09-03-2021, 3:45pm | #1 | ||||||
Iron Block, Aluminum heads....corrosion
A buddy stopped by to help this afternoon, dropped off an engine stand, going to pull short block 350 Sunday AM.....BUT he noted the cyl head gasket from the driver side.....it too was pulled to the machine shop.....
and noted corrosion on the old gasket, same as was on passenger side......but he never saw the gasket from pass side.... one glance and he swears I can NOT USE TAP WATER in the cooling system, has to be bought OTC at parts house......he learned this some 5 years ago he said.....I been using tap/well water for years, never an issue.....but this is the longest span with Aluminum heads and Iron block...... so going to pull the engine Sunday AM.....flip it over and see just HOW IN HELL the oil sump got full of water in about 15 minits after adding anti-freeze coolent, SO anyone ever heard of using just store bought premixed coolants in iron block/aluminum head engines??? |
09-03-2021, 3:56pm | #2 | ||||||
VB Dad of the Year
Your car is toast (and looks questionable). Just let it die and buy your wild live sex wife a new C8. You will thank me.
09-03-2021, 3:57pm | #3 | ||||||
I did it all the time in my C4.
09-03-2021, 4:02pm | #4 | ||||||
I’ve always used undiluted coolant and distilled water. Just did a coolant swap on the LT4 and used about 25% coolant with 75% distilled water since I live in a warm climate.
09-03-2021, 4:11pm | #5 | |||||||
IF that is true.....I don't recall ever hearing it.....lovely.... |
09-03-2021, 4:29pm | #6 | |||||||
Distilled can be nearly chemical H2O |
09-03-2021, 4:30pm | #7 | ||||||
The gasket should be a barrier for any dissimilar metal reaction. I'm not sure what you are seeing.
09-03-2021, 4:37pm | #8 | ||||||
Distilled only
09-03-2021, 4:45pm | #9 | ||||||
Distilled and water wetter in the race car because we can't use coolant. Distilled and coolant in the regular vehicles. Some weird crap in the F-250 Diesel.
In any case, no tap. Tap water has impurities in it that not only cause deposits, but the water is conductive, providing galvanic pathways. Also, the chemicals used to treat water can be acidic, further encouraging corrosion. Distilled water is cheap. I always have 5 - 10 gallons sitting around. |
09-03-2021, 5:04pm | #10 | ||||||
Barn Stall Owner #13
Gameroom Barn Bucks: $425244
I use distilled but I may consider switching to RO water instead. I’ve read several articles like the attached that say distilled can lead to issues with aluminum radiators. Industrially we do use molybdenum in our systems
https://www.hyperlube.com/blog/blog/...ooling-system/ |
09-03-2021, 5:33pm | #11 | |||||||
Here's the popular additive in race cars: https://www.redlineoil.com/waterwetter |
09-03-2021, 5:34pm | #12 | ||||||
VB Dad of the Year
Dude. Throw it away and buy a C8. You're welcome.
09-03-2021, 5:35pm | #13 | ||||||
09-03-2021, 6:10pm | #14 | ||||||
Dissimilar metals causing corrosion? Gene, you need to tack weld on a sacrificial anode....get one from the boat dealer.
....but seriously, stop being a cheapskate and put in half distilled water/half antifreeze, or just spend a little more and get the premixed version. |
09-03-2021, 6:26pm | #15 | ||||||
Distilled is preferred definitely, changing the coolant every couple years also a must.
Some well water is extremely full of minerals and ph way off which will cause problems. |
09-03-2021, 6:29pm | #16 | ||||||
The Following 2 Users Say Thank You to Bill For This Useful Post: |
09-03-2021, 6:32pm | #17 | ||||||
09-03-2021, 6:45pm | #18 | |
09-03-2021, 7:35pm | #19 | |||||||
so maybe Sunday AM or so we can have the short block out and flip it over to see WTF is with the underside.....Thing is engine ran fine/smooth without any coolent for maybe 30 seconds in the garage.....my friend thinks to get that intake checked out.....for cracks as it's a custom intake....but no way in HELL water gets into any oil passage/air fuel even..... |
09-03-2021, 8:04pm | #20 | ||||||
Gameroom Barn Bucks: $311064
