09-17-2011, 11:15am | #81 | |||||||
Gameroom Barn Bucks: $1545413
If some idiot builder/inspector allowed that pass. (shrug) My friends house was built about ten years ago, long past the time metal poles should be used to shore up living space. The pole apperas to have been added later, just by the looks of it, after the upper level started to sag. It's a cheap shortcut, plain and simple and it clearly is in the way of everything. I am not a builder and I respect your knowledge, but if anyone showed me a modern home with a stupid metal pole in the garage, I would question whether he should be allowed to build a plastic shed, much less a home. Not a knock on the OP's deal, like my friend, prolly got a smokin' deal, partly b/c of that pole. |
09-17-2011, 11:42am | #82 | ||||||
Gameroom Barn Bucks: $19527
My house built in 1985 has a metal pole in the garage supporting the rooms above the garage. I hate the placement because it is in the way of the car doors. Since this is somewhat open (mine is all sheetrocked), I would replace that single pole with two poles that do no interfere with the car doors.
09-17-2011, 1:12pm | #83 | |||||||||||
I can't speat to your friends home.
Why? If it meets the engineering and is code compliant, what is the big deal? Quote:
as I noted in my previous post...the column is in place to support the beam that the floor joists sit on. With that type of construction, the column...or a load bearing wall would have had to always been in place. In the OP case...I'd bet the column was part of the original build. Quote:
People complain about builders pricing as it is. Go and try to quote a new home. I guarantee...any buyer on a limited budget will opt for the upgrades I mentioned in lieu of a full span floor truss system. Quote:
09-17-2011, 2:18pm | #84 | ||||||
Guys talk of 'engineered trusses' and such crap, I would never use them in any home I lived in.....here is the reason.....
A good old friend who had a cabinet shop, but shut down and joined the Mongomery Co Md. fire dept.....so in his training, he found out the county tagged certain newer build communities down to specific houses..... reason why? is they used OSB or engineered truss type construction for beams or joists....and that type construction when on FIRE will virtually explode and cave in with nearly zero burn time.....the men are NOT ALLOWED TO ENTER THE HOUSE unless there is direct evidence of someone in direct peril..... which means that is a huge reduction in what they talk of as 'burn time'.... kinda like a fire door...or whatever.... I was amazed to here his comments about that, and so all his house and my place were always good solid 2x X solid lumber..... and you be amazed the shit I seen on job sites years ago....plumber need to make a hole in a OSB engineered joist...no problem, hit it with a hammer blow a hole in it, run the pipe.....cover it up with shitrock and no one knows anything.... I"m happy enough with my simple little slab house....screw all that crap.... stairs are a pain in the knees anyway when older..... |
09-17-2011, 2:44pm | #85 | ||||||
Gene
I'm not a fan of the OSB "I-beam" floor trusses. but properly handled and installed...and keep the subs from destroying them like in your example, they are fine. For long span floor systems where one does not want supporting beams and the columns that go with it...I like open web floor trusses of #2 pine 2x4 and/or 2x6. they are strong as an ox and do the job well. of course I also agree w/ ya on the 2x12x16oc floor framing system...it's what I used on the beach house. but then, I had no spans over 12 foot. but you can't have it both ways. if one wants conventional 2x12 floor framing...on spans over 14-16 foot...there will be a beam, and the column(s) under the beam to support it all. |
09-17-2011, 2:55pm | #86 | ||||||
Barn Stall Owner #16A
Gameroom Barn Bucks: $602908
The project is looking very nice!
09-17-2011, 4:28pm | #87 | |||||||
I am no builder, but I know crap when I see it. I agree, in the OP's house, it looks like it was there from the beginning. Nobody wants a pole in the middle of a friggin' garage. FACT If a man will take a house with pole in the garage over upgraded countertops, he probably let's his wife run the house so he's a failure anyway. I am not "off-base" about the price-point either; we used the fact that this house had a stupid friggin' pole as a major negotiating tactic. Hard to say for sure, but the pole being there probably cost the seller 10K. Again, the OP's house is much older, I assume, so it may not be relevant. It is also not my intent to knock the OP's house; I'm sure it will turn out great. |
09-17-2011, 6:08pm | #88 | ||||||
Barn Raising III
Gameroom Barn Bucks: $10070941
Lars is pretty much right on all accounts. BTW the pole in the garage lines up with the load bearing wall that seperates the livingroom from the kitchen.
Also it seems like those poles are common place here the southeast on homes that are 15+ years old or so. The last house i did had them too. As did the one before that. |
09-17-2011, 6:23pm | #89 | |||||||
Barn Raising III
BTW the cabinets are in for the most part. Appliance delivery tuesday. The electrician has to some back too, to move a couple outlets. |
The Following User Says Thank You to ...Whitepower... For This Useful Post: |
09-17-2011, 6:24pm | #90 | ||||||
Gameroom Barn Bucks: $3632152
Keep coming with the updates.
09-17-2011, 6:33pm | #91 | ||||||||||
wants and needs... Quote:
09-17-2011, 6:34pm | #92 | ||||||
09-17-2011, 6:41pm | #93 | ||||||
Barn Raising III
09-17-2011, 7:13pm | #94 | ||||||
The odd part to me was I had never seen crap like that and in the past month I saw two.
I think everyone agrees nobody wants poles in the garage b/c they are obtrusive. |
09-17-2011, 7:23pm | #95 | ||||||
Barn Raising III
09-17-2011, 7:27pm | #96 | ||||||
09-17-2011, 7:27pm | #97 | ||||||
09-17-2011, 7:28pm | #98 | |||||||
Instant ROI. He bought the house about 40K under market in a demand area so he's a happy camper. |
09-17-2011, 7:31pm | #99 | ||||||
Barn Raising III
09-17-2011, 7:32pm | #100 | ||||||
