01-09-2022, 10:26pm | #1 | ||||||
Clothes dryer as heat source
I have an electric dryer and a cold garage. The dryer vent pipe is in the garage wall. I was thinking about putting in a diverter flap like a fireplace flue, that could redirect dryer vent heat to the garage, or go the normal path depending on how I set it. Anyone heat their garage with the dryer?
01-09-2022, 10:36pm | #2 | ||||||
You’ll also humidify your garage big time. Not a great idea.
The Following 9 Users Say Thank You to Steve_R For This Useful Post: |
01-09-2022, 10:45pm | #3 | ||||||
Gameroom Barn Bucks: $4635916
I tried it and it got warm but it was so humid it was hard to breath. Went with a propane heater, much better. Have a couple 100lbs tanks, simple set-up and works great. Now in the mountains I only use it as backup if the power goes out.
01-09-2022, 10:49pm | #4 | ||||||
Houston is always humid anyway, so I wonder if it will matter that much? Humidity here is always in the 80-95% range. Today it's 81%
01-09-2022, 10:53pm | #5 | ||||||
Big difference between 80% and 100%. It’ll condense on smooth surfaces. It’s surprising just how much moisture is in the dryer discharge air.
01-09-2022, 10:55pm | #6 | ||||||
Well crap. Free heat seemed a decent idea.
01-09-2022, 11:03pm | #7 | ||||||
01-09-2022, 11:16pm | #8 | ||||||
My set up, I made the cart to move it easily (the heater is designed to hook on a BBQ tank. I put together a 40' hose to keep the bigger tanks outside. If you light all three burners you'll be cooked out, It'll heat 1500sq ft no problem. With your electrical skills you can build one, you got this
01-09-2022, 11:32pm | #9 | ||||||
The Following 2 Users Say Thank You to Bill For This Useful Post: |
01-10-2022, 12:01am | #10 | ||||||
I've did it, trick is just don't put clothes in the dryer.
Works for when only need heat on occasion. Two or 3 space heaters work better, i usually don't use propane nor kero heaters especially in well sealed garage. |
01-10-2022, 12:16am | #11 | ||||||
Barn Stall Owner #THX1138
Gameroom Barn Bucks: $1322
Put a heat exchanger on it, might not be very efficient though.
01-10-2022, 1:38am | #12 | ||||||
No way. Unless you only plan on running it empty it's going to add a shit-ton of moisture to the area. It will rust the hell out of everything metal (tools/vehicles).
01-10-2022, 2:16am | #13 | |||||||
Barn Stall Owner #1991
The Following 4 Users Say Thank You to carlton_fritz For This Useful Post: |
01-10-2022, 5:29am | #14 | ||||||
Well, if you acclimate yourself to Summer temps by avoiding air conditioning anything less than about 80 degrees feels cold. Especially if there's a breeze. I worked in an ASTM testing laboratory for a few years where temperature and humidity was strictly controlled. Could sense when it was off by more than a single degree or two because it made me feel hot or cold. |
The Following 2 Users Say Thank You to Torqaholic For This Useful Post: |
01-10-2022, 8:51am | #15 | ||||||
Gameroom Barn Bucks: $2001216
I've seen some, use their ovens for heat in the hood?
01-10-2022, 9:27am | #16 | |
The Following 5 Users Say Thank You to DJ_Critterus For This Useful Post: |
01-10-2022, 11:21am | #17 | ||||||
01-10-2022, 11:27am | #18 | ||||||
I do a lot more cooking in the oven in the Winter months, and on extremely cold nights, I do like to cook things that take a long time, to heat up the house a bit. Hams, roasts, frozen lasagna, etc. I make a lot more often in the Winter.
01-10-2022, 1:05pm | #19 |
I make a lot more spaghetti sauce in the winter since i have to boil the tomatoes first. That really heats the place up.
01-10-2022, 1:34pm | #20 | ||||||
Not a good idea
