12-19-2022, 2:36pm | #81 | |||||||
That video of the river table just doesn't make sense. And it's not the only one that I watched. No info at all on Rubio's website, pdf brochure or detailed instructions. I just chatted with Rubio- they say that it will brighten up the epoxy but won't stick to it. Whateverthe**** that means. I'm going to go with poly on top of this instead of the Rubio. It's a "known quantity" with me, and can be wet sanded and polished, like paint correction on a car. |
12-19-2022, 4:21pm | #82 | |||||||
You're not that guy. You are an engineer. You do things the right way or you don't do them. Good luck with your project. |
12-19-2022, 4:46pm | #83 | ||||||||
12-19-2022, 4:49pm | #84 | ||||||
12-19-2022, 4:52pm | #85 | ||||||
Nope. Just switched tactics. Back to old school.
12-19-2022, 5:46pm | #86 | ||||||
12-19-2022, 6:05pm | #87 | |||||||
12-20-2022, 10:56am | #88 | ||||||
12-20-2022, 3:38pm | #89 | ||||||
Kinda like the lacquer and enamel thing. One way works, the other way destroys the work. I always end up forgetting which is which and end up having to strip the whole thing and start over. We can't all be blessed with StorytellerStealth's good luck.
12-20-2022, 8:38pm | #90 | ||||||
I'm not happy with "almost flat", so I rigged up a redneck 2D CNC machine to re-flatten before I re-sand then apply varnish.
12-21-2022, 9:18am | #91 | ||||||
Epoxy will self level but interesting watching a stick kick your ass.
12-21-2022, 3:25pm | #92 | ||||||
Big Bob must be describing some weird thing that apes do to their mates.
12-21-2022, 3:39pm | #93 | ||||||
12-21-2022, 4:14pm | #94 | |||||||
I've determined that Bob is enough of an ass that I'm missing out too much if I have him on ignore, so I'm letting him back into the Inner Circle. |
12-21-2022, 4:39pm | #95 | ||||||
I did the same type of jig (another non-woke word) to make a wood dash for my Fiat Spider project. That was a compound curve, so the steel angle gets substituted for wood rails (long concave curve), and the sled made of a short convex curve. Same router. I don't have a picture readily available but it turned out awesome.
12-21-2022, 4:42pm | #96 | ||||||
Careful. Bob is likely to get the wrong impression about your use of that term, and want to bend you over and thrust hard enough to cause a well-engineered structure to swing.
12-21-2022, 4:50pm | #97 | ||||||
Here's the Fiat dash prior to finishing with about ten coats of spray-on polyurethane.
12-21-2022, 5:37pm | #98 | ||||||
There you go again talking out your ass again. If you would have done as Mad said then once it cured put your varnish over the epoxy would have given a beautiful depth to your finish with a flat surface. Your sled will work as well but you will spend a lot more time playing with your wood.
12-21-2022, 6:26pm | #99 | ||||||
12-21-2022, 6:35pm | #100 | ||||||
Cool, I figure ya would find those jigs or how to. I looked at one for bar top but the time, effort and dimensions to be built on the bar would have taken more time for me than sanding for days
