03-11-2023, 1:43pm | #41 | ||||||
So what exactly was the issue with battery you installed, non agm?
Does it have start/stop bullshit on it as heard its almost a requirement for agm if has that on most vehicles. New cars suck... Give me AC and disc brakes and I'll drive a 50s instead. |
03-11-2023, 1:49pm | #42 | |||||||
Same size and specs as the Porsche "rated" battery. https://www.oreillyauto.com/detail/c...?q=94rh7&pos=2 Only issue was that the steering angle sensor would not initialize. "Rated" was the term that the dealer tech used. My guess, a chip sold by Porsche to battery makers to make more profit.... |
03-11-2023, 1:53pm | #43 | ||||||
I took the O's battery back and explained their error. They gave me cash, including the $22 core charge and tax, and promised to contact corporate so it doesn't happen to some other bloke.
Great company- always has been |
03-11-2023, 2:29pm | #44 | |||||||
Gameroom Barn Bucks: $3694
And lets be honest, most Porsches have low miles, hence low repairs. And their customer service is the best, period. 2005 Era Carerra GTs camshafts being replaced for free due to pitting. 991 era GT3s had a cylinder issue. All were replaced with new warranties, at Porsches expense. Even if you didnt have the problem. |
03-11-2023, 2:33pm | #45 | ||||||
German cars had proprietary IT stuff going on when I worked on them over 25 years ago. Its like there was a time delay fuse in every one. At about 85,000 miles, they systematically start to fall apart. Starting with the electrical system, and then oiling and cooling. Pretty much every German car made after 1970 has this mantra if water cooled. I remember 30 years ago installing two radiator hoses on a VW Vanagon. the parts cost THEN was $215. Older German cars and motorcycles that are air cooled will run virtually forever with normal maintenance and overhauls. They aren't disposable appliances like all their latest stuff.
03-11-2023, 2:40pm | #46 | |||||||
Did ya do same for yours with the "O" battery? |
03-11-2023, 2:59pm | #47 | |||||||
I haven't experienced that at all in my Porsche. I just purchased the rubber components for my rear sway bar. All four can be purchased separately. Rock Auto had the links for $32 each. I had to buy the Bushings at an online dealer, and they were $12 each. When I rebuild the suspension I can buy all the parts separately or as kits for each wheel. I expect to do that at about 100k miles like I did on my daughter's S197 Mustang, twice. That car is approaching 200k miles and I expect the engine (made in Cologne, Germany) to last 350k or so. You got this thing about the air cooled Porsches that is clouding your judgement. Water cooled allows tighter tolerances and thus better longevity. Modern engines have better control of temperatures and generally run higher oil pressure than back in the day. Oils are better, more consistency and in many cases lower viscosity, therefore higher rates of flow and heat dissipation. The Pentastar Engine in my Jeep had the exhaust manifold cast into the head, and the manifold water cooled. That heats up the coolant much faster and as you know, most engine wear occurs during cold starts. Mine was running perfectly when I sold it after 175k miles. The Audi engine in My Porsche is similar- cast-in-head and water cooled exhaust manifold. So of course I expect the same benefit. |
03-11-2023, 3:02pm | #48 | |||||||
I don't know if that would have helped though, being that I still would have registered the new battery. |
03-11-2023, 3:09pm | #49 | |||||||
03-11-2023, 3:22pm | #50 | ||||||
European cars are JUNK, especially the Kraut ones.......
NEVER buy a product from ANY nation in Europe.....lord knows China and Japan are bad enough...... and modern cars have WAY too mutch in he way of electronic OVER engineering..... |
03-11-2023, 3:32pm | #51 | ||||||
Gameroom Barn Bucks: $29012
When my buddy replaces our batteries, he hooks up something under the dash to maintain memory settings for everything
03-11-2023, 3:52pm | #52 | |||||||
Why couldnt a car do the same. |
03-11-2023, 4:09pm | #53 | ||||||
These 'keep alive' battery assisters are 9 volt batteries with a connector that plugs into the cigar lighter or nowadays, 'usb port'.
Mainly to keep the monitors set and the parameters of the computer saved so it doesn't have to re-learn the drive strategy. The Germans wanted to do proprietary ADAS stuff as well, but the industry would not let them. Automatic Driver Assistance System. These are the prescription windshields, camera rear view mirrors, camera lights and sensors, etc., all of which cost thousands and thousands of dollars and must be calibrated to provide the correct information. All a bunch of hogwash to de-sensitize the new driver and to decrease the amount of control and independence he has over his vehicle, with 100% automation the ultimate goal as we lose more and more freedoms. |
The Following 3 Users Say Thank You to GTOguy For This Useful Post: |
03-11-2023, 4:50pm | #54 | ||||||||
03-11-2023, 5:16pm | #55 | |||||||
Barn Stall Owner #116
Doesn't have a big thing
I only take issues with 911 owners who bash vetted. Then again, same amount of vette owners bash 911s. Drove a 911 at Xtreme Xperience at PBIR, car was perfect and very durable, as they were running it about 40 miles each hour for 9+ hours, for two days. |
03-11-2023, 5:34pm | #56 | ||||||
Hell, I'm so far out of this equation that I've been looking at '36 and '39-'40 Ford coupes lately. Haven't decided if it has to be a flathead, but am leaning that way. If not, maybe a nailhead Buick or Olds transplant, 50's-era correct. No automatic transmissions, no disc brakes, none of that nonsense. But multiple carbs and a Columbia 2 speed rear end, hell yes. I'm looking at spending more $$$ on an 85 year old POS than a new car would cost, simply because the new cars bore me to death.
03-11-2023, 9:39pm | #57 | |||||||
03-11-2023, 11:06pm | #58 | |||||||
Gameroom Barn Bucks: $1027436
The Following User Says Thank You to higgyburners For This Useful Post: |
03-12-2023, 7:35am | #59 | ||||||
Your writing skills, or lack thereof, puts your IQ well below average. Maybe you hit your head on too many low branches...
03-12-2023, 7:44am | #60 | |||||||
We did 1,600 miles in 4 days from the FL panhandle to the Smokies. 500 miles each day up and back, and 300 miles each day in the mountains. A memorable trip. |
