Old 02-07-2011, 12:11pm   #1
vette758702
Points: 1,251, Level: 20
vette758702's Avatar
Gameroom Barn Bucks: $795
Default Considering a mod... thought ?
I've been toying with an idea... I know where I can get a clam shell cheap. I'm thinking about buying it and cutting along the inside of the center scoop enough to add material and raise it about 1 inch giving it a very slight custom job look. I don't need to do this for clearance, but I do love body work.
This subtle of a change shouldn't make the front end to bulky looking or change the body lines of the car. Anyone else done anything similar or have thoughts?
vette758702 is offline   Reply With Quote
Old 02-07-2011, 12:13pm   #2
Frizlefrak
Barn Stall Owner #46
Points: 38,732, Level: 100
Activity: 1.0%
Frizlefrak's Avatar
Gameroom Barn Bucks: $4309769
Hmmmm.....can you photoshop it to give us an idea of how you want it to look?
Frizlefrak is offline   Reply With Quote
Old 02-07-2011, 12:16pm   #3
socalman
Barn Stall Owner #21
Points: 3,963, Level: 42
Activity: 1.3%
socalman's Avatar
Gameroom Barn Bucks: $850
Sounds like the existing double 'scoop' or raised area would now be one large flush area?
socalman is offline   Reply With Quote
Old 02-07-2011, 12:28pm   #4
vette758702
1) I wish I could photoshop, I'd have a better idea.
2) I'll try to be clearer... I wouldn't cut the front (nose end) of the scoop, I would simply cut down each side and raise the windshield end up one inch... a gradual taper to the front end.
***only raising the original "scoop" center section.
Old 02-07-2011, 12:31pm   #5
socalman
Activity: 1.3%
socalman's Avatar
clear as mud
Old 02-07-2011, 12:37pm   #6
vette758702
Just stole a pic off ebay and tried to explain my though on it. The black line is where I would cut. Then add material tapering the center raising it up 1inch at the windshield. Giving it a cowl induction hood scoop look but with the factory hood center line down the scoop instead of flat like the cowl induction.
Hopefully the "mud" is a little clearer.. hahah
Old 02-07-2011, 1:30pm   #7
socalman
Activity: 1.3%
socalman's Avatar
Yep, it's getting clearer. Basically raising the 2 existing 'humps' 1" higher than stock, making them more pronounced? I like the idea.
Old 02-07-2011, 2:42pm   #8
Frizlefrak
Activity: 1.0%
Frizlefrak's Avatar
So do I. Do it!
