06-27-2011, 7:24am | #121 | |||||||
Gameroom Barn Bucks: $1545413
Trucks in general, (Ford and Chevy) hold their value extremely well and diesels more so. |
06-27-2011, 8:26am | #122 | |||||||
06-27-2011, 8:55am | #123 | |||||||
Gameroom Barn Bucks: $2527405
06-27-2011, 9:11am | #124 | ||||||
Barn Stall Owner #3
Gameroom Barn Bucks: $2324642
Your biggest problem is you have a 3/4 ton suv with a gas engine. That engine can barely move the Suburban around, let alone add weight to it.
You're better off towing with a 1/2 ton than with a 3/4 ton gas. |
06-27-2011, 9:54am | #125 | ||||||
Gameroom Barn Bucks: $2173478
Having towed with both -- albeit minimal experience with the diesels. I understand what the OP is saying.
While a diesel may be overkill for many of the jobs where a gasser is 'sufficient' tow it with a diesel and you'll realize how much more comfortable towing with a rig that might be considered overkill really is. Even more so, tow with a gasser with some strong cross winds, uneven roads, and steep inclines/declines, you'll really value that diesel and the heavier truck associated with it. Is a diesel overkill for what many of you are doing? Maybe, but so is your corvette in nearly every use. While ya'll are so vigorously defending the use of a gasser truck, you're missing the fact that even with a 'properly' loaded/balanced trailer being so close to the limits of your tow vehicle really changes the dynamics of the whole rig. Towing with 'overkill' makes for a much more comfortable trip. |
06-27-2011, 10:20am | #126 | ||||||
06-27-2011, 10:48am | #127 | ||||||
Chris I don't really agree. As someone who towed a car hauler with a GMC Canyon for 3 years I've learned that towing near the limit (or over) of something's rating is all about having the right equipment and some common sense.
Two basic additions make towing so much easier: 1. Air springs 2. A good weight distributing hitch with sway control... the biggie being sway control. With the truck properly level and the trailer setup with the correct tongue weight and the distributions bars all set correctly a 1/2 ton gasser will tow beautifully. I can tow up to 100 w/o the arse end so much as wiggling. I normally tow in the lower 70s, but coming home from RA some guy got overly mad that I was going 75 in a 65 in the left lane passing some folks. He comes up along side me and flicks me off while motioning for me to get out of the left lane.... then he zooms off. I'm sorry... I didn't realize that 10 over and passing folks was insufficent for the left lane. He thought he'd get away from me so I ran him down and got up next to him... the look on his face was priceless when my GF and I both told him he was #1. I then resumed my leisurly 75 cruise-control. |
06-27-2011, 11:15am | #128 | |||||||
06-27-2011, 11:29am | #129 | ||||||||||
Gameroom Barn Bucks: $11985
I will point out to everyone again and Polar Bear caught on to it, flat ground towing is a completely different animal than towing in the hills/mountains. |
06-27-2011, 11:34am | #130 | ||||||
Barn Stall Owner #82 BR Car Washer II,III NCM Supporter '11,'12,'13 Bantayan Kids '14
Gameroom Barn Bucks: $5504001
06-27-2011, 11:53am | #131 | ||||||||
Gameroom Barn Bucks: $1006507
Do you have 4 fat chicks under the cover? |
06-27-2011, 12:10pm | #132 | |||||||
Boat - 3700lbs dry weight. Fuel - 45 gallons @6lbs per gallon = 270lbs Trailer - Approximately 1550lbs (per tag) Gear & Sacks - Approximately 300lbs = 5820lbs. I also have a weight ticket showing it at 5930 when I had it scaled. (also we are tending to fill ballast up from the hose rather than at the lakes due to mussel problems which adds over 700lbs.) I rounded up. (also the X15 is 21.8' not including the swim deck of course and has 100" beam. It is bigger than it looks in the pic) Last edited by Gozar; 06-27-2011 at 1:36pm. |
06-27-2011, 12:11pm | #133 | ||||||||
06-27-2011, 12:16pm | #134 | ||||||||
C4 Mod
If you buy a truck with the sole purpose of towing, yea, buy a diesel. It isn't too hard to figure out. That doesn't mean that the guy who chooses to drive a truck as a DD and tows something once or twice a year should go spend $50k on a 1 ton diesel. |
06-27-2011, 12:19pm | #135 | |||||||
I did pull the Sea Ray to Naples from Athens and back in the Silverado with a 5.3......effortlessly. Mostly flat......but it did a pretty good job. 10MPG. |
06-27-2011, 12:20pm | #136 | |||||||
06-27-2011, 12:22pm | #137 | ||||||
Barn Stall Owner #3
06-27-2011, 12:22pm | #138 | ||||||
Barn Stall Owner #113
Gameroom Barn Bucks: $306898
I love truck threads almost as much as Mustang threads.
06-27-2011, 12:23pm | #139 | ||||||
06-27-2011, 12:23pm | #140 | |||||||
Barn Stall Owner #0
Gameroom Barn Bucks: $1576624
Pretty much sums it up right there. |
