06-01-2018, 8:46pm | #41 | |||||||
I've messed around with the Electric Chokes on Holley 4160/4150 Carbs, but I'm by no means a guru on the subject. |
06-01-2018, 8:50pm | #42 | ||||||
Barn Stall Owner #17
I'll be looking forward to pics of the new paint job. PPG does make good paint. Remember even strokes *that's what she said* not the sway in/out stuff most noobs do. Scott
06-01-2018, 11:27pm | #43 | ||||||
Gameroom Barn Bucks: $1317070
I don't have to worry with my awesome Krylon paint jobs. I even beat Earl Scheib's prices. |
06-02-2018, 6:07am | #44 | |||||||
06-02-2018, 6:42am | #45 | ||||||||
I tried sand blasting ONCE. That was enough for me. I had on work coveralls over my regular clothes and was covered from head to toe. After sand blasting I forgot that my wallet was still in my regular clothes. For months afterwards when I would pull out a credit card, etc...there was STILL sand in every crevice of that wallet. Blasting is huge mess. Sanding is bad enough, blasting is ridiculous Quote:
His post on how to time/tune ignition and carbs were the best on the internet. All those guys in the C1/C2 section in the old days were professors on old cars. |
06-02-2018, 2:12pm | #46 | |||||||
06-02-2018, 3:54pm | #47 | ||||||
He's still there, and posts quite a bit in PR&C Not surprising, right?
06-02-2018, 6:05pm | #48 | ||||||
06-04-2018, 7:43pm | #49 | ||||||
We have perfect weather here for painting outside of a booth. Low humid., moderate temps, no wind. It doesn't look like a lot of work, but surface prep is were all the labor is involved in painting. I left the dings of hauling fire wood for 44 yrs., also I didn't fill all the ones in the replacement tail gate. I'm happy with my $25 paint gun from Walmart. At that price, you can basically use them and toss them and buy a new one next time.
My biggest regret is not chemically stripping the tail gate. I had planned to only scuff it and paint it. I wasted too much time sanding it down to bare metal with a sandpaper. I should have used the tried and true Aircraft Paint stripper remover and gone straight to metal from the start. I hope to put the single stage color on this week, before the humid. hits 90 plus again in GA. |
The Following 6 Users Say Thank You to Grey Ghost For This Useful Post: |
06-05-2018, 9:00am | #50 | ||||||
06-07-2018, 4:10pm | #51 | ||||||
06-07-2018, 7:55pm | #52 | ||||||
Getting a second coat on is tough... no place to stand! Looks good.
06-07-2018, 7:59pm | #53 | ||||||
VB Dad of the Year
Looks good!
06-16-2018, 8:57pm | #54 | ||||||
Well the color match wasn't to my liking. I should have stopped and went back to the supplier and let them adjust it. They used their fancy camera and mixed it up by what it told them. I went back to them last week and they mixed up a fresh custom batch matched to the truck by their human eye. It was add a little of this and add a little of that and lots of back forth from the truck to the mixing area. They gave me the new batch free of charge! And it's not like I'm a frequent customer or it was a large order. The only drawback was scuffing it all up in 105 deg. heat index. I'm waiting for a morning or late afternoon to spray the new paint.
It was still giving me a hard start situation and a couple other quirks the last couple of weeks. This week I started smelling fresh gas....popped the hood and fuel was leaking from the fuel pump. Got it off and it looks like the original pump. I wrestled a new one on. That little rod that slithers up/down on the lever is always a beotch! Plus there is some kind of bracket on this motor just in front of the pump. I finally got it held up in place long enough with a hacksaw blade to get the pump in and the bolts started. I might as well rebuild the carb. at some point and that will be a complete fuel system repair. |
06-16-2018, 9:11pm | #55 | |||||||
06-29-2018, 7:59pm | #56 | ||||||
I decided to rebuild the carb. so that I know that I have been through the entire fuel system.
I should have gone to the parts store and walked out with a rebuild kit...or one of the specialty sites - quadrajetparts or Mike's carbs. Lesson learned. I've rebuilt several Holley's, this will be my first Roch. 2gc |
07-21-2018, 6:19pm | #57 | ||||||
I found the build sheet! That gives me all the documentation for the truck. Orig. invoice, build sheet, glove comp. stuff, etc...
07-21-2018, 7:08pm | #58 | ||||||
Once you get the carb dialed in, flip the air cleaner lid and take a spirited ride... it will trigger memories I promise.
07-21-2018, 7:56pm | #59 | ||||||
I have the carb blown apart now. I need to do a bit more cleaning on it and run a wire or something through all the holes. I have a compressor to blow them out. I've always heard you STILL have to run a wire through them? I wound up with a Walker rebuild kit...hope it is good. I hope I still have my pressure gauge for tuning and I've thought about leaving the emission crap off of it?
07-21-2018, 8:00pm | #60 | ||||||
Cutting torch files work really well for cleaning all the little carb orifices
The Following User Says Thank You to 86RAG For This Useful Post: |
