Old 03-20-2010, 11:15pm   #1
MYSCZ06
Points: 11,473, Level: 74
Activity: 0.6%
MYSCZ06's Avatar
Gameroom Barn Bucks: $2154
Default ok if its not one thing....
Its another... ok on my way home tonight from a CHL/CCW class my passenger head light went ....well limp..lol its got a lazy eye it opens and closes just fine and when closed its tight but when up it sits about 2-3 inches lower and is loose you can lift it up to where it should be let go and it falls... its too dark to mess with it tonight but anyone here have any idea what to look at first..thanks!
~~Shawn~~
2018 Z06 A8
Old 03-20-2010, 11:19pm   #2
My first guess would be a stripped gear, but typically those manifest via a grinding noise when lowering the lights.
Old 03-21-2010, 8:18am   #3
I'm guessing you lost a few teeth on your gear.
Old 03-21-2010, 9:23am   #4
MYSCZ06
Activity: 0.6%
MYSCZ06's Avatar
hmm guess I need to get in there see what they gears are looking like...is that possible or is it enclosed? best place to get replacement gears? gmparts wharehouse?
~~Shawn~~
2018 Z06 A8
Old 03-21-2010, 9:42am   #5
If you're going to inspect the gears you pretty much should plan on replacing them while you're in there.
step 1... remove the four #25 torx that hold on the painted headlight cover.
step 2... There are four 10mm bolts that hold the motor in. Its easier if you have a deep socket and a 1/4" drive...
step 3... Remove motor and pry open the case...
step 4... Remove & Replace gear (make sure your lube properly)
step 5... Epoxy the cover back and reinstall.
They make some brass gears that won't strip etc which is what everyone uses as replacements but I'm not sure where to get them.
Old 03-21-2010, 10:35am   #6
Z06PDQ
Points: 14,229, Level: 82
Z06PDQ's Avatar
Gameroom Barn Bucks: $16626
Default found this
Corvette C5 Headlight Motor Gears by Rodney Dickman
The Following User Says Thank You to Z06PDQ For This Useful Post:
Old 03-21-2010, 10:41am   #7
MYSCZ06
Activity: 0.6%
MYSCZ06's Avatar
Well it appears that when I put my new headlights in and I re-installed the arm pin the weird locking washer has come off and that ans the pin are gone so when the head light goes up the arm slides further up into the housing allowing it to drop...well that's what I gather is going on after quick inspection will now more when I pull the head light apart...oh and some how I tore a 2 ft small section of belt off my new set up too....1 rib and about 2 ft long....like I said one thing or another....lol
~~Shawn~~
2018 Z06 A8
The Following User Says Thank You to MYSCZ06 For This Useful Post:
Old 03-21-2010, 12:30pm   #8
Glad it wasn't the gear.
Maybe you need to go out and sacrifice a virgin to the gods or something?
Old 03-21-2010, 1:02pm   #9
MYSCZ06
Activity: 0.6%
MYSCZ06's Avatar
Yea right!...lol
~~Shawn~~
2018 Z06 A8
Old 03-21-2010, 1:31pm   #10
vettex2
Banned
Points: 2,866, Level: 34
vettex2's Avatar
Gameroom Barn Bucks: $2741
I lost both pins within a week
I replaced them with bolts and poly-lock nuts
vettex2 is offline   Reply With Quote
Old 03-21-2010, 7:28pm   #11
MYSCZ06
Activity: 0.6%
MYSCZ06's Avatar
ok well its all fixed...again...lol
I got a new pin for the headlight and a cotter pin installed functioning properly!
I got a new smaller diameter tensioner pulley the reason for this is because the 5.00 charger pulley was actually rubbing the tensioner pulley since it was so big it left little room to tighten it up and it was rubbing....but its all fixed and buttoned up...hope thats all the excitement for the time being I have a long road trip to Missouri then onto South Carolina dont need stuff breaking!!
~~Shawn~~
2018 Z06 A8
The Following 2 Users Say Thank You to MYSCZ06 For This Useful Post:
Old 04-05-2010, 8:37am   #12
Tulsa Vette Guy
Points: 4,253, Level: 44
Tulsa Vette Guy's Avatar
Gameroom Barn Bucks: $13
Originally Posted by Z06PDQ View Post
Yes, That is where I got my kit from, about $47.00, All brass gears, a complete kit to do one headlight.
78 Red coupe
87 Red C4 Vert
2002 C5 Millennium Yellow Coupe
The Following 2 Users Say Thank You to Tulsa Vette Guy For This Useful Post:
Old 04-05-2010, 7:09pm   #13
MYSCZ06
Activity: 0.6%
MYSCZ06's Avatar
awe new brake pads are needed now....lol they started making little bit of noise on whay to SC..guess I will use this thread to outline my issues ....lol
~~Shawn~~
2018 Z06 A8
Old 04-05-2010, 7:16pm   #14
Z06PDQ
Z06PDQ's Avatar
I did mime myself. Midas quoted me $700. I said "I believe I can beat that." I just did the fronts.the backs are still good.. had to buy two rotors.it was about $175 total. more $$ for
Old 04-05-2010, 7:39pm   #15
Garb55
Points: 17,083, Level: 90
Garb55's Avatar
Gameroom Barn Bucks: $7813
more $$ for
The Following User Says Thank You to Garb55 For This Useful Post:
Old 04-06-2010, 5:47pm   #16
MYSCZ06
Activity: 0.6%
MYSCZ06's Avatar
yea plan on doing mine myself also...did them right when I first bought the car I believe I have hawks on there last 32k or so. I have gotten pretty good at doing a lot of my on preventive maintenance
~~Shawn~~
2018 Z06 A8
