Old 05-28-2023, 9:21pm   #21
Taurus
Points: 27,673, Level: 100
Activity: 44.8%
Taurus's Avatar
Gameroom Barn Bucks: $3895593
Nice, you'll see the same on mine as I pulled the smog stuff off it as well. I still have the OEM smog parts and carb if I ever decided to go back to all stock. Even if I ever sold it I would do it as is and give them he stock parts to do as they want.
Can't imagine ever selling it though, it was a bucket list car for me from my younger days. A red on black 78 or 79 L82, just always what I lusted for in my earlier days when these things were sitting new on car lots.
Taurus is offline   Reply With Quote
Old 05-28-2023, 9:23pm   #22
Yadkin
Points: 31,310, Level: 100
Activity: 99.8%
Yadkin's Avatar
This was one of my most practical mods. After getting stuck (with my wife in the car) due to a burned fusible link, I built a main fuse panel that could be serviced on the road with just two tools and extra fuses.
Yadkin is online now   Reply With Quote
Old 05-28-2023, 9:26pm   #23
Yadkin
Activity: 99.8%
Yadkin's Avatar
Mine was a barn find in a house that I was fixing. I kept it for three years, fixed everything on it that was broken, made some practical, tasteful mods, detailed the hell out of it and sold it. I actually made a little bit on the project.
Old 05-28-2023, 9:26pm   #24
Taurus
Activity: 44.8%
Taurus's Avatar
I've thought about that as well, seems like a good idea. Along those lines, the other thing I did was install a back up hood release for the same reason, they are a bear to open when it breaks and with my luck it would would happen trying to leave a car show.
The Following User Says Thank You to Taurus For This Useful Post:
Old 05-28-2023, 9:30pm   #25
Taurus
Activity: 44.8%
Taurus's Avatar
Mine sat in a storage unit in Orlando for between 24 and 26 years depending on who you listen to. I spent many hours and dollars getting it back on the road while trying to keep it original as much as possible. Had to replace all the brakes, all rubber parts including hoses, belts and bushings, convert it to R134A Freon and of course do tires and a fuel and cooling system flush and rebuild.
Low mileage does not equal low maintenance.
Old 05-28-2023, 9:33pm   #26
Yadkin
Activity: 99.8%
Yadkin's Avatar
Here's the wiring diagram for that mod. This also includes a relay harness for the headlights. That eliminates a huge resistance loss in the headlamp switch, making OE headlamps brighter. I converted the low beams (actually lo-hi beams) to Hella Euro-spec lamps. They fit right in but are higher wattage. The relay harness is designed to handle the additional wattage.
Old 05-28-2023, 9:34pm   #27
Taurus
Activity: 44.8%
Taurus's Avatar
Looks doable, thanks.
Old 05-28-2023, 9:36pm   #28
Yadkin
Activity: 99.8%
Yadkin's Avatar
Yours looks like an engine out detail. Much nicer than mine, which was on a budget. I had to do all that stuff as well, including a new radiator and AC compressor, orifice and condenser.
Old 05-28-2023, 9:40pm   #29
Yadkin
Activity: 99.8%
Yadkin's Avatar
Here's a view showing the circuit breakers for the headlamps. I can't find a picture of the relays, but I mounted them on the driver's side close to the hood hinge. You really had to look had to notice them.
The Following User Says Thank You to Yadkin For This Useful Post:
Old 05-29-2023, 10:06am   #30
GTOguy
Points: 25,509, Level: 100
Activity: 95.8%
GTOguy's Avatar
Some very clean and slow C3's. Used to hate them, now they are classics. Nice engine bays and detail work on both cars.
GTOguy is online now   Reply With Quote
Old 05-29-2023, 10:19am   #31
Points: 128,417, Level: 100
I love the C3's. All of them up to '77. I didn't like when they got rid of the flat vertical back window in favor of the bubble.
My 1st car was almost a '74 silver coupe. I could afford the car but not the insurance.
I did eventually get a '71 ragtop. One day maybe I'll have another C3. It is the only corvette generation I would be interested in at his point.
LATB is offline   Reply With Quote
The Following User Says Thank You to LATB For This Useful Post:
Copyright © 2009 - 2023 The Vette Barn
