05-05-2024, 10:02pm | #301 | ||||||
IMO something like this just under the valence would look much better than the turned down pipes. Link
There are lots of similar options. . |
05-05-2024, 10:44pm | #302 | ||||||
Why did you fill in the exhaust exit in the valence if you're not installing side pipes?
05-05-2024, 11:12pm | #303 | ||||||
I'm good with asking for directions, but your answer doesn't obligate me to follow. I wouldn't have guessed you were the type to follow the dark blue line on Google Maps 100/100 times.
In a way, this side conversation is a metaphor for this thread. You are seeking the straightest line from point A to B. What appears to be the most direct path may not be the most satisfying. I'll go full dork on you and leave with this thought that popped in my head: The Road Not Taken BY ROBERT FROST Two roads diverged in a yellow wood, And sorry I could not travel both And be one traveler, long I stood And looked down one as far as I could To where it bent in the undergrowth; Then took the other, as just as fair, And having perhaps the better claim, Because it was grassy and wanted wear; Though as for that the passing there Had worn them really about the same, And both that morning equally lay In leaves no step had trodden black. Oh, I kept the first for another day! Yet knowing how way leads on to way, I doubted if I should ever come back. I shall be telling this with a sigh Somewhere ages and ages hence: Two roads diverged in a wood, and I— I took the one less traveled by, And that has made all the difference. Just cut the "U" out of the valence with a fine-toothed blade or cutting wheel, put the bezel in place and point the exhaust tips in the direction of the admirers of that fine looking '68 ass end...as they should. |
05-05-2024, 11:15pm | #304 | ||||||
Barn Stall Owner #102
Gameroom Barn Bucks: $23243
05-05-2024, 11:16pm | #305 | |||||||
05-05-2024, 11:20pm | #306 | |||||||
05-06-2024, 8:23pm | #307 | ||||||
When you need a break from wrench churning, your female crafty side kicks in.
Had every intention of tossing this compartment bin. Made of glorified cardboard (fiber board) and has a felt like coating that was dry rotted beyond repair. Had a wild idea to use matte decoupage to “refinish” and steamed and squared up the bottom and lip and filled some bad spots. |
The Following 11 Users Say Thank You to C3C7NIC For This Useful Post: |
05-06-2024, 8:25pm | #308 | ||||||
That turned out great! Do you cook and sew too?
The Following 6 Users Say Thank You to Steve_R For This Useful Post: |
05-06-2024, 8:30pm | #309 | |||||||
🤪, yea, me! I’m a map guru, one of the talents I’m proud of. Dad made sure I was a great shotgun and had me reading maps since I was 6 yrs old. He would plot out some great adventures for us and traveled the entire US and Nova Scotia on his motorcycle. I had to let him know how many more mile markers before our exit etc. Fun memories. Bet most people (young especially) have no idea how to read a map. If their navigation system goes out, they are screwed. Dad always made travel with road maps for every state I would be traveling through. Sage advice |
The Following 3 Users Say Thank You to C3C7NIC For This Useful Post: |
05-06-2024, 8:30pm | #310 | ||||||
Gameroom Barn Bucks: $894473
The Following User Says Thank You to Little Red L98. For This Useful Post: |
05-06-2024, 8:33pm | #311 | ||||||
As a matter of fact, I made a lovely dinner. Spaghetti, homemade garlic bread (crispy fresh garlic on top) and a 5 lettuce salad picked fresh from my garden.
If hubs is lucky he’ll get a happy ending tin his massage later. Ok, all of the above is true, except for the happy ending. |
The Following 6 Users Say Thank You to C3C7NIC For This Useful Post: |
05-06-2024, 8:34pm | #312 | ||||||
The Following 4 Users Say Thank You to C3C7NIC For This Useful Post: |
05-06-2024, 8:39pm | #313 | ||||||
The Following 2 Users Say Thank You to Steve_R For This Useful Post: |
05-06-2024, 9:16pm | #314 | |||||||
05-06-2024, 9:50pm | #315 | ||||||
The Following 5 Users Say Thank You to Steve_R For This Useful Post: |
05-06-2024, 9:51pm | #316 | ||||||||
FWIW, I finished graduate school with a 4.0. Quote:
Pipe down, grandpa. |
05-06-2024, 11:16pm | #317 | ||||||
Buy the period correct bezels, cut the semi circles and install the correct tips. It's easy, cheap and will look best. You won't regret it.
05-07-2024, 2:13pm | #318 | |||||||
I wish it were that simple. There has to be fiberglass work to fabricate the lip to attach the bezel on both the quarter panel and the rear filler panel then that all has to be painted. Won’t be an easy or Inexpensive fix, unfortunately. |
05-07-2024, 5:47pm | #319 | ||||||
05-07-2024, 9:51pm | #320 | ||||||
Got the passenger rear bumper on. Dear Lord! 4 hours! Ended up having to grind down part of the bracket corner. It was not fitting into the fiberglass so had to make modifications.
Where has AndE been? This is usually where he shows up and starts taking about facials and monkfish. |
The Following 5 Users Say Thank You to C3C7NIC For This Useful Post: |
