02-28-2017, 3:26pm | #121 | ||||||
Barn Stall Owner #3
Gameroom Barn Bucks: $2324642
The Following User Says Thank You to C5SilverBullet For This Useful Post: |
03-10-2017, 10:15am | #122 | ||||||
Barn Stall Owner #3
Bricks and insulation.
The Following 3 Users Say Thank You to C5SilverBullet For This Useful Post: |
03-10-2017, 10:21am | #123 | ||||||
03-10-2017, 10:24am | #124 | ||||||
Barn Stall Owner #3
03-10-2017, 10:25am | #125 | ||||||
03-10-2017, 10:40am | #126 | ||||||
They do sell unfaced (no paper) insulation, which is cheaper, but probably harder to install. Maybe that's what we are looking at?
If I ever have a house built again, I'm going to insist on upgraded insulation. It doesn't cost that much more, and the labor is the same. r-19 in walls instead of r-13. and r30 in attic vs. r-19 When I replaced some of the builder attic insulation with r-30 after Ike, I noticed a difference in how quickly the house heated up in the Summer. Still thinking about going up there and upgrading the rest of the attic, before it gets hot.I think you'd get more bang for the buck doing that then say, using the expensive double pane windows. |
03-10-2017, 10:47am | #127 | |||||||
Barn Stall Owner #3
03-10-2017, 3:10pm | #128 | ||||||
R-19 is the minimum for an attic, maybe that's what was discussed? Your pictures clearly show R-13 in the walls. If you agreed on R-19 for the walls, now would be the time to have a chat with your builder, before the drywall goes up.
03-10-2017, 3:31pm | #129 | ||||||
Barn Stall Owner #101
Gameroom Barn Bucks: $6269655
It's all pink to me.
03-10-2017, 4:08pm | #130 | ||||||
Barn Stall Owner #87
Gameroom Barn Bucks: $16535584
I only see the labels in the one pic, and that appears to be the garage. You might have a chat with the building inspector. They do have inspectors down there don't they? In NJ they do a inspection prior to drywall installation.
03-10-2017, 4:25pm | #131 | ||||||
Good point. I don't see any printing on the insulation in the house. Maybe garage insulation is considered a separate thing, even when it's attached? My garage is detached.....no insulation or sheetrock, just exposed studs.
03-10-2017, 4:29pm | #132 | ||||||
R13 is on 2x4 framing.....R19 is on 2x6 framing....garages are mostly 2x4....
hard to tell from pix about the rest of the house....I ASSume you know the diff when you look, a 2x4 is actually 1.5x3.5 inches 2x6 is actually 1.5x5.5 inches.... |
03-10-2017, 5:12pm | #133 | ||||||
Not much of a reason to put more then R-13 in tha garage unless it's heated or cooled.
03-10-2017, 8:04pm | #134 | ||||||
Barn Stall Owner #3
I didn't actually ask him anything, he just mentioned it during a conversation. I know absolutely 0 about it.
03-10-2017, 8:10pm | #135 | ||||||
Ask about the insulation and if it is paper backed. If it is, it was installed incorrectly. Unfortunately I have experience installing insulation and paper goes towards the living space.
03-10-2017, 8:11pm | #136 | ||||||
Barn Stall Owner #3
More brick.
03-11-2017, 2:35am | #137 | ||||||
Barn Stall Owner #13
Gameroom Barn Bucks: $425244
The vapor barrier (paper) needs to face the cost conditioned side, if not it will allow moisture into the insulation. If they are using unfaced insulation, then a plastic vapor barrier will need to be added before sheetrock
03-11-2017, 11:50am | #138 | |||||||
Barn Stall Owner #3
It is R-19 in the living area, and R-13 in the garage. |
03-11-2017, 11:52am | #139 | |||||||
Barn Stall Owner #3
It is R-30 in the attic. |
The Following 2 Users Say Thank You to C5SilverBullet For This Useful Post: |
03-11-2017, 12:00pm | #140 | ||||||
Barn Stall Owner #3
They did use some R-30 in the garage also, on the front half.
