06-14-2023, 6:26am | #121 | ||||||
06-14-2023, 7:30am | #122 | ||||||
06-14-2023, 11:03am | #123 | ||||||
Gameroom Barn Bucks: $12721
In your experience, did you get any that looked like this:
06-14-2023, 1:06pm | #124 | ||||||
I made a PT porch railing -- NO GROUND CONTACT -- that rotted apart in about 10 years.
06-14-2023, 1:56pm | #125 | ||||||
06-14-2023, 1:57pm | #126 | ||||||
06-14-2023, 1:59pm | #127 | ||||||
Stick frame. Basically this, but with everything 16" on center, not 24", and one door in front with no windows:https://howtospecialist.com/outdoor/...to-shed-plans/
The Following 4 Users Say Thank You to 86RAG For This Useful Post: |
06-14-2023, 4:18pm | #128 | |||||||
Barn Stall Owner #14/32
Gameroom Barn Bucks: $4810
The Following User Says Thank You to Vandelay Industries For This Useful Post: |
06-14-2023, 4:58pm | #129 | ||||||
06-14-2023, 5:03pm | #130 | |||||||
Gameroom Barn Bucks: $1008643
The Following User Says Thank You to sublime1996525 For This Useful Post: |
06-14-2023, 6:43pm | #131 | ||||||
06-14-2023, 7:33pm | #132 | ||||||
06-15-2023, 3:00pm | #133 | ||||||
Side walls done. I think I'll do the sheathing on them next before doing the roof
The Following 5 Users Say Thank You to 86RAG For This Useful Post: |
06-15-2023, 3:15pm | #134 | |||||||
I suggest: -run the sheathing horizontal (I assume plywood or OSB) -and allow the sheathing to span the wall and pony wall yet built to make the shed roof. (some would also do the 1/2 gable ends as well) |
06-15-2023, 3:38pm | #135 | |||||||
I'm using OSB, and not really sure what the advantage would be to run them horizontal vs. vertical. Plus, if I run them vertical I will have to pieces left after cutting in front door opening to make the doors with. And yes, the sheathing will overlap the pony wall as well as the gables. |
06-15-2023, 3:59pm | #136 | |||||||
But running the sheathing horizontal and staggered can help keep the studs from bowing crooked. We also block at the 4' line so the sheathing is nailed along all edges. We always have done it this way. It's a good habit to attach wood building materials perpendicular. I assume you will run the roof sheathing perpendicular to the framing. |
06-15-2023, 5:10pm | #137 | |||||||
[/QUOTE]We always have done it this way. It's a good habit to attach wood building materials perpendicular. I assume you will run the roof sheathing perpendicular to the framing.[/QUOTE] Yes, roofing will be plywood and running perpendicular Got any Tyvek you don't need? |
06-15-2023, 5:12pm | #138 | |||||||
I assume you will run the roof sheathing perpendicular to the framing.[/QUOTE] Yes, roofing will be plywood and running perpendicular Got any Tyvek you don't need? [/QUOTE] What are you planning for siding? |
06-15-2023, 6:12pm | #139 | ||||||
The Following User Says Thank You to 86RAG For This Useful Post: |
06-15-2023, 6:28pm | #140 | ||||||
