03-18-2023, 8:12pm | #121 | ||||||
I really like the way you cleaned and painted the engine compartment.
03-18-2023, 8:17pm | #122 | ||||||
Gameroom Barn Bucks: $2001216
03-18-2023, 9:15pm | #123 | |||||||
It'll get detailed better, I'm not going for a frame off restomod here... |
03-18-2023, 10:39pm | #124 | ||||||
I like your approach. I like this old truck. Excellent thread.
03-19-2023, 10:39am | #125 | ||||||
Moderatrix
Barn Stall Owner #109 BR Organizer II,III,IV NCM Supporter '17 Bantayan Kids '13,'15,'17
Location: Your not a good moderator either, V-A-G. Honestly I find it kind of funny.
Gameroom Barn Bucks: $9966256
Love!! ❤️❤️😍😍
03-20-2023, 7:46am | #126 | ||||||
Ufffff, well had to pull the motor back out then drop it back in again....Wrestled the big blue for another half a day yesterday.....but finally found the sweet spot.
The torque converter was our troubles.....First attempt we bolted it to the flywheel, and tried, but couldn't get that last 1/4"......On our second try, we put the converter into the trans housing then the motor. Now those four bolts that go through the flywheel fought us, until boom they popped into their holes! The motor is completely in, and the motor mount bolts fell right into the slots! Started on the accessory items but still plenty to go. I'll get some wrenching done on it this week, lots can be done with just one person. Even closer!! |
The Following 5 Users Say Thank You to Don Rickles For This Useful Post: |
03-20-2023, 1:55pm | #127 | ||||||
Gameroom Barn Bucks: $1037769
I haven't done a motor swap in decades, but as I remember it, it has to go in and out at least once, all the while forcing...hitting...wrestling...swearing...crying...nothing in the way, no logical reason it won't seat, then it slips into place with no effort. And you wonder...wtf..?
Now you have to install the distributor 180 digress out at least twice; can't be finished until you've had a fire ball. |
The Following User Says Thank You to Craig For This Useful Post: |
03-20-2023, 3:57pm | #128 | |||||||
03-20-2023, 7:31pm | #129 | ||||||||
I did over look one more choke tube broken off,...... but it goes straight down into the manifold so easily accessed to drill it out. Baby steps.... |
03-21-2023, 11:35am | #130 | ||||||
Be advised also that the choke tubes sometimes only carry only heat, not exhaust gas. They press into a sleeve in the exhaust manifold that is sealed from the gas in the manifold. The sleeves like to rust out, along with the choke tube, and those who don't realize replace the tube, sticking it right into the manifold. This allows exhaust condensation and carbon to enter the choke T stat, causing pre-mature failure. You can restrict the end of the tube or pack some steel wool in the tube securely or whatever. I would verify with the factory manual. They all differ. The one on my '61 Corvette goes all the way through the manifold and out the bottom. Weird, but it works just fine. Some tubes DO go right into the exhaust, and IIRC, Fords may be what I remember. I remember a LOT of carboned up FoMoCo chokes!
03-23-2023, 10:11am | #131 | |||||||
Gameroom Barn Bucks: $56446
The Following User Says Thank You to ptindall For This Useful Post: |
03-23-2023, 11:22am | #132 | ||||||
Fords were really creative. Our '64 Galaxie withe the 352 was similar, only it had a heater hose bracket fastened to the choke housing has well which pressed the heater hose to the choke housing for better operation. Belt AND suspenders, I guess! My point was for our bald and sarcastic friend to verify no actual exhaust was flowing into his choke housing.
03-23-2023, 11:49am | #133 | ||||||
Moving along pretty well! Transmission and related all buttoned up. Exhaust system all back together. All the wiring is reconnected, ran a new ground cable.
When we were pulling the motor out we snapped off the reservoir hose tube… Now, to replace the pump reservoir (or the pump itself), you have to remove the pulley…. One more new tool in the box…. Pulley puller! Tool was 69. A new pump is 59.00! Just the reservoir was 50 with shipping…All done with new o rings! Rainy here today can’t play outside….. |
03-23-2023, 12:05pm | #134 | ||||||
Rebuilding the original pump with new O rings is 100% better than going the 'reman' route. That pump will likely outlast us now. For a guy with a comb-over and a barbed tongue, you're ok.
03-23-2023, 12:33pm | #135 | ||||||
03-23-2023, 1:19pm | #136 | ||||||
I like that puller, i have a decent one but always looking for a better one
03-23-2023, 2:14pm | #137 | ||||||
03-23-2023, 2:34pm | #138 | ||||||
03-23-2023, 2:48pm | #139 | |||||||
But, with the insidious gay agenda being forced down my throat for the past several years, I am out of patience with the whole thing. So it is what it is. There are a LOT of things and people and ideas that I used to not care one way or the other about that I now see as an insidious agenda that goes against my moral and ethical code of conduct. |
03-23-2023, 3:21pm | #140 | |||||||
