07-02-2021, 4:15pm | #1 | ||||||
Car batteries...'72 vette
amp meter says like .01 drain when still in the garage....but the battery life is marginal at best.....car ran fine yesterday....but DVM says when starting at the battery terminals....down to 5 volts.....something not right.....
but open circuit even with headlights on measures 12 or so.... anyone?? I think it's a bad battery but only some 2 years old Auto Zone.... |
07-02-2021, 4:18pm | #2 | ||||||
Gotta be aliens
07-02-2021, 4:42pm | #3 | ||||||
Barn Stall Owner #108
Gameroom Barn Bucks: $109844
I think that you answered your own question.
The Following User Says Thank You to Vegas For This Useful Post: |
07-02-2021, 4:47pm | #4 | ||||||
07-02-2021, 4:57pm | #5 | ||||||
Gameroom Barn Bucks: $406058
Assuming that you've checked the terminal cleanliness & tightness, I'd guess some sort of internal fault, break, failure, or whatever. I've had some strange behaviors out of car batteries in my years; when something just makes no sense, I tend to replace the battery. 2 years seems pretty young though.
The Following User Says Thank You to Stevedore For This Useful Post: |
07-02-2021, 5:20pm | #6 | ||||||
Goldilocks
Gameroom Barn Bucks: $1009320
It needs new tubes. Still got your suitcase from the 60's?
07-02-2021, 5:29pm | #7 | |||||||
07-02-2021, 5:40pm | #8 | ||||||
Barn Stall Owner #79
Gameroom Barn Bucks: $955
I had an Optima battery die a premature death because I didn't drive the car very often. Turns out some batteries just won't survive the discharge/recharge cycles associated with infrequent use. I replaced mine with a new Optima and keep it on the trickle charger any time the car is not in use. It's been several years and I've had no more problems.
How often do you drive your '72? |
07-02-2021, 6:26pm | #9 | |||||||
Anyone else with crappy newer battinators??? I suspect China junk.... |
07-02-2021, 6:30pm | #10 | |||||||
07-02-2021, 6:55pm | #11 | ||||||
Check the big cable at the starter. Make sure all those and the grounds are clean.
Does it have a ballast resistor or the famous GM fusible link? |
07-02-2021, 7:57pm | #12 | ||||||
07-03-2021, 2:08am | #13 | ||||||
Gameroom Barn Bucks: $1232517
That is why I put a battery cutoff switch. Slow drain.
07-03-2021, 9:09am | #14 | ||||||
SO, after messing with it yesterday, and putting charger on it, and measuring drain, and seeing it as just ten milliamps, computer injection memory storage, not likely an issue.....
so first thing this AM, I start the car as if nothing happened....WTF?? how in hell can a battery have an overnight failure like that and then recover by some miracle?? internal structual failure?? if so, how in HELL can it cure itself?? |
07-03-2021, 9:17am | #15 | |||||||
SOME Real Barner
Gameroom Barn Bucks: $2034428
It's bad connections....clean, inspect, tighten....battery, alternator, and starter. Properly diagnose after that is done. |
07-03-2021, 9:32am | #16 | |||||||
and what is with upon looking up at Auto Zone site, all their batteries are now TWO HUNDRED BUX???...... |
07-03-2021, 9:48am | #17 | ||||||
Why? There are only a few manufacturers of car batteries anyway. I believe the Duralast batteries are made by Johnson Controls, which are OEM on a lot of cars...they manufacture several other brands, including Interstate. Exide is the other company that manufacture car batteries.
The last Wal-Mart battery I had on my truck was manufactured by, you guessed it, Johnson Controls (the OEM battery was made by Johnson Controls as well) - I'm currently running a Duralast Gold, which replaced an Optima that went kaput after one year. |
The Following 2 Users Say Thank You to StaticCling For This Useful Post: |
07-03-2021, 9:49am | #18 | |||||||
07-03-2021, 10:31am | #19 | |||||||
Gameroom Barn Bucks: $2115673
07-03-2021, 11:25am | #20 | |||||||
SO I decided to take my cphone with me and go battinator shopping stopped into about 6 parts houses......and the cheapest battery of correct size was marked MARINE Deep cycle.....76 bux.....P24 size with good 1/4 inch studs on the top BUTTTTTT the 'more normal' auto batteries in anything approaching the correct size were 200 bux same size batt case....so go figger.....AND it is rare to find any battery with the studs on it for my wiring style.....except the marine batt.....go figger....whole damn shelf full of them 7' high and some 15' wide all them stupid batteries, not a dime worth of difference between them, and the same price too.....WTF??? |
