05-25-2023, 4:56pm | #21 | ||||||
05-25-2023, 4:57pm | #22 | |||||||
Here you go: https://tighttorque.com/trucks/ford/f150-13 |
05-25-2023, 5:00pm | #23 | ||||||
Barn Stall Owner #118
Gameroom Barn Bucks: $1002672
I remember back in the Army helping the shop torque down the Jesus nut on a Huey at 700ft lbs.
Had a torque wrench about 3 1/2 ft long. Got a payloader and raised the bucket. Slowly moved towards the wrench and then pushed until it popped. |
05-25-2023, 6:46pm | #24 | |||||||
Gameroom Barn Bucks: $56446
https://tighttorque.com/trucks/ford/f150-11 |
The Following User Says Thank You to ptindall For This Useful Post: |
05-25-2023, 6:49pm | #25 | ||||||
05-25-2023, 6:51pm | #26 | |||||||
VB Dad of the Year
05-25-2023, 7:26pm | #27 | ||||||
We need to torque things really tight in the heavy equipment trade. Our shop uses something called a torque multiplier to extend the range of an average torque wrench. Perhaps you can find one at reasonable cost.
05-25-2023, 7:41pm | #28 | ||||||
Barn Stall Owner #122
Gameroom Barn Bucks: $1158963
I’ve watched guys at the track in Porsches torque the rear axle nut with humongous wrenches-said it was 400 ft/lbs.
05-25-2023, 8:33pm | #29 | |||||||
Barn Stall Owner #747-400
05-25-2023, 9:20pm | #30 | ||||||
05-25-2023, 9:22pm | #31 | |||||||
05-25-2023, 9:38pm | #32 | ||||||
05-26-2023, 5:50am | #33 | ||||||
Gameroom Barn Bucks: $530
When I had a 2001 Excursion I went to change the pads and rotors and then saw the caliper bolt torque spec ----- 274 ft lb I said **** that
05-26-2023, 6:14am | #34 | ||||||
Y'all who buy these giant vehicles, what did you expect?
05-26-2023, 7:48am | #35 | ||||||
05-26-2023, 8:15am | #36 | ||||||
05-26-2023, 8:58am | #37 | |||||||
SOME Real Barner
Gameroom Barn Bucks: $2034428
This is the correct answer; and is a very common tool. Some parts houses loan these out. I've seen el-cheap-0's sell for less than $50., and will torque down to 4800nm/3400lbs. |
05-26-2023, 9:21am | #38 | ||||||
05-26-2023, 9:54am | #39 | |||||||
It's 75 lb-ft for a 4wd and 25 lb-ft for a 2wd https://ford-specs.com/cars/2004/f15...pecs_front.php FRONT SHOCK ABSORBER INSTALLATION To replace the front shocks on an f150 you will first need to remove the nuts on the top of the shock. This can be accessed from under the hood of the vehicle or by the side with a wrench. The next bolt to remove is the lower bolt that runs through the lower control arm. Once removed the shock can then be removed from the vehicle. The new shock can then be moved back into the vehicle the same way the old one came out. Once the new shock is installed you can then start installing the bolts and nuts. The upper nut can be installed the same way that it had been removed and should be torqued to 40 ft-lbs. The lower bolt may need to be aligned and pounded back into place. If you must hammer on the bolt be sure not to ruin the threads, once the bolt is through it can be torqued to 25 ft-lbs if the vehicle is 2WD or 75 ft-lbs if 4WD. f150 Front Shock Upper Nut Torque Spec : 40 ft-lbs f150 Front Shock Lower Bolt Torque Spec(2WD): 25 ft-lbs f150 Front Shock Lower Bolt Torque Spec (4WD): 75 ft-lbs |
05-26-2023, 10:23am | #40 | ||||||||
https://ford-specs.com/cars/2005/f15...pecs_front.php Quote:
