Old 02-18-2020, 7:49pm   #41
JRD77VET
NCM Supporter '16,'17,'19,'20
Points: 115,957, Level: 100
Activity: 13.3%
JRD77VET's Avatar
Originally Posted by Mr.Bigg View Post
Then you could lub the bendix with a small copper tube as well. Just pull a starter bolt and bend the tube as needed.
To jump the solinoid turn the key on then connect the big nuts on either side. Use something heavy duty, pliers handles work well. It will burn them a bit if not your battery is to low,
Edit make damn sure it is in neutral.
The older farmer Howard lost his life a few years ago when he reached up to start the tractor. It was in gear and ran him over
I miss my friend Howard
The Following 2 Users Say Thank You to JRD77VET For This Useful Post:
Old 02-18-2020, 9:39pm   #42
Rikki Z-06
Barn Stall Owner #747-400
Points: 78,264, Level: 100
Activity: 18.7%
Rikki Z-06's Avatar
I lost my Uncle this way.
Rikki Z-06 is online now   Reply With Quote
The Following User Says Thank You to Rikki Z-06 For This Useful Post:
Old 02-18-2020, 11:18pm   #43
MEANZ06
Points: 46,195, Level: 100
Activity: 0.8%
MEANZ06's Avatar
Gameroom Barn Bucks: $4635916
You said this all happend after jumping it. This sounds like it could be low voltage to the starter.
Edit just watched the video. Looks like a easy fix either way.
It's quite obvious when you can reach the starter key standing next to a tire that's as tall your as your shoulders, so I/we have never attempted messed starting it form the ground, I or my wife are on the tractor before it's even attempted to start...
Thank you for pointing this out! Sorry for the losses
MEANZ06 is offline   Reply With Quote
