Old 01-22-2022, 11:38am   #1
Points: 34,382, Level: 100
Default Detailing Question
@datawiz or anyone else who knows: Will a clay bar remove old dried-up tree sap from a car's paint? If not, what detailing technique should I ask The Guy to use to remove that shit?
Old 01-22-2022, 12:04pm   #2
Norm
Barn Stall Owner #1776
Bantayan Kids '13,'17
Points: 76,204, Level: 100
Activity: 15.9%
Norm's Avatar
Location: DelMarVa. Formerly owned, 65, 75, 97, 01, 10, 14, current 86, 16 Z06. Most Bucks $2,002,001,941
Yes, clay barring will remove old contaminated crap from your finish, just finished up one last Wed that felt like sandpaper, when finished, slick like a mirror.
Meguiars or Mothers clay kits work well.
https://www.thevettebarn.com/forums/...d.php?t=127672
JCS USA USN USMC USCG USAF USSF USAR USNR USMCR USCGR USAFR ARNG ANG USPHS NOAA USMM AUS CSA Police/Fire/EMS/EMT
Thank You For Your Service
Old 01-22-2022, 12:06pm   #3
Steve_R
Points: 44,285, Level: 100
Steve_R's Avatar
I’d start with a clay bar. If that doesn’t work use polishing compound either by hand or an orbital buffer depending on how much and how extensive it is. I have a non-orbital buffer I use with rubbing or polishing compound, but it’s easy to burn the paint on edges with those so you need to know what you’re doing.
Steve_R is offline   Reply With Quote
Old 01-22-2022, 12:14pm   #4
Giraffe (He/Him)
Goldilocks
Barn Stall Owner #905
Bantayan Kids '13,'15
Points: 88,051, Level: 100
Activity: 13.3%
Giraffe (He/Him)'s Avatar
Gameroom Barn Bucks: $1009320
Dried tree sap *can* be beyond the reach of a clay bar.
WD-40.
The Following User Says Thank You to Giraffe (He/Him) For This Useful Post:
Old 01-22-2022, 12:24pm   #5
Iron Chef
Barn Stall Owner #1
Barn Raising I, II
NCM Supporter '11, '12
Points: 45,749, Level: 100
Activity: 8.6%
Iron Chef's Avatar
Gameroom Barn Bucks: $2299270
Depends upon the size of the sap. The sap that comes off the trees here is usually very tiny droplets and they always wash off with water. Clay bar should work just fine, but be sure to use a lot of detailing spray to keep the bar from scratching the paint (I use Meguiar's Final Inspection but any detailing spray will suffice).
Also, fold the "dirty" surface of the bar in on itself a few times (kind of like kneading dough) to give you a clean surface to work with.
Iron Chef is offline   Reply With Quote
The Following 2 Users Say Thank You to Iron Chef For This Useful Post:
Old 01-22-2022, 1:19pm   #6
GTOKareNNN
Points: 1,083, Level: 18
Activity: 25.2%
GTOKareNNN's Avatar
Have used Kerosene to remove tree sap on lacquer and enamel paints. put a little on a cotton ball and tape it to the area and leave it for awhile. It will break down the sap and not hurt the paint.
GTOKareNNN is offline   Reply With Quote
Old 01-22-2022, 1:40pm   #7
Points: 81,880, Level: 100
Activity: 50.4%
Or Mineral Spirits works well and also will strip all old wax .....windshield looks like there is no glass in it too
I had Thompsons water seal on a Blazer I had.....thought it was far enough from the deck but.....it wasn't.
04 commemorative is offline   Reply With Quote
Old 01-22-2022, 1:43pm   #8
DAB
Barn Stall Owner #4
Points: 149,570, Level: 100
Activity: 27.0%
DAB's Avatar
in 9 years i have yet to detail wash my truck. water, soap, rinse, wipe dry with chamois, done.
DAB is online now   Reply With Quote
The Following 2 Users Say Thank You to DAB For This Useful Post:
Old 01-22-2022, 1:57pm   #9
The_Dude
Points: 33,987, Level: 100
Activity: 49.6%
The_Dude's Avatar
Gameroom Barn Bucks: $306898
https://www.meguiars.com/automotive/...-15-oz-aerosol
The_Dude is offline   Reply With Quote
Old 01-22-2022, 1:58pm   #10
Anjdog2003
Points: 27,515, Level: 100
Activity: 99.6%
Anjdog2003's Avatar
Gameroom Barn Bucks: $324490
Paging DetailDude
Anjdog2003 is offline   Reply With Quote
Old 01-22-2022, 2:45pm   #11
Datawiz
VB Dad of the Year
RDBM
Barn Stall Owner #9
Points: 102,988, Level: 100
Activity: 34.9%
Datawiz's Avatar
This is where I would have taken you as well. I agree with all of the above already suggested, but you may need a chemical. Start light, like mineral spirits, or a light alcohol. I've also used acetone successfully for things like that in the past, but be VERY careful with acetone. Strong stuff. If your clear coat is healthy, you should be fine.
Datawiz is offline   Reply With Quote
Old 01-22-2022, 4:35pm   #12
the new me
Points: 1,688, Level: 24
Activity: 6.5%
the new me's Avatar
Don't know if this works on all tree sap, but pine tree sap comes off very easily with 99% rubbing alcohol. Not sure if the 70% stuff works as well.
the new me is offline   Reply With Quote
Old 01-22-2022, 4:40pm   #13
Torqaholic
Points: 20,829, Level: 99
Activity: 67.9%
Torqaholic's Avatar
Might try white vinegar? Haven't used it for tree sap but it does a good job of dissolving baked on bug splatter.
Torqaholic is offline   Reply With Quote
Old 01-22-2022, 5:39pm   #14
I have some denatured alcohol and it seems to work, but it's extremely labor intensive. The Guy would probably charge me $1000 in labor to get all the little spots off.
Old 01-22-2022, 5:58pm   #15
Activity: 50.4%
I had to wash the entire S10Blazer with mineral spirits,then wash with car wash soap and water,dry it and then wax it
At end of day I did have a popeye arm
Old 01-22-2022, 6:10pm   #16
Steve_R
Steve_R's Avatar
Pro tip: Go to an auto paint store and get a gallon of this. It’s what they use to remove contaminates before painting a car. It won’t hurt paint. At $25/gallon I always have a can in my garage.
The Following 3 Users Say Thank You to Steve_R For This Useful Post:
Old 01-22-2022, 7:12pm   #17
Grey Ghost
Points: 40,144, Level: 100
Activity: 8.8%
Grey Ghost's Avatar
Clear Coat or Single Stage?
With clear coat you have a thin layer on top of the color coat. With single stage you are removing the color coat with about anything you touch it with.
Even a little heat from a hair dryer or heat gun may help and you can get plastic razor blades at Home Depot for scraping without damage. Then a light polish to remove the fine scratches followed by a coat of good wax.
Old 01-22-2022, 8:18pm   #18
markids77
Points: 18,430, Level: 93
Activity: 7.1%
markids77's Avatar
This. I also use my thumbnail as a scraper if the stuff is dried out and opaque... helps lift without hours of soak and rub. If still clear I simply wet a folded paper towel, sit it on the sap for a bit to soften then wipe with a clean towel. HTH.
The Following User Says Thank You to markids77 For This Useful Post:
Old 01-24-2022, 7:39pm   #19
It's a Lexus so I'm pretty sure it's clear coat.
Thanks for the suggestion, I'll look for the plastic raazor blades.
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
