Old 04-04-2010, 6:24pm   #41
Is that bottle in the rear center cubby?
Old 04-04-2010, 8:15pm   #42
No, its mounted right in the center. My 12 disc changer is in the center cubby hole. I wanted to mount it in there, so sit would be stealth, but it wouldn't go in there with the changer.
Where it is, all I have to do is reach back, turn the valve, purge, arm, and spray.
Old 04-04-2010, 9:44pm   #43
Not you, I already commented on your bottle. I was wondering about Z06's bottle.
Old 04-04-2010, 11:18pm   #44
In that case, my bad, please continue..............
Old 04-05-2010, 6:47am   #45
Z06PDQ
Points: 14,229, Level: 82
Z06PDQ's Avatar
Gameroom Barn Bucks: $16626
in the trunk,mounted on a piece of plywood covered in carpet. I was going to build another piece of plywood with velcro to cover it, but I'd have to remove it every time I showed someone the bottle. it really doesn't get in the way much.still plenty of room to carry stuff.
The Following User Says Thank You to Z06PDQ For This Useful Post:
Old 04-16-2010, 3:15pm   #46
Microedge is back, installed, and working great! Only took them 2 fugin weeks to get it back to me. All I have to do now is turn the valve, arm, and push the throttle. The controller takes care of everything else.
I have it set as follows for now: On at 3K RPM, off 6K RPM, 1st gear locked out, only comes on in 2nd and up. I programmed in a half second delay to give the tranny time to kick down into second, and WOT to dump fuel. Once it hits, it hits nice.
Initial impression: Good investment.
Old 04-16-2010, 7:28pm   #47
First let me say congrats and oh how cool!
Now for the questions. Do you still need a switch mounted by your gas pedal or does the controller read WOT from the PCM?
Does the microedge pull timing if you want or do you use the HSW "Interface"?
You have an auto?
Does the microedge monitor AFR or is that again done by the "interface"?
I have more questions but chew on those and I'll get back to ya.
Old 04-16-2010, 8:32pm   #48
You have an auto?
No WOT switch. It gets connected to the TPS
No it does NOT pull timing. You need the Interface for that.
Yes, I have an A4.
Yes, it will monitor AFR and can be set to shut down the N20 if you get too lean.
Chewed 'em up and spat 'em back atcha buddy.
Got anymore questions, check your PM box.
Old 08-14-2010, 11:00pm   #49
Garb55
Points: 17,083, Level: 90
Garb55's Avatar
Gameroom Barn Bucks: $7813
Can you get a better Pic?
Old 08-15-2010, 8:53am   #50
Z06PDQ
Z06PDQ's Avatar
I'll try -
Old 08-15-2010, 8:58am   #51
Z06PDQ
Z06PDQ's Avatar
Default a better one? notice quick disconnects
forgot to paint my toenalis
Old 08-18-2010, 8:34pm   #52
Where did you pick up the quick connects Z?
