Old 11-16-2009, 9:38pm   #1
Eagleeye
Points: 10,779, Level: 71
Eagleeye's Avatar
Gameroom Barn Bucks: $2288
Default Popping static in radio after plug change !
40k on the Z and i was bored so I decided to change the plugs...NGK TR55's set at .055 and got 'er done in about two 45min. sessions to include new MSD wires. I new about #7 and removed vac. hose and got a swival and all that. All went well untill I fired her up and had a real crappy idle...forgot to reinstall the da-- brake vac. hose! Corrected the dumb ass and all was smooth until I drove to work today. Runs GREAT but have static popping as if one wire arcing...can't find it ! Pulled the coil end off #1 to start there and the spark was so strong it was jumping like three inches to ground !!! Getting the boots to snap on the plugs was a pain with the heat shields and wire coils too so I guess one isn't on tight ??? Strange that I turned the radio up so I could hear the popping under the hood and the sound would change [loudness] by just touching any coil pack with my gloved hand...weird
Old 11-17-2009, 11:22am   #2
03SlowZ06
Points: 3,068, Level: 36
03SlowZ06's Avatar
Gameroom Barn Bucks: $100431
Sounds like you have a ground issue. Make sure that you did not break any of the ground wires.
50th Anniv. Quick Silver Z06
OBX LT's, Haltech Stinger
P1SC waiting to go on
Old 11-17-2009, 7:23pm   #3
Crowvet
Points: 8,497, Level: 64
Crowvet's Avatar
Gameroom Barn Bucks: $2194
I would suspect that either you have a wire that isnt seated to the plug (snapped on tight) or a plug insulator may have gotten cracked during installation.
Crowvet is offline   Reply With Quote
Old 11-18-2009, 5:03pm   #4
Eagleeye
Eagleeye's Avatar
I'm sure it is one of the two...but which plug ? My next approach was to pull wires - one at a time - at the coils and listen to the radio for the pop to stop. That was when I realized how far the spark could jump...so now I wil try to improvise an insulator to prevent the spark from jumping from coil pack to ground !
Old 11-18-2009, 6:40pm   #5
Crowvet
Crowvet's Avatar
The best way to isolate the miss is with a scan tool, You can watch the misfire counter to see witch one it is. Sometimes you can run the car in a darkened enviroment and mist water on the boots with a spray bottle and cause the suspect cylinder to arc.
Old 11-18-2009, 8:56pm   #6
Eagleeye
Eagleeye's Avatar
Yup ! Now you mention it...used to do the night/water bit ! Are you old enough to remember that all wires had a "glow" around them in the dark ?
Old 11-19-2009, 11:21am   #7
Crowvet
Crowvet's Avatar
I,m older than dirt but not quite as wise.
