10-21-2018, 8:32pm | #1 | ||||||
Gameroom Barn Bucks: $1524159
Heat Shrink Self-Solder Butt Splice Connectors
Need to get a few of these.
The Following 5 Users Say Thank You to Wathen1955 For This Useful Post: |
10-21-2018, 9:33pm | #2 | ||||||
Banned
Gameroom Barn Bucks: $4469
10-21-2018, 9:56pm | #3 | ||||||
Gameroom Barn Bucks: $2214590
In the late 70s I worked for Raychem, the company that invented heat-shrinkable tubing.
10-21-2018, 10:29pm | #4 | ||||||
Barn Stall Owner #5150
We use those for some repairs out in the shop. Work pretty good.
10-22-2018, 12:02am | #5 | ||||||
Barn Stall Owner #16A
Gameroom Barn Bucks: $602908
Very cool.
10-22-2018, 2:04am | #6 | ||||||
I seen them tricks before, but being an old ET from over 1/2 a century ago, just WHAT and HOW does that work,?? I have always used TV/Radio/Electronic solder with flux that allowed the metals to anneal and essentially form one solid connection, BUT that required about 600f heat and my iron rated at 800f tip temp.....witch is FAR above the melting point of any plastic I ever heard of.....
Can someone esplain just specifically how this works??? |
10-22-2018, 5:47am | #7 | ||||||
Pretty good discussion about them over here: https://www.jalopyjournal.com/forum/...#post-12788043.
Biggest complaint was no mechanical connection, but people that use them seem to be happy with them. |
10-22-2018, 5:48am | #8 | |||||||
10-22-2018, 5:49am | #9 | ||||||
Barn Stall Owner #122
Gameroom Barn Bucks: $1158963
10-22-2018, 7:06am | #10 | ||||||
Barn Stall Owner #69
Gameroom Barn Bucks: $1084134
This looks great!!
10-22-2018, 7:19am | #11 | |||||||
never heard of any metal melting at the temps plastic will survive at....much less anneal.... so just what is that lo temp 'solder' composed of?? |
10-22-2018, 7:28am | #12 | |||||||
10-22-2018, 7:37am | #13 | |||||||
https://www.amazon.com/Melting-Point.../dp/B001QUXA8M |
10-22-2018, 12:10pm | #14 | |||||||
so it makes me wonder about corrosion, but with that jacket around it, I don't suppose it would matter..... interesting..... |
10-22-2018, 2:12pm | #15 | ||||||
@aerovette could use these for his master skillz
The Following User Says Thank You to Rob For This Useful Post: |
10-22-2018, 2:32pm | #16 | ||||||
2016 Election Expert
Barn Stall Owner #64
A place I worked at in the 80's and early 90's was a military contractor primarily making electronic sub-assemblies and all sorts of wiring/cabling like harnesses for jet fighters, Space Shuttle, nuclear subs, you get the idea. We used these things on quite a few cables, not typically the most high-end ones but quite a few. I learned that teflon insulation is good, silver-coated copper stranded wire is very good, shielded twisted pair is good, and all solder joints must be inspected and electrical tested. Finished cables and assemblies were all tested for continuity and high-voltage leakage, sometimes put on a shaker table, sometimes under water.
I kinda took for granted all the access I had to cool stuff and when I left I found out that gathering together a nicely stocked collection of goodies like that doesn't come cheap. |
10-22-2018, 2:37pm | #17 | ||||||
They have their applications. We had some versions of these that also had some sticky stuff inside the sleeve that would make it a water proof connection all in one go. Most of the typical uses for these were for pigtails. Imagine you want to terminate the shielding of several cables to a common ground point. You'd strip the shield to expose about a 1/4" of shield braid, put one of these on the cable over the bare shield and also a 18 gauge wire (for instance) and melt the thing, and instant pigtail. IIRC you could order these special for just that very purpose - pigtail included - and it made for a very nice shield termination. Also you had to use the concentrator tips on the heat guns to melt these guys, IIRC the temps were similar to what we used in normal soldering - it was real solder, not something low-temp.
10-22-2018, 2:40pm | #18 | ||||||
10-22-2018, 3:26pm | #19 | ||||||
Banned
10-22-2018, 4:02pm | #20 | ||||||
Yes. Very close because it freezes somewhere close to -40
This is my signature |
