10-12-2022, 9:21pm | #541 | |||||||
Barn Stall Owner #102
Gameroom Barn Bucks: $23243
So a cut would need to be made on both the rear lower filler panel as well as the rear fender. I have the old pictures of the OG rear parts. As I was looking at it today, it hit me that he had those filled in. Trying to decide of it would be cheaper to just say screw it and put side pipes on or modify the body to put it back to original (as I wanted). At this point, going to have to try to cut corners where I can. |
10-12-2022, 9:27pm | #542 | ||||||
If it was me I wouldn't cut the body... Not now anyways. The exhaust can just be turned down instead of straight out the back.
The Following 4 Users Say Thank You to Rodnok1 For This Useful Post: |
10-12-2022, 9:59pm | #543 | ||||||
Yeah, but damn...a big block through side pipes is ear candy. And it's not like you are going to be driving it across country or every day.
The Following 2 Users Say Thank You to Grey Ghost For This Useful Post: |
10-13-2022, 4:52am | #544 | ||||||
Gameroom Barn Bucks: $1014987
The Following User Says Thank You to Old Ben For This Useful Post: |
10-13-2022, 5:16am | #545 | |||||||
Gameroom Barn Bucks: $311064
If it were mine, I'd keep it original. Sides are hot, loud and will burn your leg if you accidently touch them getting out of the car. The turn down idea would be the cheapest resolution but to me not right for a '68. Just my $.02 worth. |
10-13-2022, 7:59am | #546 | |||||||
10-13-2022, 8:39am | #547 | ||||||
Will have the local shop doing the other work take a look too, when they get it in their shop. Not sure if you all can tell from previous pictures of the exhaust what has been done under there.
The car being “loud” was never one of my priorities. And I believe I stated, new exhaust had been installed literally a month before it went to NC. I have no idea where the side pipe idea came from. DUB kept going down rabbit holes; ones I now have no answer to. |
10-13-2022, 8:45am | #548 | |||||||
10-13-2022, 8:49am | #549 | |||||||
SOME Real Barner
Gameroom Barn Bucks: $2034428
And they dont have to be so loud they makes your ears bleed. Like mine.
10-13-2022, 9:23am | #550 | |||||||
However, I vote side pipes. |
10-13-2022, 10:09am | #551 | ||||||
There was a guy in my neighborhood that had a Big Block 65 (396) Vette with Side Pipes.
He had a custom exhaust on it that had standard mufflers (hidden) and he could switch back and forth between Quiet (hidden mufflers) and Loud (Side Pipes) with an electric switch. Really cool setup. BEAUTIFUL car. He ended up with Dementia unfortunately...family sold that car. Edit: Just realized this was post 9000 |
The Following User Says Thank You to StaticCling For This Useful Post: |
10-13-2022, 11:04am | #552 | ||||||
Thanks all, appreciate the input..
I had no idea you could do either! That sounds interesting!!! |
10-13-2022, 5:44pm | #553 | ||||||
Tough call. One part of me says just to fix the thing and get it going and make any changes down the road. Another voice tells me while it's in the shop to fix it the way you want to live with it forever.
I had side exhaust on my '66. I was much younger, but, the sound wasn't bad even with the top up/down. There is an electric valve they can install if you want to flip between side or rear. |
10-13-2022, 7:05pm | #554 | ||||||
Dedicated side pipes require bespoke headers along with the pipes as they are needed to direct the gasses out the side. That would mean replacing the entire system (again).
Adding either side pipes and/or cutouts (the electric doors which open and close for volume control) to the current system would entail even more massive cutting and welding butchery than has already befallen your poor baby, if there is even room under there with the big block, big transmission and oversized exhaust tubing....possible? sort of...but not very practical. |
10-13-2022, 8:11pm | #555 | |||||||
Barn Stall Owner #111
Gameroom Barn Bucks: $5547
The Following User Says Thank You to outrunm For This Useful Post: |
10-13-2022, 8:18pm | #556 | ||||||
Gameroom Barn Bucks: $22573
The Following User Says Thank You to Hardluck For This Useful Post: |
10-14-2022, 7:17am | #557 | ||||||
I dunno if I posted about my pipes in this thread or not....but I have the stock looking through pipe looking with glass pack toward the back, I can look through the muffs when off the car....2.5 inch use square stainless pipe ends in the stock square rear location....
10-14-2022, 8:28am | #558 | ||||||
1. Not all side pipes require headers
2. The ones I had, had removable mufflers. I could unclamp them from the collector, slip the mufflers in, and reduce the noise 3. If you start with side pipes and then decide you don't like them, the cut outs in the rear valance can be easily made. If you don't start that way and decide you want them later, the valance will have to be patched...like they already are. Again, purely personal preference. We'll all like the car either way. |
10-14-2022, 8:35pm | #559 | ||||||
you need this
10-15-2022, 6:37am | #560 | ||||||
Barn Stall Owner #106
I had the side pipes on my C3 and loved them but occasionally burned my leg on them, when exiting.
The Following User Says Thank You to Dan47 For This Useful Post: |
