03-21-2023, 4:41pm | #21 | ||||||
[Gene] Back in the moldy daze, we had a plastic bottle and a hose run to the base of the old CAR-bib-orater to mix H-too-Oh into the cylinders and stretch the gazz mileage out.[/Gene]
03-21-2023, 4:53pm | #22 | |||||||
Barn Stall Owner #118
Gameroom Barn Bucks: $1002672
Well, as for me, been there done that with the oversized vehicles used as DD's. This is why my wife and I have Sonata Hybrids. Both are 2015's bought at the same time. We get 36mpg in town, yes I use the the car calculation but as a back up, filling up a 16 gal tank every 3 weeks tells me it's fairly accurate. Besides, the MPG on the stickers is set at sea level calculations. Drops dramatically as you increase in altitude |
The Following 2 Users Say Thank You to slewfoot For This Useful Post: |
03-21-2023, 10:18pm | #23 | ||||||
Gameroom Barn Bucks: $1524159
Gene lives in Florida right? Do they add ethanol to gas? When I had my 2000 Ford F150, I got 17-18 all the time. When they started to add ethanol to the gas (10%), my mpg dropped down to 14.
03-22-2023, 1:40am | #24 | ||||||
No mileage reported by the OP. The cats could be clogged. That would really affect mpg. I agree with some here, the Acadia (my sister had one) is a POS. Dump it.
03-22-2023, 6:03am | #25 | ||||||
Gameroom Barn Bucks: $3694
If they are clogged, you can generally see them glow pretty good at night while running.
Or if they are starting to clog/ internally broken, may be the issue. When breaking it can cause the engine to sense knock, as one of my cars did, and it killed fuel economy.. Ethanol is in all fuel, with the exception of the ethanol free of course. You need to look these stations up. FLorida has allot of them due to boating. My 4runner go 1 mpg better from Georgia state line to Charleston. I did four calculated runs within a couple months. My Corollla got 2 mpg better with ethanol free fuel. Use this link to find the stations near you. https://www.pure-gas.org/ |
03-22-2023, 6:20am | #26 | ||||||
Over 20 years ago, when playing with the vette and DPFI and MPG, it was said to buy gas with no ethanol, so I went to the BP station up the street, who SAID/ADVERTIZE they had REAL gas......so I tried several tanks of it.....
no cat, but closed loop on the FI......NO help on MPG......alky fuel same as gasoline......go figger...... |
03-22-2023, 6:23am | #27 | ||||||
With no ethanol, you can retune the engine to take advantage of it.. Air Fuel Ratio is not 14.7 its more like 14.3 with ethanol. I know there are smarter people out there that know this, especially tuners.
Ethanol free you can make more power, adjust timing etc... Is it worth it, maybe, as the fuel costs more sometimes.. |
03-22-2023, 10:56am | #28 | |||||||
Barn Stall Owner #116
Doesn't have a big thing
I used e85 in all my cars once I do the flex fuel kit and tune, none are driven too much, as a while ago it was explained to me that ethanol is very corrosive for fuel pump, lines and injectors. One day I may win the lottery and get a reliable daily driver,,, |
03-22-2023, 11:14am | #29 | |||||||
03-22-2023, 11:21am | #30 | ||||||
When running straight alcohol, what is your air fuel ratio. 7 to 1.
So, explain how adding alcohol leans the air fuel ratio out. I have no problem beomg corrected, and will take contructive crticism, but I know af ratio with 10% ethanol reduces af ratio https://www.carparts.com/blog/what-i...hart-included/ |
03-22-2023, 12:27pm | #31 | ||||||
You're talking apples and oranges. 100% pure Ethanol or E85 has to run at 7:1 because it has 50% of the energy of gasoline, which runs at 14:1-ish. Add E-10 to a fuel system designed and jetted to run pure gas, and the system runs lean due to the diminished energy in the ethanol. Ask anybody who runs pure ethanol or E85 how they jet their carburetors. They will tell you that they either removed the jets entirely, or went up 100% in jet size. If you tried to run pure alcohol in a fuel system jetted for pure gas, you would be over 25:1 and so lean you would burn up your pistons. Hell, I saw that happen maybe 6 times this month at the vintage drags....lean condition on the top end, and Poof go the pistons.
03-22-2023, 12:29pm | #32 | ||||||
03-22-2023, 12:49pm | #33 | |||||||
The Following User Says Thank You to Vette40th For This Useful Post: |
03-22-2023, 12:57pm | #34 | ||||||
Correct. That's the IDEAL ratio. So you need to jet RICHER to run it. If you put E-10 into your non-computer-controlled car, your car will run leaner (15.7 or so) UNLESS you re-calibrate your carb or fuel injection. Newer cars like my Tundra do this automatically. I simply get about 2 MPG more when I run pure gas out of state on trips. Back in CA, it drops due to the E-10 being less efficient because of its lack of energy compared to gasoline.
03-22-2023, 1:23pm | #35 | ||||||
GTO DOOD is the man, as always!!
03-22-2023, 1:55pm | #36 | |||||||
Apologies for the 'wrong-o'. I interpreted that you said that ethanol simply made the mixture richer all by itself, and went on my tirade. We both agree on this. |
03-22-2023, 2:05pm | #37 | ||||||
03-23-2023, 8:13am | #38 | |||||||
Barn Stall Owner #17
Scott
03-23-2023, 8:21am | #39 | ||||||
03-23-2023, 11:12am | #40 | |||||||
Again, the OP needs to dump the current turd while it still runs and drives, because it won't shortly. |
