01-31-2023, 9:36am | #41 |
01-31-2023, 9:41am | #42 | ||||||
01-31-2023, 9:42am | #43 | ||||||
01-31-2023, 9:44am | #44 | ||||||
01-31-2023, 1:56pm | #45 | ||||||
Yadkin has admitted to being wrong-o on occasion. So has Lars.
There is nothing to argue about here. You are both hard-headed stubborn squares. |
01-31-2023, 2:05pm | #46 | ||||||
01-31-2023, 2:05pm | #47 | ||||||
01-31-2023, 2:29pm | #48 | ||||||
I get the ongoing ribbing for my drafting error, but the fact is a standard 8x16 CMU is 3/8" shy in all three dimensions. The 3/8" is for mortar thickness. So a mason working precisely will make a wall 3/8" shorter in all three directions...
Then there is the "1/2-inch" OSB sheathing which is commonly sold as 7/16" with an actual thickness closer to 13/32".... I normally detail a foundation wall section so that the sill plate is flush with the outside edge of the masonry. That lets the sheathing overhang the foundation wall to reduce the potential for moisture wicking. That has the effect of enlarging the building plan dimensions by 7/16"... All which is ignored by everyone involved. Funny business, building construction. |
01-31-2023, 2:55pm | #49 | ||||||
01-31-2023, 3:14pm | #50 | |||||||
Lemme finish my coffee and maybe I'll give it a go. |
01-31-2023, 3:18pm | #51 | ||||||
01-31-2023, 3:33pm | #52 | ||||||
01-31-2023, 3:39pm | #53 | ||||||
01-31-2023, 3:45pm | #54 | ||||||
01-31-2023, 3:52pm | #55 | ||||||||||||
Here ya go. For your entertainment and enlightenment.
Enjoy. Your post could have ended right there. Quote:
(we add a layer of poly attached to the wall studs from a 12" roll that spans the bottom of the wall and the top of the foundation, before the wall sheathing. This adds in keeping any moisture that forms on the bottom of the sheathing from getting to the bottom of the wall and sill plate. Quote:
The reason is, finishes vary. Even brick varies. Only the highest level plans would ever call out the finish dimensions. Typically because at the time of plans (and even contract) these finishes have not been selected. Not ignored by me and other good contractors. Frankly tracking and anticipating finishes while doing framing/structural/foundation work is exactly what separates the good from the bad. An experienced eye can always tell if finishes wee not considered during the early stages of construction. The word "afterthought" comes to mind. Served me well for 50+ years. |
01-31-2023, 5:11pm | #56 | ||||||||
[/QUOTE] |
01-31-2023, 5:26pm | #57 | ||||||||
He absolutely will build the wall to the plan dimensions regardless of the CMU dimension. Quote:
A brick home, a siding home, a stone or stucco home, using the exact same floor plan...will have the same foundation plan dimensions. It is also why subcontractors who quote based on square footage do so by building plan, not overall dimensions. A framer for example is not getting paid for the additional square footage with the brick added. A 30' x 40' rectangle home is 1200 sq ft. That's the foundation dimensions and the framing dimensions. Add sheathing and finishes and it's still a 1200 sq ft home. The mason is going to build to the 30' and 40' dimensions, regardless of the CMU dimensions. |
01-31-2023, 5:48pm | #58 | ||||||
01-31-2023, 6:04pm | #59 | ||||||
Are you sure you guys aren't siblings? You sure argue/fight/bicker like you are.
In any case, I heartily approve. |
01-31-2023, 7:24pm | #60 | ||||||
