01-26-2011, 11:29am | #1 | ||||||
Barn Stall Owner #35
Gameroom Barn Bucks: $1212
ABS/4WD Warning Light Question
2006 Mercury Mariner V6 AWD Automatic (Ford Escape)
My ABS Light has started coming on and along with it the 4WD light. The lights will be off when the car is started and will come on a few miles down the road. Service Brake System and Service 4WD System in message center. The ABS light is steady and the 4WD light flashes 8 times approximately every 40 seconds. No Codes appear in my code reader. The sensors and harnesses appear okay. Any ideas? Thanx. Mark |
01-26-2011, 11:35am | #2 | ||||||
Gameroom Barn Bucks: $2173478
Not all code readers can check ABS and body control codes -- perhaps try a different scanner?
01-26-2011, 11:39am | #3 | ||||||
01-26-2011, 12:13pm | #4 | ||||||
All autozones/Advance can scan your CIL <Check Engine Light> But not all of them can scan your other codes. Call around to find one with the better scanner available, they will check the code for free.
01-26-2011, 12:21pm | #5 | ||||||
Vette Barn Deacon
Gameroom Barn Bucks: $21169452
Check your fluid levels lately?
01-26-2011, 1:39pm | #6 | ||||||
01-27-2011, 12:43pm | #7 | ||||||
Okay. Upon further inspection, it looks like the tone ring on the LF is cracked.
If that doesn't do the trick, I'll let you guys know. |
01-27-2011, 12:47pm | #8 | ||||||
Barn Stall Owner #420
Gameroom Barn Bucks: $12530349
hope that takes care of the problem, check engine lights drive me insane..specially the ones that come on for scheduled service intervals
01-27-2011, 1:50pm | #9 | ||||||
Vette Barn Deacon
01-27-2011, 1:55pm | #10 | ||||||
Gameroom Barn Bucks: $56446
That's going to be it. I was going to say before paying for diagnosis, visually inspect all wheel speed sensors and wiring because that is usually going to be the problem. But it looks like you already did that and found the problem. |
01-27-2011, 6:23pm | #11 | ||||||
LF is Left Front, and here's a pic showing the electromagnetic (tone) ring and the sensor that monitors it.
It was pretty easy to see that it was cracked once I moved the truck forward enough times to see all of it. |
08-05-2013, 6:46am | #12 | ||||||
08-05-2013, 7:18am | #13 | ||||||
Bantayan Kids '13,'15
Gameroom Barn Bucks: $1037769
08-05-2013, 12:51pm | #14 |
For some reason, I've found that ford products are really weird when it comes to dealing with the ABS. They're tied into everything and a small sensor on the passenger rear of the RV my family had shut that mother down...like it wouldn't run kinda shut down.
