08-13-2023, 6:47pm | #1 | ||||||
Why I do my own work
A new client had me look at her car, just purchased off a lot "as is". 2012 Audi Q5 with 125k miles. About a week after driving it off the lot, she smelled burning oil.
She took it to a dealer who claimed that it was the camshaft cover and quoted her $9000. I didn't see the quote but I imagine it contained other services to bring up-to-date with all that mileage. I looked at it, figured it to be the PCV assembly, leaking onto the camshaft cover then onto the exhaust manifold. About $100 for OEM at Rock Auto. I replaced it today and found stripped threads for the lowest bolt holding the assembly, so I drilled and tapped to the next size up. The red circle in the picture. I also degreased the engine as best as I could. After test driving, it appears that the issue is no more. |
08-13-2023, 6:58pm | #2 | ||||||
Oh yay, another look at me Yaddy thread.
The Following 7 Users Say Thank You to MadInNc For This Useful Post: |
08-13-2023, 7:01pm | #3 | ||||||
I found several other issues caused by the previous owner or his mechanics.
13 of 15 missing bolts, speed nuts or both for the aero cover under the engine. I gave the new owner the option of ordering a new hardware kit, or tossing the cover altogether, making it easier to change the oil. I also replaced the belt and tensioner, and found a boogered up drive for the bolt holding the idler in place. I know it's a T40 since that's what the new one (OEM part) has. Also the tensioner pulley- same T40. I tried everything to remove it with the limited access. I'll need to remove the radiator and cooling fans to get access to cut a slot in the screw head. My recommendation- get that done when the radiator is flushed. 3 of 4 broken connectors for the coils. Each connector is about $40 plus time. Instead I made it all neat and sturdy with zip ties- identifying the modification by marking with a gold sharpie. |
08-13-2023, 7:02pm | #4 | ||||||
08-13-2023, 7:05pm | #5 | ||||||
08-13-2023, 7:08pm | #6 | ||||||
This one's a little mystery. The bottom end of coil 1 was dented (here it is after I repaired it with needle nose pliers). The top of plug#2 had an extra insulator on it. Good news is, non OEM plugs, so at least they were changed at least once before.
08-13-2023, 7:10pm | #7 | ||||||
08-13-2023, 7:17pm | #8 | ||||||
Gameroom Barn Bucks: $1027436
WTF.... No Duck Tape!!
08-13-2023, 7:41pm | #9 | ||||||
Barn Stall Owner #14/32
Gameroom Barn Bucks: $4810
The Following 8 Users Say Thank You to Vandelay Industries For This Useful Post: |
08-13-2023, 7:45pm | #10 | |||||||
08-13-2023, 7:47pm | #11 | |||||||
Barn Stall Owner #113
Gameroom Barn Bucks: $306898
The Following 9 Users Say Thank You to The_Dude For This Useful Post: |
08-13-2023, 7:51pm | #12 | ||||||
The Following 4 Users Say Thank You to Vandelay Industries For This Useful Post: |
08-13-2023, 7:54pm | #13 | ||||||
08-13-2023, 7:59pm | #14 | ||||||
08-13-2023, 8:04pm | #15 | ||||||
08-13-2023, 8:07pm | #16 | ||||||
08-13-2023, 8:16pm | #17 | |||||||
Are the people making the labels really that illiterate, or is it a purposeful play on words? If it's the latter, 3/4 of the country doesn't even know it. I wonder to this day. |
08-13-2023, 8:25pm | #18 | |||||||
SOME Real Barner
Gameroom Barn Bucks: $2034428
I rotated the air in the Vette tires. Upcoming thread will be detailed, and consist of a short Power Point Presentation. |
The Following 8 Users Say Thank You to Strats-N-Vettes For This Useful Post: |
08-13-2023, 9:07pm | #19 | ||||||
An 11 year old Audi with 125K mikes.
The Following 2 Users Say Thank You to LATB For This Useful Post: |
08-13-2023, 10:27pm | #20 | ||||||
In my reply "Duck I Says" I was referring to the movie Unforgiven when Gene Hackman (Little Bill) got sick of being corrected by Saul Rubinek (W.W Beauchamp) as to the Duke of Death.
