Old 11-11-2010, 7:53pm   #1
Default Check those header bolts
Developed a slight exhaust leak the other night, of course it was on the drivers side. I was like WTF? Those factory metal gaskets NEVER leak. Ugh!
So today I stopped off at Autozone and picked up a set of metal Fel-pro gaskets to fix the leak, because it's going to be a sweet weekend for cruising. I figured I would just change out the drivers side, call Gene Culley and order some new factory gaskets, and replace it once the Fel-pros failed.
Pulled the FRC, and plug wires off, took the AIR tube apart and off, and started unbolting the header. When I got to the last one toward the firewall(you guys know, the ***** bolt) I could almost turn it with my fingers. That sucker had worked its way loose. My dumb arse might not have torqued it down tight enough when I put the haders on, or it just worked its way loose.
So I tightenend it down, put the other bolts back in, put the plug wires back on, re-connected the AIR system, and fired it up. Leak fixed!
Moral of the story: Make sure to check your header bolts twice if you want to save yourself some time, money, and frustration.
Old 11-11-2010, 8:00pm   #2
Garb55
Points: 17,083, Level: 90
Garb55's Avatar
Gameroom Barn Bucks: $7813
Little More Nos and you might just loosen up the Passengers Side next!
Old 11-11-2010, 9:49pm   #3
Nope, checked those while I was under the hood.
Old 11-11-2010, 9:59pm   #4
Garb55
Garb55's Avatar
Good Call
Old 11-12-2010, 6:23am   #5
Good catch.
Always make sure the gaskets you use have circular and not D shaped openings when using headers.
Just my $.02
Old 11-12-2010, 7:36am   #6
Originally Posted by WKMCD View Post
Good catch.
Just my $.02
And never use anything other than metal gaskets.
I don't know how people would even consider D shaped gaskets. Those are the same people who try to put that square peg in the round hole I think.
Old 11-12-2010, 5:25pm   #7
Congrats on the easy fix.
Is the torque for the header bolts the same as for the stock manifolds?
Old 11-13-2010, 7:58am   #8
Yes, but don't even think you're going to get a torque wrench on header bolts. AInt happenin'.
Crank them down good and snug.
Old 11-22-2010, 8:01am   #9
Z06Joe
Points: 9,241, Level: 66
Z06Joe's Avatar
Gameroom Barn Bucks: $1325
See.... that's why I don't drive mine.... too much **** can go wrong... Jus say'n!!!
(OO CORVETTE OO)
(___|1QWKZ06|___)
Z06Joe is offline   Reply With Quote
Old 11-22-2010, 9:53pm   #10
Get that thing out and drive it man!
