06-10-2023, 7:04am | #61 | ||||||
06-10-2023, 7:18am | #62 | ||||||
Does this have a moisture barrier underneath? What about insulation under the flooring deck?
06-10-2023, 7:45am | #63 | ||||||
Barn Stall Owner #14/32
Gameroom Barn Bucks: $4810
The Following 4 Users Say Thank You to Vandelay Industries For This Useful Post: |
06-10-2023, 8:12am | #64 | ||||||
Gameroom Barn Bucks: $2001216
Cool thread
06-10-2023, 8:16am | #65 | ||||||
The Following User Says Thank You to StaticCling For This Useful Post: |
06-10-2023, 8:18am | #66 | ||||||
The Following 2 Users Say Thank You to snide For This Useful Post: |
06-10-2023, 8:43am | #67 | |||||||
If you did so it would be best to have it on the ground not attached to the underside of the structure. Insulation is not a good idea for a building that is not conditioned (HVAC). It can create a dew point and mold that usually follows. [conversely an HVAC building that is not insulated can do the same] An exception would be closed cell spray foam. Done properly it seals the structure and leaves little to no room for trapped air between the wood and environment that can create the mold. (It also is a moisture barrier but that is getting deep into the weeds in this conversation) Disclaimer: I’m not an engineer or building scientist. But I have learned from engineers and building biologists and other specialists more than I want to know about this stuff. And I have spent a lifetime in this line of work. Including major mold remediation and repairs. If you spend any substantial amount of time taking structures apart it’s very obvious what was done wrong and what was done right. |
06-10-2023, 9:51am | #68 | ||||||
The Following User Says Thank You to 86RAG For This Useful Post: |
06-10-2023, 9:53am | #69 | ||||||
06-10-2023, 10:20am | #70 | |||||||
*engineer |
The Following User Says Thank You to TheRealBadger For This Useful Post: |
06-10-2023, 3:11pm | #71 | |||||||
Irony Deluxe |
06-10-2023, 6:18pm | #72 | ||||||
06-10-2023, 6:22pm | #73 | ||||||
I haven't seen the site. So you're building a bridge from your driveway to the shed floor?
06-10-2023, 6:23pm | #74 | ||||||
06-10-2023, 6:26pm | #75 | ||||||
You think the load on a shed is comparable to a railroad.
06-11-2023, 5:17am | #76 | ||||||
06-11-2023, 5:41am | #77 | ||||||
06-11-2023, 6:16am | #78 | ||||||
06-11-2023, 6:27am | #79 | |||||||
The reason why wood ties don't last is because high dynamic loads on busy lines. On little used branch lies, or storage yards ties last a very long time. I am greatly amused by your envy, and ignorance of all things technical. |
06-11-2023, 7:09am | #80 | ||||||
