12-14-2017, 2:04pm | #1 | ||||||
For a MAGNET? Seriously? LOL
12-14-2017, 2:36pm | #2 | ||||||
How do those utility box lock "thingys" negate the effects of magnetism ?
12-14-2017, 3:01pm | #3 | ||||||
In their letter they stated that the tampering began after he became a customer.
He doesn't say how long he's been a customer, but if they've checked the reading more than twice, then they've not found it there before. So if he was using the magnet to alter his reading, then his usage should reflect that from the months that they didn't find a magnet to the time that they did. Since they've pulled the magnet, they should see an increase in usage now. Unless he puts another magnet out. Are they going to post a guard? I bet the reason that they say that tampering began after he became a customer is because his average usage hasn't changed. Also, the glass would have to be pulled and the magnet held next to the disk for it to alter a reading. Also, how does putting a couple of locks on the box stop the nefarious magnetism? Edit: He should sue for any stress related illnesses that they may have given him. Dude looks like he's about to pop a vein. |
12-14-2017, 3:09pm | #4 | ||||||
Barn Stall Owner #16A
Gameroom Barn Bucks: $602908
Any meter tampering will be found almost immediately.
There are larger meters servicing several addresses and the readings are compared to what left the power generating facility. If the sums of the individual residences don't add up to the sums of the regional meters, they go out to each individual meter and they find the culprit. |
12-14-2017, 3:11pm | #5 | ||||||
Gameroom Barn Bucks: $4614507
Hmmmm.....wonder if it works?
12-14-2017, 3:39pm | #6 | ||||||
12-14-2017, 4:00pm | #7 | ||||||
with our newest meter, they don't have to be right at the meter to read it; just drive by or pull into the driveway. The only reason to read it in-person is because something is suspected. The meter in his video looks like one of the newer ones.
12-14-2017, 4:18pm | #8 | |||||||
With my meter, no one does a damn thing. It uses cell towers to communicate the usage. |
12-14-2017, 4:23pm | #9 | ||||||
12-14-2017, 5:00pm | #10 | |||||||
No. We are. There was a fee to install them and $5.00 a month to have them...not that there is an option NOT to. The company I used to work for built the communications mini-stations that gathered neighborhood info and passed it along. Meter relays to Mini-Station relays to Utility company, all by cell. You can see relay boxes on some of the poles outside the subdivision. They have battery back up, insane encryption, neat boxes. About 5 feet tall and 3x3 footprint. https://en.wikipedia.org/wiki/Automatic_meter_reading |
12-14-2017, 5:07pm | #11 | ||||||
2016 Election Expert
Barn Stall Owner #64
I convert my electrons to photons just before they hit the meter, then convert them back to electrons before it hits my breaker box. As far as my meter is concerned, it's just really bright outside and my bill is ZERO! All you need is a couple of inexpensive E2P and P2E devices. Make sure you specify three-phase 220V/10 million lumens.
12-14-2017, 5:10pm | #12 | ||||||
12-14-2017, 5:36pm | #13 | |||||||
12-14-2017, 7:28pm | #14 | |||||||
Not sure about the modern smart meters, but the old disc type were nothing more than an induction motor. Coils build up a field that generates a counter field in the rotating disc, that causes the disc to turn. It is all calibrated and can be slowed by a magnet located beyond the glass bowl. Power company will have billing records for that address going back years, can see how that changed when he moved in, and again would notice a change when the magnet was applied. It should not be too difficult to estimate what the power bill should have been. I suspect paying back their estimated power consumption would be more agreeable than Civil Penalties. The thief probably is a net neutrality advocate, and thinks electric power too should be unmetered, as an essential utility for modern life unencumbered with consideration for how much is used. |
The Following User Says Thank You to Jasper711 For This Useful Post: |
12-15-2017, 3:28am | #15 | |||||||
He's a scrapper and there is a ton of various scrap metal in the whole area... sorted out according to the metal type- iron, aluminum, etc. He said he uses the magnet as a quick way of determining the type of metal he has collected. Says he just stuck the magnet on the side of the box as a convenient place to keep it. |
12-15-2017, 7:41am | #16 | |||||||
Barn Stall Owner #13
Gameroom Barn Bucks: $425244
It does, at least with the older meters
In the 80's my father was a firefighter and one of his co-workers lost his job due to meter tampering - he put a magnet inside the meter box to slow the meter down (I'm not an expert in how it works). Since this was a small town with it's own power company etc and they were all city employees, he was able to get a meter seal, illegally though, and reseal his meter box, so no one ever suspected anything. One day the neighborhood he lived in was having some unusual electrical issues, so the electrical crew was checking house to house to see if they could find anything and stumbled upon his magnet when they opened his meter box. He ended up having to resign in order to save his pension, otherwise he would have been fired. |
12-15-2017, 12:43pm | #17 | ||||||
12-15-2017, 2:14pm | #18 | |||||||
Previous occupancy billings are mute. He can always argue the claim (whether honestly or not) that he has a rigid and efficient discipline for power consumption. Unless they can prove it otherwise, only his billings really come into play. The proof comes now after they've removed the magnet. And that comes down to how much effort each party is willing to do; If he is legit in his claim and the magnet was intermittently placed on the box, then he does nothing and the bill will reflect that. If he did intentionally use the magnet and it it did alter the reading, then he will have to recreate that reading without getting caught. Both situations put a lot of effort on the provider to monitor the box. Only if he is trying to alter the reading again without being caught, does he need to put forth a lot of effort. And in the end, he can always claim ignorance. He explained why the magnet was there, which seemed like a very good alibi (again, whether truthful or not). At best they can charge him for the difference after they establish a baseline for a few months going forward. And they still need to prove that the magnet he used can indeed affect the reading on that box. Which would seem pretty simple to do. |
