10-17-2021, 12:59pm | #1 | ||||||
2015 Sierra issues. Experts or smartasses welcome.
2015 Sierra Denali 120006 miles. I bought this used and occasionally I would get a P0307 code. I'd erase it and it would drive for months with no issue. Last night I went to dinner..' all good. I start the truck to leave and as I pull out I get a stabilitrak light and a flashing CEL. Reduced power and bad idle.
Today I: Disconnected the battery for a couple hours hoping for a miracle "reset" no luck. Swapped 1 and 7 coil, plug, and wire. No luck Observations: NO lifter tapping #7 plug was oily When no code is present, oil pressure is about 30. When stabilitrak light comes on, oil pressure increases to just over 40 and I can hear some sort of sound like air flowing or vacuum or something. When I clear the code, the sound goes away and the oil pressure goes back to 30. CEL comes on long after the Stabilitrak has been on a while. (minute or more) Only ONCE after I first swapped the plug, coil and wire, I got a cold rough idle code P050D V4/AFM does not engage. |
10-17-2021, 1:50pm | #2 | ||||||
Barn Stall Owner #1991
That's all I got. |
10-17-2021, 1:57pm | #3 | ||||||
Barn Stall Owner #2112
Gameroom Barn Bucks: $3043611
My jeep is throwing a thermostat code. I bought the OEM part from Rock Auto along with the sensor and 4 things of anti-freeze, and will have my mechanics fix it on Thursday. This is after I changed a right rear speed sensor. That should darken the dash. Edit: Too bad Gene didn't live closer. I'd have him do it. |
10-17-2021, 2:02pm | #4 | |||||||
Have you people never heard of electrical tape? |
10-17-2021, 2:32pm | #5 | ||||||
10-17-2021, 4:00pm | #6 | ||||||
Barn Stall Owner #THX1138
Gameroom Barn Bucks: $1322
A 2015 with 120k miles? I have a 2004 2500HD with only 70K - want to trade?
10-17-2021, 4:04pm | #7 | ||||||
[WEZzie]Shoulda bought a Silverado.[/WEZzie]
10-17-2021, 6:53pm | #8 | ||||||
That's about the same as on wife's 2001 250k miles Focus, twin cam engine.....no spark on #3 cyl.....so I bought a new sender unit....measured the coils on it, and going to compare to the one in the car tmrw AM......
10-17-2021, 7:10pm | #9 | |||||||
And don't forget to FOCUS !!!! |
10-18-2021, 6:39pm | #10 | ||||||
Gameroom Barn Bucks: $2106426
10-18-2021, 8:49pm | #11 | ||||||
Turned out to be a bad fuel injector. Whew. Expensive fix BUT at least the heads don't have to come off. That had me nervous.
The Following 3 Users Say Thank You to Aerovette For This Useful Post: |
10-18-2021, 9:37pm | #12 | ||||||
10-18-2021, 10:32pm | #13 | |||||||
Pull the fuel rail (under the intake) Remove all the injectors and replace with new Replace the rail Replace the intake. I most likely could have done it, but this work has a 30,000 mile, 3 year warranty parts AND labor. Let them have their fun with it. |
10-19-2021, 2:09am | #14 | ||||||
Yeah, works great, but I only use it for RED idiot lights. CEL is a dull yellow and doesn't need tape.
The deactivation device for AFM has a bright BLUE LED but it's down by the pedals and helps locate things dropped on the floor. Also not distracting enough to need tape. |
10-19-2021, 3:36am | #15 | ||||||
Found your problem:
2015 Sierra Denali |
10-19-2021, 8:45am | #16 | ||||||
10-19-2021, 9:05am | #17 | |
