03-05-2020, 12:30am | #1 | ||||||
Looking for input regarding my dad
This has reached the point of ridiculous from a medical standpoint, and sadness for me to see my dad this way.
He has/had afib and has a pacemaker. Prior to the pacemaker, they did an ablation. While most everyone I have heard about, was draggy for a little while after their ablation, but then snapped back good as new. Not my dad. He is constantly fatigued and short of breath. He can't walk 20 feet without having to sit and rest. It takes him a few minutes to climb the stairs. His behavior would have you believe he was chasing the dog or chopping wood when all he did was walk from the stairs to the kitchen table. It takes a few minutes to walk from the car to the door and he comes in breathing like he just ran a mile. Doctors can't figure it out. BP is fine, heart rate is fine, bleed time is fine, oxygen level in blood is fine. Afib is controlled. It just makes no sense and physically, everything checks out, but he is just a mess. I'm looking for similar stories. You, someone you know, neighbor? Anyone else know of a situation like this? What was the cause? |
03-05-2020, 7:02am | #2 | ||||||
Barn Stall Owner #∞
Gameroom Barn Bucks: $34677
COPD?
The Following User Says Thank You to z06psi For This Useful Post: |
03-05-2020, 8:30am | #3 | |||||||
Gameroom Barn Bucks: $550
The above issues you are describing happened to me, exactly as you have written. It took 12 months to figure out that the cardiologist who performed my ablations went too far. Ablating nerves (literally burning them away) creates scar tissue in the area where the pulmonary veins connect to the heart. Some ablating is performed inside the heart, some inside the veins. In my case, excessive scar tissue in my pulmonary veins blocked one vein 100%, and two others by up to 50%. As the scar tissue grew, I became weaker, ultimately causing me to be nearly unable to climb stairs or walk more than 25 feet. I was initially diagnosed with Pulmonary Arterial Hypertension, which is ultimately fatal, as the symptoms are very similar. A right heart cath showed blood pressures within my lungs were off the chart. Normal PH treatments, however, had no impact. What ultimately led to the correct diagnosis was an MRI of my lungs. In the MRI, the lungs show as black ovals with white pinpricks of light where blood is flowing. Halfway up on my right lung, the lung went completely black due to the complete lack of blood flow. In my case, the correction involved installing a stent into the blocked pulmonary vein (not an artery, which is where one normally expects to have stents). I was on the table for 5 hours, and the cardiologist came out smiling to tell my wife and son that it had been a success and blood (seen via dye in the vein) was flowing again. Two days later I was making laps around the ICU. It made a huge difference. My work was performed at VCU Hospital lin Richmond VA. This type of stent installation had never been heard of before, and I was their first attempt to correct the ablation screw up. My problem now is the loss of muscle from the incapacitation I experienced. I lost 30 lbs. over two years and due to recurring afib haven't been able to regain my strength. I hope to get back at some point. Unless your father deals with a cardiologist who understands the dynamics caused by excessive ablations, they won't be able to diagnose the problem, if indeed it's similar to my situation. It may be entirely different from what I've been through, but you described my experience word for word. |
The Following 9 Users Say Thank You to steve's 74 For This Useful Post: |
03-05-2020, 9:04am | #4 | ||||||
My MIL is going through that right now. I wish I had an answer. Just did two Afib bouts and a triple bypass. Seems like Steve 74 may be onto something.
03-05-2020, 9:11am | #5 | |||||||
Barn Stall Owner #102
Gameroom Barn Bucks: $23243
Hard to give input without more information or access to diagnostic tests that have been done. I am going to assume that all other cardiac function has been assessed. "everything" checking out would indicate to me he has had angiography and echocardiogram. The symptoms described most match up with CHF (congestive heart failure), with this he would also have presentation of swelling of legs, more difficulty breathing when laying down (orthopnea) as well as the symptoms you described above. As Top mentined, COPD could be a cause as well, but can easily be ruled in or out with PFT (pulmonary function tests) and CXR (Chest xray). Even though cardiac or pulmonary malfunction are the likely cause, there is a possibility he has been recently started on new medications that could ALSO be contributing to these symptoms. Hope that helps buddy. Watched my dad literally wither away with a combo of Cancer and COPD, I will never forget those horrible months. Sorry man. ALSO>>> if his doctor cannot figure it out, time to get a second opinion!!! |
The Following 3 Users Say Thank You to C3C7NIC For This Useful Post: |
03-05-2020, 10:06am | #6 | ||||||
C3C7NICl is correct. All possibilities should be checked and properly diagnosed. My case is unique, but the team at VCU felt like my situation was going to become a much more common as many hospitals are now doing ablations, some without proper training and/or experience. Make certain that your Dad has a great team in both cardiology and pulmonology.
03-05-2020, 11:24am | #7 | ||||||
Barn Stall Owner #1000
Gameroom Barn Bucks: $2425793
Pulmonary hypertension??
03-05-2020, 12:06pm | #8 | |||||||
03-05-2020, 12:13pm | #9 | ||||||
Barn Stall Owner #16A
Gameroom Barn Bucks: $602908
He’s not still fulltiming in his RV is he?
03-05-2020, 12:20pm | #10 | |||||||
Gameroom Barn Bucks: $2214590
I guess every case is different, though, that's how medial science is. |
03-05-2020, 2:35pm | #11 | |||||||
As Nicole has said, all issues need to be reviewed, because it may be something else. Again, the MRI of my lungs was what finally caught the issue for me. And you are partially correct about the doctor thing. Only a referral to another doctor at another hospital found my problem. Once the other hospital's cardiologist had found the problem, it was difficult for someone to say that it wasn't the previous cardiologist's fault. Maybe, but the pacemaker is supposed to counteract that. My wife has had three ablations with little and short term results, but no negative effects because of her pacemaker. A pacemaker struggles to control afib when it includes high heart rate, which is what I'm dealing with. My rate has topped 220/minute on occasion, which is completely disabling. In my case, they would have to sever the nerve between heart and brain and install a pacer, which would then run my heart full time and turn me into an android. May still have to go that route, but it's obviously irreversible. I just went into aflutter at 12:30, which has caused mildly elevated heart rate but normal sinus rhythm. Aerovette, if you want to talk, my number is 5409081957. Feel free to call. I'm stuck in the hospital for a while longer apparently. |
03-05-2020, 3:08pm | #12 | ||||||
03-05-2020, 3:10pm | #13 | |||||||
He is having a lung MRI done now...the complication being the impact of the dye on his kidneys. Kidney function is just a hair above the lower limit. Right now he is being hydrated (4 hours). Basically a flush and fill. |
03-05-2020, 4:27pm | #14 | ||||||
03-05-2020, 4:32pm | #15 | |||||||
03-12-2020, 4:38pm | #16 | ||||||
UGH
Lung MRI shows no blocked veins. The mystery continues. |
