01-22-2023, 2:39pm | #21 |
Let Aero and Yaddie have a meeting of the mindless and figure out your 220 situation. They can both over engineer it while doing it wrong all in one shot
The Following 5 Users Say Thank You to DJ_Critterus For This Useful Post: |
01-22-2023, 2:42pm | #22 | ||||||
Gameroom Barn Bucks: $2001216
01-22-2023, 2:44pm | #23 |
01-22-2023, 3:02pm | #24 | ||||||
Barn Stall Owner #14/32
Gameroom Barn Bucks: $4810
01-22-2023, 3:53pm | #25 | ||||||
01-22-2023, 4:04pm | #26 | ||||||
01-22-2023, 4:31pm | #27 | ||||||
I have my well water go through this first:
before going anywhere else (water heater, softener, pressure tank...). It gets quite nasty in a year. |
01-22-2023, 5:14pm | #28 | ||||||
I can't put down my copy of Yad and the Art of Water Heater Maintenance. Truly a metaphor for living life fully!
01-22-2023, 5:36pm | #29 | ||||||
01-22-2023, 5:44pm | #30 | ||||||
Barn Stall Owner #13
Gameroom Barn Bucks: $425244
More like 100-150 amps, some I’ve seen require 3 50A breakers.
The Following 3 Users Say Thank You to Black94lt1 For This Useful Post: |
01-22-2023, 5:48pm | #31 | ||||||
01-22-2023, 5:49pm | #32 | ||||||
01-22-2023, 6:06pm | #33 | |||||||
My Son In Law is looking at a “Heat Pump Water Heater”. Home Depot sells the and while they are comparable price to a gas tankless water heater, they really don’t require much at all electricity to run (claim less than a lightbulb - annually) https://www.energy.gov/energysaver/h...-water-heaters Rheem has been selling these since 2009 https://www.rheem.com/heatpumpwaterheater/ |
01-22-2023, 6:15pm | #34 | ||||||
Heat your water while cooling your garage.
01-22-2023, 6:46pm | #35 | ||||||
01-22-2023, 7:07pm | #36 | ||||||
You already have a geothermal well so add a circuit or zone and use that to heat your water. And move the new geothermal system to the garage where you can access it easily. Since you have a baller house and the last bathroom is 1/4 mile away, have the plumber run an insulated loop and circulation pump so hot water is near instant at all locations.
01-22-2023, 7:12pm | #37 | |||||||
The Following 2 Users Say Thank You to JRD77VET For This Useful Post: |
01-22-2023, 7:21pm | #38 | |||||||
The tankless nearest the bathroom is a thought but as I said running a wire is a challenge… I just got an estimate for a sidewalk vented propane heater, so yes you are correct, it is an option. |
01-22-2023, 9:31pm | #39 | ||||||
If you have hard water, you're going to have to flush your water heater regularly. Somebody above suggested the use of a good ball valve instead of the one that comes with the water heater.
Maybe that same person suggested a zinc anode instead of aluminum. I have two water heaters. One is in a low boy in the attic crawl space and it's a real pita to deal with. When the first one went out, it weighed around 300 lbs because it was full of hard water sediment because the previous owner had not solved the hard water issue. I built a gantry crane with a 4x8, some appropriately-sized joist hangers, a Harbor Freight electric winch and some galvanized pipes rigged as rollers. It's built into the rafters in order to get that 300-lb heater out and the new much-lighter one in. Due to limitations of height in the attic crawl-space, the gantry crane has an angle to it, so I used a come-along to control the tendency of the water heater to rapidly roll downhill on the crane. Not to mention to winch the new heater uphill to its platform. The water heater was attached to the winch's hook using a makeshift harness made out of tie-down straps. (FWIW he gantry crane, along with the electric winch, the come-along and the tie-down straps are still in place up there in the event they are ever needed again.) I think if I need to deal with it again, I'll put in a tankless on-demand heater up there. But at least I'll be able to get the old heater out without too much hassle. In addition to fixing the hard water issue, I did some other stuff: Installed a good drain valve --- somebody above called it a full-bore drain valve. I installed a powered anode instead of a zinc anode. The powered anode is powered by a low-voltage DC transformer (wall wart) using 120v AC which happens to be right near the electric water heater, wouldn't ya know? The powered anode is not sacrificial metal. Instead it gives up electrons that come from the power company so it in theory never wears out unless the wall wart power supply fails or God knows maybe some other possible failure mode. There are diagnostic lights on the top of the anode and there are test points on top of the anode so its condition can be assessed without removing it from the water heater. Regarding flushing the in-attic water heater: As you probably already know, an in-attic water heater gets installed with a drip pan that is plumbed to an outflow pipe that leads outside your house exterior wall somewhere nearby-ish. Because it was a royal hassle to drag a hose up there and attach it to a drain valve, then run it outside, I rigged up a fix. I put a T in the line from the drip pan to outside. One part leads to outside. another part leads from the pan to the T and the other part leads from the water heater drain valve to the T. So all I have to do is open the drain valve and the water flows to outside without running a hose or any other hassle. I put in a stop valve between the drip pan and the T so that the rush of water from the drain doesn't end up flooding the drip pan. That valve stays open most of the time. It is only closed when I drain the heater. It is immediately opened again when the draining process is complete. There is no stop valve between the heater's drain valve and the T because so far I have never seen water flow uphill. Arguably, instead of a stop valve I could have used a one-way backflow preventer, but I was concerned that a small amount of water coming from the drip pan might not be enough incentive for the backflow preventer to stay open. The risk of the stop valve is the possibility that one could forget to open it up again which, if left closed, could cause the drip pan to overflow in the attic instead of outside. If I was feeling extra lazy or extra spunky, depending on your point of view, I could have plumbed this stuff using electric valves from the heater to the T (leaving the heater's drain valve always open) and from the drip pan to the T that could be activated with the flick of a switch, but I was either a) too lazy to install such a thing or b) too chicken to rely on opening electric valves in my attic without personally inspecting the whole mess prior to each use. Mostly b. In any case, with very soft 0-grain hardness water, I don't find that I have to flush my water heater. And I'm very careful to open the drain pan valve after flushing. This is the best source I've ever seen for all things water heater related: https://www.waterheaterrescue.com They are the source for the power anode I used: https://www.waterheaterrescue.com/wa...hot-water.html If you're dealing with hard water, they also offer the right drain valve (though you can get one at any plumber or home-improvement store) and they also offer a curved dip tube that helps the water swirl at the bottom of the heater when you're draining it, thus helping to encourage the sediment to exit via the drain valve. I don't have one, but probably would if I had hard water. FWIW, I put a powered anode on my other water heater too, even though it's easy to get to, because sacrificial anodes only lasted a max of three years and I had to pay attention to them. Now I can just do occasional diagnostics. You may notice that some water heater models have guarantees twice as long as similar models. The difference is that the longer-guaranteed models have two anodes. If you can put in a powered anode, your water heater will last a very very long time. This setup has been going for about 13 years and so far no problems. |
The Following User Says Thank You to the new me For This Useful Post: |
01-22-2023, 9:45pm | #40 | ||||||
Gameroom Barn Bucks: $1008643
I went through this a couple years ago. Gas water heater but the deposits are real. Hard water sucks. Now I’ve got a water softener
