#21 | ||||||
I jiggered up a small steam engine on mine! It's fired with coal and if I run out I can use wood. That's called a "multi-fuel."
Works great, but the fumes can be overwhelming at times. All youse gas or electric guys (i.e. coal, oil, natural gas) are so far behind the times. ![]() Get modern or go home! ![]() |
#22 | |||||||
![]() Quote:
#23 | |||||||
![]() Quote:
I laugh every time I hear lawn tractor it's a ****ing riding lawn mower. I just use it close to the house where I can't get a tractor into. And getting old trying to pull start shit is more work than the job itself. ![]() So as far as the OP goes with being old with a 1/4 acre I believe it would be a good fit. ![]() |
#24 | ||||||
Barn Stall Owner #0331
I bought an electric lawnmower just so I wouldn’t blow out my one remaining good shoulder and arm with a rotator cuff injury pull starting my gas mower.
The Following User Says Thank You to Louie Detroit For This Useful Post: |
#25 | ||||||
Barn Stall Owner #123
Gameroom Barn Bucks: $525
Not to mention having to tear down the carb every few months to clean all the shit out from dissolving gaskets caused by ethanol mix fuel
The Following 2 Users Say Thank You to KenHorse For This Useful Post: |
#26 | ||||||
Barn Stall Owner #116
Doesn't have a big thing ![]()
IMO, going battery with a mower is like jumping in the telsa with GSC3 and elon, you really do not want to do that!!
I have owned gas since I started my lawn service at 13, today I am on my second honda, only foregin shit I own, but it does me good, 15 years with the last one. Nothing beats the smell of gasoline burning and mulched grass in the morning,,, maybe napalm. |
#27 | ||||||
#28 | ||||||
#29 |
Stall Owner #1120.2520 ![]() Join Date: Feb 2010
Lift up the front end to rotate the mower in a different direction. With drive wheels on the back, the mower tends to keep going and is a PITA if you don't remember to let go of the lever.
#30 | ||||||
The Following User Says Thank You to KenHorse For This Useful Post: |
#31 | ||||||
Or was it plugged up from sitting all winter with gas in it? Alcohol in gas tends to do that, but it shouldn't be destroying gaskets, rubber lines, etc. since the '90s when manufacturers started using materials that were impervious to gasahol.
I got stuck in the middle of a lake with my 1988 boat cuz the fuel line/pickup rotted out. I replaced the entire fuel system with modern hoses (green lettering instead of white). I never did anything to the carbs, surprisingly, and a buddy bought it a few years ago and the carbs are still fine AFAIK. But that's just one example. |
#32 | ||||||
I always ran the fuel out at the end of the season so there was no fuel anywhere in the system. But the problem was never in the spring, it was always during the mowing season where a rubber o-ring (that sealed the float bowl) would break down and leave little particles in the bowl that would plug the jet(s). I always used genuine B & S replacement and it never failed to fail at least once during the season
#33 |
#34 | |||||||
![]() Quote:
Took me a little time to develop the muscle memory but now it's 2nd nature |
#35 | |||||||
Gameroom Barn Bucks: $476
![]() Quote:
#36 | |||||||
Barn Stall Owner #117
![]() Quote:
Every time I buy small equipment that needs a motor, I try to make it a Honda. IMO, Honda makes the best small engines around. My power washer has a small Honda on it and it starts with the second pull every time. I have an older small zero turn that has an 18 hp Honda. My wife uses it around the barns. It's 20 years old this year and has only required standard maintenance. |
The Following User Says Thank You to Tikiman For This Useful Post: |
#37 | ||||||
I agree that Honda-made small engines are top of the heap. Superior design, materials, and assembly. They will run indefinitely if cared for.
#38 | |||||||
![]() Quote:
The 750 started pretty hard in the spring after sitting all winter, but then it was fine. I redlined both bikes as often as possible -- no issues. ![]() My buddy also had a 750, a '71 I think. There were issues with our early ones breaking the drive chain if doing burnouts, etc. There was a recall, which helped somewhat. He was always doing burnouts, wheelies, and board shifting it, really beating it hard, and finally the chain blew and went through the lower case. We completely stripped the crankcases in his folks' yard (June 1972) and replaced the lower case. I don't remember if that was before or after the recall. They fixed that problem in later model years as I recall. But the 750, which came out in 1969, was on the cutting edge of motorcycle technology. Four cylinders crossways, four carbs, OHC, disc brake (front only, I think), 5-speed tranny, etc. So you can expect some problems -- especially when my buddy got his hands on one, lol. ![]() We rode them to Florida and back in '72, I had the wife on the back. Held them at 80 for three days, never missed a beat. On the stretch between Jacksonville and our destination in Daytona, we held them at 90 the whole way. Zero problems. |
#39 | |
![]() Quote:
#40 | |||||||
![]() Quote:
