Old 06-08-2011, 9:11am   #21
jaxgator
Barn Stall Owner #99
NCM Supporter '11,'13
Bantayan Kids '13,'14
Points: 38,631, Level: 100
jaxgator's Avatar
Gameroom Barn Bucks: $1017
My guess is the carb's gummed up. How long did it sit before you tried to crank it?
My pressure washer does this every year. It's always the same thing. The bolt on the bowl is gummed up. I take the carb apart and clean the holes in that bolt with a paper clip. Put it back together and it fires right up.
jaxgator is offline   Reply With Quote
Old 06-08-2011, 9:25am   #22
Truck Guy
Barn Stall Owner #18
NCM Supporter '11
Points: 20,953, Level: 99
Truck Guy's Avatar
Gameroom Barn Bucks: $227052
Usually a gas feed problem through the carb if it will start and then die.
Truck Guy is offline   Reply With Quote
Old 06-08-2011, 9:33am   #23
Entropy
Fantasy Football Champ '12
Points: 26,770, Level: 100
Entropy's Avatar
Gameroom Barn Bucks: $90918
Originally Posted by VatorMan View Post
Mark mowing the yard
I knew it!
Entropy is offline   Reply With Quote
Old 06-08-2011, 9:35am   #24
C5SilverBullet
Barn Stall Owner #3
Barn Raising I
NCM Supporter '11, '12
Points: 43,112, Level: 100
Activity: 1.1%
C5SilverBullet's Avatar
Gameroom Barn Bucks: $2324642
Originally Posted by Uncle Pervey View Post
Do what I do... hire a Messican.
That's what I do too.
C5SilverBullet is offline   Reply With Quote
Old 06-08-2011, 12:49pm   #25
FRISKY
Friday Fiver
Points: 18,570, Level: 94
FRISKY's Avatar
Gameroom Barn Bucks: $733982
Put some SeaFoam in the gasoline every once-in-a-while.
FRISKY is offline   Reply With Quote
Old 06-08-2011, 1:21pm   #26
...Whitepower...
Barn Raising III
Points: 51,252, Level: 100
...Whitepower...'s Avatar
Gameroom Barn Bucks: $10070941
I cleaned the existing air filter that was dirty as shit and swapped out the plug Monday and nothing. The gas is fine as its a month old. The mower has been acting up latley though. I am going to check out the carb tonight and see where that gets me.
...Whitepower... is offline   Reply With Quote
Old 06-08-2011, 1:26pm   #27
NeedSpeed
Points: 69,720, Level: 100
NeedSpeed's Avatar
Gameroom Barn Bucks: $1553643
Does it fire at all? Might verify you're getting spark by touching the plug to something metal on the mower and pulling the cord and watching for spark.
If it is you might spray starter fluid on the plug and a squirt in the plug hole.
NeedSpeed is offline   Reply With Quote
Old 06-08-2011, 1:30pm   #28
...Whitepower...
Barn Raising III
It fires and turns over for two seconds and stalls out.
Old 06-08-2011, 5:58pm   #29
Jeff '79
Barn Stall Owner #2112
Fantasy Football Champ '14,'16,'20
Points: 162,095, Level: 100
Jeff '79's Avatar
Gameroom Barn Bucks: $3043611
the rubber diaphram in the carb has minute pinholes in it....rebuild time. bummer.
Jeff '79 is offline   Reply With Quote
Old 06-08-2011, 6:00pm   #30
jaxgator
jaxgator's Avatar
Definitely starting to sound like a problem with the carb.
Old 06-08-2011, 6:04pm   #31
F40
Barn Stall Owner #17
Points: 4,521, Level: 45
F40's Avatar
Gameroom Barn Bucks: $2311
Yep. easy fix
F40 is offline   Reply With Quote
Old 06-08-2011, 6:24pm   #32
65 Hardnoks
Points: 1,744, Level: 25
65 Hardnoks's Avatar
Gameroom Barn Bucks: $1171
What else should i do.
Once you get it running, don't do squat to it for at least 8-10 years.
Leave it outside uncovered all year long through below zero temps to 100 plus days.
I wheeled my '89 Murray 5hp B&S motored machine down to the curb this spring. Two slow pulls on the cord to get the oil where it needed to be, then VROOM!
YMMV
Edit: I think lawn mowers are manly machines and they don't like to be babied. IMHO
65 Hardnoks is offline   Reply With Quote
Old 06-08-2011, 6:33pm   #33
Jeff '79
Jeff '79's Avatar
The damn ethanol ruins the rubber hoses and diaphragms in the older mowers...Newer machines have materials that can tolerate ethanol.
Old 06-08-2011, 8:38pm   #34
...Whitepower...
Barn Raising III
There was shit in the fuel tank. Running fine now. After 6 years it was time for a tune up anyway.
Cleaned up the tank, changed the oil, new air filter, new plug, cleaned up the carb a bit and the 6.5hp Briggs and Stratton is running fine.
Old 06-08-2011, 8:41pm   #35
SnikPlosskin
Barn Stall Owner #93
Points: 63,830, Level: 100
Activity: 2.5%
SnikPlosskin's Avatar
My starter won't mow.
Old 06-08-2011, 8:43pm   #36
Jeff '79
Jeff '79's Avatar
It makes me feel just great that all of my suggestions, were completely wrong.....
Old 06-08-2011, 8:45pm   #37
65 Hardnoks
Now, keep it outside. That's the "fine" tuning!
YMMV
Old 06-08-2011, 8:51pm   #38
SnikPlosskin
Activity: 2.5%
How many times has Thrakk told you not to shit in your fuel tank?
Old 06-08-2011, 8:58pm   #39
oahuyahoo
Barn Stall Owner #67
Points: 12,190, Level: 76
oahuyahoo's Avatar
Next time save yourself a bunch of trouble and give ol' Red a gingle at CFOT.
oahuyahoo is offline   Reply With Quote
Old 06-08-2011, 9:02pm   #40
NEVRL8T
Barn Stall Owner #25
Points: 27,763, Level: 100
Activity: 0.5%
NEVRL8T's Avatar
Mark, you weren't using that mower while making some of your horseporn movies, were you?
NEVRL8T is offline   Reply With Quote
