07-04-2018, 4:44pm | #1 | ||||||
Barn Stall Owner #122
Gameroom Barn Bucks: $1158963
So it begins.....
Decided it’s time to man up and get my track car in order. Both trans and engine going out to be rebuilt. I’ll rebuild the torque tube myself.
Having a lift makes this pretty easy. |
The Following 11 Users Say Thank You to VatorMan For This Useful Post: |
07-04-2018, 4:49pm | #2 | ||||||
Good luck with the build Tom. Looking forward to the progress pics!
07-04-2018, 5:05pm | #3 | ||||||
I’m gonna need 5 gallons of degreaser to clean everything before putting it back together.
The Following 2 Users Say Thank You to VatorMan For This Useful Post: |
07-04-2018, 5:55pm | #4 | ||||||
Barn Stall Owner #17
Good deal man!
Will be nice to have her all freshened up for the next round of beatings. Been wanting to pull my trans for a rebuild. Grind on the 1-2 shift if I'm over 3k rpm. Synchros I'd guess but the rest of the trans is rock solid. Scott
07-04-2018, 8:15pm | #5 | ||||||
Gameroom Barn Bucks: $1005893
The clean up always takes more time than anything
07-04-2018, 8:17pm | #6 | ||||||
Lots of picture to post
Good luck, hope nothing is worse than expected |
07-04-2018, 8:30pm | #7 | ||||||
07-05-2018, 3:26am | #8 | ||||||
Gameroom Barn Bucks: $1232517
will be watching!
07-06-2018, 3:56pm | #9 | ||||||
So there is a tranny under that muck ! I may let RK rebuild the torque tube too.
The Following 4 Users Say Thank You to VatorMan For This Useful Post: |
07-06-2018, 4:50pm | #10 | |||||||
I've also used Rodney at RPM but shipping is a bugger. Scott
07-06-2018, 5:48pm | #11 | ||||||
If the rules allow it, put in an ECS u-joint torque tube replacement and never worry about replacing it again
07-06-2018, 7:47pm | #12 | ||||||
This is a reliable setup. I thought about the LG rubber bushing replacement, but word has it , it transfers hella noise. I’m going to use polyurethane bushings.
07-07-2018, 2:07pm | #13 | ||||||
So dropped the trans/diff/torque tube off at the builder. He tore it apart so he could see what was needed.
I need a new 3rd,4th and 5th gear. He showed me why it would slip out of 3rd occasionally. The last pic, look at the steel keepers. You’ll see one that is missing. He’s also going to weld a bung at the front of the trans for a Doug Rippie trans cooler that I’ll install this winter. Torque tube had one bad bearing- everything is going to be replaced plus install a new slave cylinder with bleeder. I’m also buying a lightweight flywheel and a Mantis dual clutch. Needless to say I’m a lot poorer now. |
07-07-2018, 3:47pm | #14 | ||||||
VB Dad of the Year
07-07-2018, 5:36pm | #15 | ||||||
07-07-2018, 6:56pm | #16 | ||||||
VB Dad of the Year
Nice Max Jax.
07-07-2018, 6:57pm | #17 | ||||||
VB Dad of the Year
07-07-2018, 7:02pm | #18 | ||||||
So here is what your differential looks like. And those cool looking grooves in the case ? Yeah, not so cool. Cause by a broken spring.
07-07-2018, 7:04pm | #19 | ||||||
Whoops ! Wrong first pic.
07-07-2018, 7:23pm | #20 | ||||||
Barn Stall Owner #2112
Gameroom Barn Bucks: $3043611
