Old 10-20-2009, 6:25pm   #1
Default Still no N2O talk in here?
I know someone on here must be spraying their car... If so tell me about your set up. Dry, wet, Nano, etc...
Oh yeah, if you do spray, can I have a ride?
Old 10-20-2009, 6:33pm   #2
nedih rotaredom
Sophisticated PITA CM
Points: 2,433, Level: 31
nedih rotaredom's Avatar
Gameroom Barn Bucks: $837
Hehehe................150 wet nx............next year a ride I hope
Old 10-21-2009, 9:49am   #3
edcmat-l1
Charter Member - Vendor
Points: 3,014, Level: 35
edcmat-l1's Avatar
Gameroom Barn Bucks: $1080
Here's a lil spray for yas!
https://www.thevettebarn.com/forums/c....html#post3780
The Following User Says Thank You to edcmat-l1 For This Useful Post:
Old 10-21-2009, 5:05pm   #4
Originally Posted by edcmat-l1 View Post
That's what I'm talkin about!
Old 10-21-2009, 9:27pm   #5
Stangkiller
Barn Stall Owner #5
Barn Raising I,II,III,IV
NCM Supporter '11,'12,'13,'14,'16,'17,'19,'20,'21
Points: 50,885, Level: 100
Activity: 1.4%
Stangkiller's Avatar
Gameroom Barn Bucks: $2173478
I want some on my busa
99 coupe -- supercharged
Stangkiller is offline   Reply With Quote
Old 04-26-2010, 1:58pm   #6
Z06PDQ
Points: 14,229, Level: 82
Z06PDQ's Avatar
Gameroom Barn Bucks: $16626
Default faulty remote bottle opener switch
remote bottle opener switch has been "hit or miss" for a couple of months now. in the open position it worked fine every time,but when I went to close it I had to hit it till my damn finger got sore. today I tried some "starter & generator" cleaner that I had left over from using to clean the wheel sensors when I was getting codes. that did the trick. even though I used a rag I got some on the plastic it looks kind of "chalky" now. oh well, at least I didn't have to replace it.
Old 04-26-2010, 8:36pm   #7
Glad you got it fixed. Lucky break.
How does the opener work exactly? Do you just hit the switch and the opener runs until the bottle is open or closed or do you have to hold the switch the whole time? If you have to hold the switch how do you know when it's open/closed?
Old 04-27-2010, 7:29am   #8
Z06PDQ
Z06PDQ's Avatar
you can hear a change in pitch in the motor when the bottle opens or closes. once it closes I purge the N2O in the line to keep pressure off the solenoids.
Old 04-27-2010, 5:26pm   #9
Spray? What is this spray you speak of?
Old 04-27-2010, 6:00pm   #10
Z06PDQ
Z06PDQ's Avatar
just refilled my bottle today. 8 lbs. for $36. has this **** gone up? what do ya'll pay? I went to two different shops that were out & finally found it at an "off road" truck place. last time I bought it, it was $2.50- $3.00 lb.
Old 04-28-2010, 5:46am   #11
$6.90 a lb. here. $73.00 to fill a 10 lb bottle!
Old 04-28-2010, 7:00am   #12
Old 04-28-2010, 8:45am   #13
Z06PDQ
Z06PDQ's Avatar
used to be the shops used refills more as a "service." they figure to get you in there to buy N20 & you'll buy something else from them. times are tough. now they have to make $$ where they can.
