02-26-2023, 3:15am | #1 | ||||||
Senior Lurker
Barn Stall Owner #95
Gameroom Barn Bucks: $750520
LED Lights Color Temperature
Any of you have a bunch of LED recessed lights in your home? If so, what color temperature do you have? 2700K, 3000K, 4000K, 5000K? Which is best?
02-26-2023, 3:41am | #2 | ||||||
I used to have a skylight in the LR, but when roof was replaced some 2 years ago, I covered it over outside, so inside I have a timer on a 4' LED light, first one was cheep enough, so bought about 6 of them, one in the ceiling above the diffuser panel and a piece of silver surface insulation above it.....and so wooden I know about 4 outta the six went out not so long ago, and so I upped the price paid a bit and got 3 more and did not use one in the storage shed....
as to color, it's bright white, but I can't put a number on it..... |
02-26-2023, 6:02am | #3 | ||||||
Depends on what you want.. The higher the number closer to sunlight.
I went woth 4700 and 5k I believe. Same with all the led lights in my barn, 5k. I do have a multi color range led light bed side as nobody wants the sun first thing i the morning. Something to consider... Also dimmable are awesome. |
02-26-2023, 6:53am | #4 | ||||||
2700°K, 90+ CRI. That's as close as I've found to incandescent bulbs. I've had the best luck with Philips. Cree has been pretty good too, except their 3-way A19 bulbs.
5k+ gives me headaches after prolonged exposure. |
The Following User Says Thank You to CurtP For This Useful Post: |
02-26-2023, 7:06am | #5 | ||||||
Barn Stall Owner #16A
Gameroom Barn Bucks: $602908
2700K because it’s as close to incandescent as I could find. Same as above. Bright white light like fluorescent bulbs produce give me stress and aggravation. Incandescent is much easier to tolerate.
02-26-2023, 7:09am | #6 | ||||||
When our house was being built we told the contractor we wanted recessed lighting throughout the house. He suggested these. They have 5 settings from 2700K to 5000K. We set them all at 3500K. I liked that we could choose the setting that best suited us. They are dimmable, but we didn't put in any dimmer switches. Fairly inexpensive units, too.
https://www.amazon.com/dp/B08KG6KLX1...led%2Brec&th=1 |
The Following User Says Thank You to 86RAG For This Useful Post: |
02-26-2023, 7:13am | #7 | ||||||
3000k
This is my signature |
The Following User Says Thank You to Rob For This Useful Post: |
02-26-2023, 8:23am | #8 | ||||||
02-26-2023, 8:31am | #9 | |||||||
I like those adjustable units... |
02-26-2023, 10:12am | #10 | |||||||
02-26-2023, 10:14am | #11 | ||||||
Barn Stall Owner #14/32
Gameroom Barn Bucks: $4810
118K
Alright...I had to check. 2700K here, except the basement--5000 down there. |
The Following User Says Thank You to Vandelay Industries For This Useful Post: |
02-26-2023, 11:12am | #12 | ||||||
Barn Stall Owner #117
Depends on whether you are in vegetative mode or flowering mode.
The Following 4 Users Say Thank You to Tikiman For This Useful Post: |
02-26-2023, 12:58pm | #13 | ||||||
Probably a dozen houses in my subdivision have that kind of lighting in the cornices of their houses. It's a neat effect at night, I guess they can control the color and intensity of them, too.
02-26-2023, 2:56pm | #14 | ||||||
Barn Raising I
Gameroom Barn Bucks: $308343
5000k. So they match my headlights.
The Following User Says Thank You to TripleBlack For This Useful Post: |
02-26-2023, 6:25pm | #15 | ||||||
02-26-2023, 10:06pm | #16 | |||||||
Gameroom Barn Bucks: $2173478
Long story short she decided against the 2700k and settled on 3500k |
02-27-2023, 10:13am | #17 | |||||||
I buy my incandescent lights in bulk. Usually from Grainger, but lightbulbs.com have them as well. I buy 100w and 60w regular bulbs and PAR30L halogens. |
The Following User Says Thank You to Tikiman For This Useful Post: |
02-27-2023, 11:21am | #18 | ||||||
My City house had a huge variety of fixtures, all different types of incandescent bulbs that required replacing often. As a result I had a small warehouse full of bulbs. All heating up the house and adding to my cooling bill.
I replaced the most used with LEDs long before the bulbs were available everywhere and cheap like they are now. Many of those are still working, so they have saved me a boatload in electricity. Regarding color |
02-27-2023, 2:24pm | #19 | ||||||
Barn Stall Owner #13
Gameroom Barn Bucks: $425244
I prefer 3500, 2700 is too yellow and 5000 is too white. My garage is 5000 but inside the hose we have mostly 3500 and a few 3000
The Following User Says Thank You to Black94lt1 For This Useful Post: |
02-27-2023, 5:45pm | #20 | ||||||
VB Dad of the Year
The Following 2 Users Say Thank You to Datawiz For This Useful Post: |
