... no need to waste your mone on new ones. If you want to check them take them out and roll them on a glass table to make sure they don't wobble any.
10-31-2010, 9:11pm | #18 | ||||||
ah cool didnt know that i'll def check them out and if all is good reuse them
01 z06 |
