Picture Perfect Share your photography tips, techniques and prize captures here. |
01-18-2014, 9:38pm | #1 | ||||||
Goldilocks
Gameroom Barn Bucks: $1009320
Splash!
The Following 3 Users Say Thank You to Giraffe (He/Him) For This Useful Post: |
01-20-2014, 9:23am | #2 | ||||||
Goldilocks
Manual, with a cable release. Drop fruit, release shutter. After a few times I got the timing down OK.
Speedlite covered in a plastic Baggie @ 1/128 power pushed right up to the glass. Ideally, 2 speedlites opposite from each other would be perfect. |
01-20-2014, 9:34am | #3 | ||||||
Goldilocks
They do, but they're short. Kind of a must for macro stuff where you can't have any camera shake. B&H sells a 30' extension for them.
If you have a Speedlite you've got the major expense covered. The big thing is the adaptor to get the flash off the camera body. $40.00 wasn't too painful. |
01-20-2014, 11:26am | #4 | ||||||
#2 is cool
01-20-2014, 11:36am | #5 | |||||||
Goldilocks
Canon and Nikon flashes are a little different. Nikon has been incorporating a PC jack for years. Canon FINALLY just did. My 550 didn't have a PC jack, I had to buy the kit. (The $40.00) Your flash has to have the capability to work in manual mode too. These shots were all manual on both camera and flash. |
01-20-2014, 1:06pm | #6 | ||||||
Goldilocks
A slave flash needs to see light in order to fire. Radio triggers don't. Maybe you could knock down the hot shoe flash enough so it didn't affect your exposure but still fire the slave?
The simple solution is a PC cable from your camera to the speedlight. |
01-20-2014, 4:46pm | #7 | ||||||
Do you have other back drops? I'm think blue would look much better.
01-20-2014, 4:51pm | #8 | ||||||
Goldilocks
01-20-2014, 7:04pm | #9 | ||||||
Gameroom Barn Bucks: $1001635
Nice work Thomas I really like #1 and #3...Love #2!
Was this is a fish tank? Did you have to use a CPL not to get the glass reflection? |
The Following User Says Thank You to Nitro-C5 For This Useful Post: |
01-20-2014, 7:13pm | #10 | ||||||
Goldilocks
Yes, a fish bowl. I wouldn't do a bowl again, but it was handy. I got some odd reflections off it. I think a square tank might be better.
No CPL. If you dial down the exposure enough that seems to do the trick. I did put a reflector directly opposite the speedlite to try and add some fill. I worked, sort of. |
01-20-2014, 7:31pm | #11 | ||||||
I really hope that is one of those novelty drink mugs. I know the L stuff is weather proof...but....
01-20-2014, 7:39pm | #12 | |||||||
Goldilocks
01-21-2014, 5:13pm | #13 | ||||||
You are both right. In Thomas's case if he is using another flash it is still IR, but the "Slave" units needs to see the Pre-Flash of the "Master" to fire. If you are using a Non Flash (example: IR trigger) will not send a Pre-Flash but the units still have to see each other. Basically that system is Optical vs. a radio system that does not need to be seen. Optical/IR are great in about 90% of the situation you will shoot in...where they have limitation are when the flashes are great distances apart, cannot be seen because they are in an enclosed box or on a very bright day if shooting outside.
01-21-2014, 5:58pm | #14 | ||||||
Goldilocks
01-21-2014, 6:10pm | #15 | ||||||
