Old 08-03-2022, 12:00pm   #1
aerovette
Barn Stall Owner #7734
Points: 74,662, Level: 100
aerovette's Avatar
Location: It's insulting when liberals think we're as stupid as they are.
Default Media room question
Believe it or not, sometimes even MY electronic/electrical expertise is challenged
I have a media room upstairs that has a TV for regular viewing, and a projector for movies.
My amp for surround is typical with multiple HDMI inputs and a signal output.
My problem is this...with one output on the receiver, I can run the cable box in, the BluRay in, or Game console in and then the output to the TV. I can't get an output to the projector though, unless I physically unplug one cable and plug another in.
I don't think hubs work in reverse. They are usually multiple in and single out just like the receiver. I need on in and two out so I can decide which device (TV or Projector) gets the signal.
Any ideas?
aerovette is offline   Reply With Quote
Old 08-03-2022, 12:03pm   #2
DJ_Critterus
Stall Owner #1120.2520
Points: 85,860, Level: 100
Activity: 99.4%
DJ_Critterus's Avatar
it's called a hub...
https://www.amazon.com/s?k=hdmi+spli...ref=nb_sb_noss
The 2nd device listed (TEKNET) will probably work best for you.
DJ_Critterus is offline   Reply With Quote
The Following User Says Thank You to DJ_Critterus For This Useful Post:
Old 08-03-2022, 12:08pm   #3
Mick
Points: 10,504, Level: 70
Activity: 43.5%
Mick's Avatar
Gameroom Barn Bucks: $12721
How is the engine stand set up?
Mick is offline   Reply With Quote
The Following 2 Users Say Thank You to Mick For This Useful Post:
Old 08-03-2022, 6:53pm   #4
IrishSpuds
Points: 4,531, Level: 45
Activity: 8.3%
IrishSpuds's Avatar
Gameroom Barn Bucks: $1604
ARC return.
IrishSpuds is offline   Reply With Quote
Old 08-03-2022, 7:14pm   #5
Stevedore
Points: 12,776, Level: 78
Activity: 6.9%
Stevedore's Avatar
Gameroom Barn Bucks: $406058
A simple HDMI splitter should work. And you'd only need ARC if the audio source is from within the projector or the TV. I think.
Stevedore is offline   Reply With Quote
Old 08-03-2022, 7:45pm   #6
MadInNc
Points: 118,981, Level: 100
MadInNc's Avatar
Paging @kingpin
MadInNc is offline   Reply With Quote
The Following User Says Thank You to MadInNc For This Useful Post:
Old 08-03-2022, 9:44pm   #7
ratflinger
Barn Stall Owner #THX1138
Points: 11,950, Level: 75
Activity: 51.1%
ratflinger's Avatar
Gameroom Barn Bucks: $1322
Get a better receiver then. One with 4 or 5 inputs
ratflinger is offline   Reply With Quote
Old 08-03-2022, 9:52pm   #8
aerovette
aerovette's Avatar
Why? How does that solve the problem?
Old 08-04-2022, 9:14pm   #9
Thunder22
Points: 15,884, Level: 86
Activity: 26.1%
Thunder22's Avatar
Gameroom Barn Bucks: $216475
RIF.... he needs 2 outputs, already has multiple inputs.
Thunder22 is offline   Reply With Quote
Old 08-04-2022, 9:35pm   #10
ratflinger
Activity: 51.1%
ratflinger's Avatar
Negasonic Teenage Warhead: Okay, you’ve got me in a box here.
Old 08-04-2022, 10:19pm   #11
aerovette
aerovette's Avatar
I have a solution (thanks DJ). It is a splitter for mirroring two monitors. In my case the same signal will go to the TV and the projector. I just choose which one to power on and watch it. The other mirrored signal will go to the device that is turned off.
Old 08-05-2022, 1:44pm   #12
theandies
Points: 3,190, Level: 36
Activity: 17.6%
theandies's Avatar
I use an HDMI switch box. One input and multiple outputs. There are manual ones that you have to switch, one's with remotes and one that detects what's feeding it and switches automatically. This might work as it has two inputs and multiple outs.
Example:
https://www.amazon.com/ZAMO-Switcher...ps%2C66&sr=8-8
【HDMI Switch 2 in 4 out HDCP 2.2】avedio links hdmi 2 input 4 output 2X4 switcher splitter can easily streams video and audio from 2 HDMI devices to 4 HDMI display simultaneously .Supports HDCP 2.2 protocol compliant HDMI 2.0(Note: The four HDMI output ports can only display the same screen and split display is not supported.)
【Vedio &Audio】4K HDMI Switch Selector box supports up to Ultra HD [email protected] resolution RGB/YUV 4:4:4 .,[email protected],Full HD 1080P,720P,3D, HDMI 2.0, It also supports 3.5mm and SPDIF audio output.
【Wide Compatibility】 avedio links 2x4 HDMI switch box compatible with computer, Blu-ray player, DVD player, AV receiver, Roku streaming media player, TV Box, Play Station 3/4, PS5, Xbox One/360 or other HDMI compatible devices to your Ultra 4K TV (UHD TV), HDTV, monitor, display or projector with a big screen.
【Features】DOWNSCALING:avedio links HDMI switch 2 in 4 out can output 4k and 1080p at the same time.HDR 10: Help you enjoy a vivid visual world! All ZAMO products are backed by our 12-Month Product Warranty and you will always get friendly support.
【Plug and Play】 This 4K HDMI Switch is easy to set up and operate, just power it with AC adapter and connect your HDMI devices to enjoy! TWO-WAY SWITCH:Supports manual select input sources through a built-in button or use of IR remote controller without having to get up from your seat.
theandies is offline   Reply With Quote
The Following User Says Thank You to theandies For This Useful Post:
Old 08-06-2022, 6:49pm   #13
Thunder22
Activity: 26.1%
Thunder22's Avatar
just a heads up for when you're ready to replace your avr - my yamaha 7850 has 2 HDMI outputs.
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
