09-16-2011, 8:31pm | #1 | ||||||
Barn Stall Owner #1991
Ford people, need some help
2005 CV. Headlights do not come on. They will work when the lever is pulled for flash to pass. No low or high beams working. Fuse is good.
09-16-2011, 8:33pm | #2 | ||||||
Barn Stall Owner #75
Gameroom Barn Bucks: $15302323
Does it have the auto-off rotary timer?
09-16-2011, 8:37pm | #3 | ||||||
Gameroom Barn Bucks: $5201
flash to pass should kick the high beams and possibly low at the same time, so relays, bulbs and fuse sounds good. Switch maybe? Does it have auto head lights?
09-16-2011, 8:40pm | #4 | ||||||
Never heard of such a thing.
No auto headlights. Was thinking switch. Not sure how to check it. |
09-16-2011, 8:41pm | #5 | ||||||
09-16-2011, 9:07pm | #6 | ||||||
09-16-2011, 9:11pm | #7 | ||||||
09-16-2011, 10:11pm | #8 | ||||||
Barn Stall Owner #0
Gameroom Barn Bucks: $1576624
The Following 4 Users Say Thank You to C5Nate For This Useful Post: |
09-16-2011, 10:47pm | #9 | ||||||
Barn Stall Owner #65
Gameroom Barn Bucks: $5394274
Turn headlight switch to ON position with car off and open the door, does the reminder come on?
Let me know. It's all about the process of elimination. |
09-16-2011, 10:56pm | #10 | ||||||
Gameroom Barn Bucks: $1013348
09-17-2011, 5:44am | #11 | ||||||
Gameroom Barn Bucks: $3632152
09-17-2011, 11:39am | #12 | ||||||
Hooked up new headlight switch. Not it. Non-returnable too. Heading to junk yard for dimmer switch. I unhooked the old plug and the parking lights came on. Also started dinging. Now it dings with the old switch.
09-17-2011, 12:21pm | #13 | |
Speaking of that, anybody need a new fan control module for a 2005 C6? |
09-17-2011, 3:05pm | #14 | ||||||
Different dimmer switch didn't work either. I'm at a loss. Neighbor mentioned a Lighting control module, but also said it's expensive. That part is supposedly for strobe lights, which I do not have.
09-17-2011, 3:12pm | #15 | ||||||
Dorkapottamus
Barn Stall Owner #52
Gameroom Barn Bucks: $9339471
Run wires from the battery through a toggle switch to the lights. Easy. I'm still working on the dimmer issue.
09-17-2011, 3:26pm | #16 | ||||||
09-17-2011, 3:34pm | #17 | ||||||
Barn Stall Owner #16A
Gameroom Barn Bucks: $602908
09-17-2011, 3:38pm | #18 | ||||||
LCM is known for failing in these cars...nice.
09-17-2011, 3:41pm | #19 | ||||||
I mentioned that you needed to ohm it out and have a schematic before buying anything.
Does the LCM have anything to do with flash to pass? Not sure where you got the switch but if your nice and did not destroy the box they might take it back. Junkyard again? should be easy to find parts. |
09-17-2011, 3:45pm | #20 | ||||||
Bet there is a relay or the likes in the LCM that needs replacing.
Or hard wire the headlights temporarily. |
