05-13-2020, 8:22am | #1 | ||||||
Barn Stall Owner #102
Gameroom Barn Bucks: $23243
Thanks DAB
Shout out to DAB for coming to the rescue on our wood working project question.
Plan to acquire the drill bits and extenders we discussed. This should be a fun project. |
05-13-2020, 8:26am | #2 | ||||||
What could possibly go wrong?! Hint: Bondo can be used to fill any gaps. I use it to patch rotted door frame bottoms. And window frames. |
05-13-2020, 8:36am | #3 | ||||||
Barn Stall Owner #∞
Gameroom Barn Bucks: $34677
05-13-2020, 8:39am | #4 | ||||||
Is there a secret handshake or something to join the club and know WTF this is about?
05-13-2020, 8:46am | #5 | ||||||
Barn Stall Owner #∞
05-13-2020, 8:58am | #6 | |||||||
Agree, have done that before, bondo works pretty good actually. Have used that trick on home flips. Easy to sand down and paint = good as new This projects will require a bit more work. Working with 6X6 boards. Pictures to come. |
05-13-2020, 9:00am | #7 | ||||||
05-13-2020, 9:10am | #8 | ||||||
Something Nic has needs drilled in a bad way...
with an extender apparently. Unfortunate. |
05-13-2020, 9:17am | #9 | ||||||
05-13-2020, 9:19am | #10 | ||||||
2” hole, 4” deep.
Oh dear. |
05-13-2020, 9:21am | #11 | ||||||
05-13-2020, 9:23am | #12 | ||||||
So neighbor has one of these. They do not want it, needs about 7 boards replaced, of course the boards needing replaced are the massive 6X6 boards that were put below ground and as a consequence rotted. SO...... We can purchase replacement boards from the manufacturer ($$$$ plus shipping) OR we can fabricate our own. Grands will love it. |
05-13-2020, 9:26am | #13 | ||||||
05-13-2020, 9:30am | #14 | ||||||
Barn Stall Owner #1776
Doug is my go to professional woodworking specialist of impeccable integrity, I had commissioned him to do 3 separate start from scratch jobs, a table top fruit bowl, a flying wooden stingray (the fish), and a custom made inert explosive ordnance top for a WWII era 90MM brass shell, my favorite.
05-13-2020, 9:32am | #15 | |||||||
so where do you need to drill the holes? of the boards, sides? and what goes into the holes (watch out for Knooger)? hypothetically, if you wanted to attach a 2" diameter pipe to a 6x6 end, I'd drill a 2-1/8 or 2-1/4 hole, seal the end of the pipe (some blue tape would work), mix up some Bondo (with fiberglass, good stuff), put that into the hole, insert the pipe, brace it until the Bondo sets (30 min should do nicely), and the pipe will be held securely. if this is for rotten little kids, sand down the lumber and the edges. 80 grit should work well. |
05-13-2020, 9:45am | #16 | |||||||
We will make sure this is on top of the ground. PO had buried them at least a foot deep in pea gravel, which accelerated the wood rot. Knooger loves strange holes. |
05-13-2020, 10:01am | #17 | |||||||
YW /thread |
05-13-2020, 10:16am | #18 | |||||||
05-13-2020, 10:45am | #19 | ||||||
Gameroom Barn Bucks: $22573
05-13-2020, 11:57am | #20 | ||||||
Barn Stall Owner #∞
