01-17-2010, 6:35pm | #1 | ||||||
Gameroom Barn Bucks: $2827
Pfadt Inverted Shocks
I ordered a set of Pfadt Inverted Adjustable Shocks from Chip (CCA) as my X-mas present. I was a little bored this afternoon so I started to install them. I got the passenger side front installed in about a hour. I'm waiting for the PB Blaster to soak in on the drivers side before I try to break that top shock nut loose.
Front install .. before and after. Bling Bling: Before: Installed
2008 C6 Z06 Last edited by Lowcash; 01-17-2010 at 8:29pm. |
01-17-2010, 6:37pm | #2 | ||||||
SUWEET!!!!!
But I think it's upside down. |
01-17-2010, 7:18pm | #3 | ||||||
Believe me I double and triple checked.
2008 C6 Z06 |
01-17-2010, 8:26pm | #4 | ||||||
Front driver side complete. Will work on the rear set tomorrow.
2008 C6 Z06 |
01-18-2010, 9:35am | #5 | ||||||
Looking good Sean!
01-18-2010, 4:21pm | #6 | ||||||
All 4 corners done and set to 6 clicks. Will take it out tomorrow afternoon to settle it back down then schedule an alignment later this week or next.
I'm glad I worked on Kevin's shocks last year. It really pays off knowing what needs to be taken apart and what doesn't.
2008 C6 Z06 |
01-18-2010, 5:24pm | #7 | ||||||
If you didn't drop the spindle, you don't need to have it aligned again. Unless it was needing it before.
Make sure you tell us how she handles now.
01-18-2010, 6:03pm | #8 | |||||||
I don't think I've ever had the car aligned. I also turned down the rear bolts (front bolts didn't want to play nice after soaking in PB Blaster), so I figure why not get it aligned to Pfadt street specs.
2008 C6 Z06 |
01-18-2010, 6:07pm | #9 | |||||||
BTW: If you're thinking of washing/polishing/sealing/waxing your car and want to practice on mine - I'll make the sacrifice. |
01-18-2010, 7:36pm | #10 | |||||||
Always willing to be the 'test rat'. Well, that guy down south with the 'ol black car' did an AWESOME job wetsanding and polishing my car. All I have to do is white pad its once every 2 weeks to get the towel streaks out. BTW: I cleaned the wheel wells and polished the rims while the car was on jackstands. ~30 minutes per rim makes a big difference!
2008 C6 Z06 |
01-18-2010, 11:18pm | #11 | ||||||
Charter Member - Vendor
Gameroom Barn Bucks: $807
Look'n good Sean
How's the carpet coming Peace Chip |
01-19-2010, 10:11am | #12 | ||||||
Still sitting in the box in the corner of my garage.
2008 C6 Z06 |
