11-11-2021, 2:34pm | #1 | ||||||
Engine rough as hell......
Timing in range....but VERY rough idle....all 8 seem to be firing.....the same, butttttt the fuel is good pressure, LT-1 engine with HEI up top in back....
so roller block, 1.6 roller rockers.....thought they all adjusted right but hoo nose?? SO how to adjust roller cam?? keeping an insane mess to a min..... no unusual valve train noises.... any hints anyone??? |
11-11-2021, 2:51pm | #2 | ||||||
Moderator
Gameroom Barn Bucks: $988270
Vacuum leak somewhere?
11-11-2021, 3:10pm | #3 | ||||||
Seriously doubt it, thing is, the idle is more or less, 'normal' speed, not like 2+
it's lo enough that I can feel the weird firing and wonder about valves adjustments......one other thing, when I tore it down I did not keep the roller lifters in order, the got mixed up when cleaned......same with roller rockers 1.6 ratio..... |
11-11-2021, 3:34pm | #4 |
exhaust opening = adjust intake
Intake closing = adjust exhaust Do this for each cylinder and do it in order so you don't get anything mixed up. We've already gone over this in past threads |
11-11-2021, 5:21pm | #5 | |||||||
thing is, I wonder about the adjustments on clearances..... |
11-11-2021, 8:18pm | #6 | |||||||
I wonder if you either have spring bind or have bent a valve or several because the increased lift made them kiss the pistons. EDIT: Are the new rockers solid rollers or hydraulic, and what were the old ones? |
11-11-2021, 8:59pm | #7 | |||||||
Barn Stall Owner #1962
Gameroom Barn Bucks: $251407
The Following User Says Thank You to Oh-yaa For This Useful Post: |
11-12-2021, 5:41am | #8 | ||||||
Same rollers lifters and roller 1.6 rockers as before.....same cam even....they used to run smooth and well before the gasket failures....but like I said, they not all in the same spots they were before....the valve train does not make noise like it was loose.....
11-12-2021, 8:57am | #9 | |
11-12-2021, 9:10am | #10 | |||||||
so the only trick is, now that the lifters are full of oil, I wonder if they forcing the valves too much open,....in other words....back off the adjustments say 1/2 a turn lovely....pull all the crap outta the way to get the damn covers off.... GRRRRR.....at least I got some arthrongus pills to kill the worst of my pains in the shoulders and hands.... |
11-12-2021, 9:12am | #11 | |
11-12-2021, 1:42pm | #12 | |||||||
11-12-2021, 2:04pm | #13 | |
11-12-2021, 6:21pm | #14 | |||||||
but I put a hose clamp over the pipe to limit the leaking/noise and drove a few blocks ......now to handle the ignition system.....engine smoothed out a LOT from burning off all the oil from machine/assy.....but I note the temp is normal, in spite of the silly gauge on the dash....going by my IR gun.....which is super accurate over the years.....proven..... NOT that the engine runs really gross or anything, just not PURRfect, yet.... need trace out some dizzy wiring yet......HATE my memory.....PITA.... |
The Following 2 Users Say Thank You to mrvette For This Useful Post: |
