Old 01-18-2010, 6:30pm   #1
Default Center console power port inop... fuse?
Noticed the center console power port doesn't work today. For reference the cig lighter one works fine. Also, I pulled up the trim panel that houses the TC/AH button and pass. airbag light and checked all connections. The TC/AH button works properly and the pass. airbag light works as intended.
I'm too lazy to go pull up the carpet and start messing w/ fuses... anyone have a fuse list or know if the power port is on it's own fused circuit? The plug connector looked fine and none of the terminals were bent or bunt at all.
Thanks,
Brian
EDIT: Times like these I wish I wasn't perma-banned from CF
http://forums.corvetteforum.com/c5-t...in-the-c5.html
I'm posting this because it was way too hard to find the fuse location of the power outlet in the the center console, even after searching the Forum. Also, the GM shop manuals do an extremely poor job of helping you find this as well.
The fuse location for the 12V "Cigar Lighter/Accessory port" in the center console is in the interior fuse panel on the passenger side floor under the mat. Once you find this, it is still far from obvious which fuse it is. To save the next guy some trouble, the exact fuse is fuse #1 "CNSLCIG", which actually stands for Console Cigar Lighter Lighter.
MadDog
Old 01-18-2010, 6:49pm   #2
GB Vette
The Old Guy
Points: 62,624, Level: 100
Activity: 6.4%
GB Vette's Avatar
Gameroom Barn Bucks: $804566
I guess you don't need this now
'02 FRV (Fixed Roof Vert)
NCM Lifer #1572
Old 01-18-2010, 6:51pm   #3
Points: 35,032, Level: 100
Yes, it is it's own circuit (20a fuse #1). Nothing else on that fuse.
The lighter in the ashtray is 20a fuse #7.
Old 01-18-2010, 10:05pm   #4
Fuse was clearly blown... easy fix
Thanks Gary I'm going to save that.
Old 01-18-2010, 10:52pm   #5
DropTheTop
Barn Stall Owner #777
Points: 22,113, Level: 100
DropTheTop's Avatar
Gameroom Barn Bucks: $6589249
Thanks,
Brian
Fuse # and Location for 12V accessory port in the C5 - Corvette Forum
Sweet! Mine doesn't work either, and I never bothered to track it down.
Thanks guys.
