Old 06-08-2023, 3:28pm   #701
Points: 128,432, Level: 100
Originally Posted by dvarapala View Post
What do you expect from a guy who bolts a floor speaker to his ceiling?
I expect that bath fan to rattle like a sumbitch up against that plumbing.
LATB is online now   Reply With Quote
The Following 3 Users Say Thank You to LATB For This Useful Post:
Old 06-08-2023, 3:33pm   #702
GTOguy
Points: 25,509, Level: 100
Activity: 95.8%
GTOguy's Avatar
Attachment 81611
Yadkin won't hear it. He'll have Midnight Rider pumping through that lone speaker screwed to the ceiling.
GTOguy is online now   Reply With Quote
The Following 2 Users Say Thank You to GTOguy For This Useful Post:
Old 06-08-2023, 3:40pm   #703
GTOguy
Activity: 95.8%
GTOguy's Avatar
Sometimes I'm perceptive. Other times I'm shamefully slow on the uptake.
I just realized Yaddie's 'addition' is actually his new Man Cave, because now that he's mostly retired and around the house all the time, Baby Doll is getting tired of him straightening the pictures with a laser and electrifying the flatware. The speaker was the tell here. Yaddie is going to spend many happy hours puttering in the 'addition', out of his wife's hair, re-engineering who knows what. He may even set up his PC down there and post more often. We can only hope.
The Following User Says Thank You to GTOguy For This Useful Post:
Old 06-08-2023, 4:28pm   #704
Points: 49,187, Level: 100
Activity: 78.0%
This is only the beginning. He purchased the lot next door so he can build a brand new house just for her so she doesn't have to deal with him anymore.
The Following 2 Users Say Thank You to dvarapala For This Useful Post:
Old 06-08-2023, 5:41pm   #705
TheHammer
Points: 11,800, Level: 75
Activity: 5.8%
TheHammer's Avatar
Gameroom Barn Bucks: $2149
it's a cave alright
TheHammer is offline   Reply With Quote
Old 06-08-2023, 8:26pm   #706
Yadkin
Points: 31,310, Level: 100
Activity: 99.8%
Yadkin's Avatar
'Can't you see what that Yaddie has done to me.....' LOL....
I remembered that you saw AC DC way back when around the time I did ('79) so I was projecting. The more time that goes by, the more obvious it is how some of the bands and artists were beyond compare. MT and The Allman Bro's fit right in that groove, IMO.
No, I saw AC/DC in Greensboro NC around year 2000. I remember the year since I drove my '98 Mustang GT to meet up with my buddy Butch , then on to meet his pharmaceutical rep. We got in the reps car, he treated us to dinner, the concert, and strip bars after. Then Butch and I drove off and I did some donuts in the parking lot. What a hoot.
Yadkin is offline   Reply With Quote
Old 06-08-2023, 8:29pm   #707
Yadkin
Activity: 99.8%
Yadkin's Avatar
Attachment 81611
There is about 1/2" clearance. But since I was able to tuck the new vent up higher than the "professionals" set the old one, it will be moved when I raise the drop ceiling.
Old 06-08-2023, 8:35pm   #708
Yadkin
Activity: 99.8%
Yadkin's Avatar
The new house on that lot will have a four car garage with a ceiling high enough for four post lifts, doors face the rear. The garage will be accessed from my existing driveway. A small front driveway will hold two vehicles for the main level renters.
I'm thinking of doing a chalet style, 6:12 gable front with large overhangs supported by round timbers.
Old 06-08-2023, 8:38pm   #709
Yadkin
Activity: 99.8%
Yadkin's Avatar
Originally Posted by TheHammer View Post
it's a cave alright
Damn straight. These "man caves" with video games, a big screen and plush interiors are definitely not my thing.
Old 06-11-2023, 5:20am   #710
Yadkin
Activity: 99.8%
Yadkin's Avatar
I replaced the water main yesterday. Now my main shut-off is as close to the entrance as possible, with a PRV immediately downstream.
My original plumber had installed the valve above the ceiling and behind the boiler in my garage, with no PRV. Our street pressure here is about 140psi.
Old 06-11-2023, 5:34am   #711
Yadkin
Activity: 99.8%
Yadkin's Avatar
I only have an inch of insulation space behind this box. So I'll put a foam board back there and keep the box warm with a 3-feet length of 38-degree heat tape. The rest of the wall will be closed cell spray foam.
Old 06-11-2023, 10:20am   #712
GTOguy
Activity: 95.8%
GTOguy's Avatar
Screw this. Fix the camera in the Porsche and get us some road videos.
Old 06-11-2023, 8:56pm   #713
Yadkin
Activity: 99.8%
Yadkin's Avatar
Originally Posted by CF mods eat dick View Post
Two questions did you sleeve the line going through wall?
Also looks like a bitch to replace the press red valve if it leaked or went bad, no?
The line through the wall has plastic insulators, same as through the studs or blocking, except on both sides. The pex can't touch the concrete between them. If the inspector requests it, I can insert a 1" x 8" long pex sleeve by slicing along its length.
The first picture shows an unused insulator. There is a threaded male adapter at the outlet end of the PRV inserted through the hole in the blocking that prevents pex-wood contact, so that insulator is not needed.
The 2nd picture shows the inlet end of the PRV- it's a union, enabling removal of it or the upstream ball valve. To access the union, remove the upper copper hanger. Both hangers are easily removed by first removing the two stainless steel 1-5/8" deck screws that fasten the plate to the wall stud. The plates are turned slightly for better access of the screws. The screws are T20 drive- nearly impossible to strip.
Old 06-12-2023, 7:17pm   #714
Yadkin
Activity: 99.8%
Yadkin's Avatar
New door from the garage to a hallway outside the basement bathroom. The hall will be tiled for easy clean up of my greasy shoe soles.
Old 06-12-2023, 7:19pm   #715
Yadkin
Activity: 99.8%
Yadkin's Avatar
In the past two days I demolished a roman tub, two shower stalls, and about 8' of interior wall (including insulation). Most fit in my truck- tomorrow will be my second trip to the landfill.
Old 06-12-2023, 7:29pm   #716
UniqueDoug
Points: 24,791, Level: 100
UniqueDoug's Avatar
Gameroom Barn Bucks: $5427
Nice load, now time to upgrade those steel wheels.
UniqueDoug is offline   Reply With Quote
Old 06-12-2023, 7:47pm   #717
Damn that’s a mess.
Old 06-12-2023, 7:48pm   #718
Yadkin
Activity: 99.8%
Yadkin's Avatar
Damn that’s a mess.
Yeah sure.
Old 06-12-2023, 7:48pm   #719
Yadkin
Activity: 99.8%
Yadkin's Avatar
Nope. Mine's a work truck.
The Following User Says Thank You to Yadkin For This Useful Post:
Old 06-12-2023, 7:56pm   #720
Yeah sure.
Indeed.
Copyright © 2009 - 2023 The Vette Barn
