09-13-2022, 11:03am | #221 | |||||||
Gameroom Barn Bucks: $1014987
09-13-2022, 11:27am | #222 | ||||||
Run your hand over the painted surfaces... Isn't hard to feel the difference between fresh paint and buffed out paint. Pictures will not pick it up well unless lighting is just right.
09-13-2022, 11:28am | #223 | |||||||
Dogface
Barn Stall Owner #409 Bantayan Kids '13,'15,'17
Gameroom Barn Bucks: $2450928
The Following User Says Thank You to dwjz06 For This Useful Post: |
09-13-2022, 11:42am | #224 | |||||||
Barn Stall Owner #102
Gameroom Barn Bucks: $23243
Also looked through diagrams on paragon/Wilcox/and all the regular sellers. Coming into this 1/2 way done with stuff pulled off I already had paid to have installed here is a fuggin nightmare. I had everything bagged and tagged that we removed. Well of course none of that is here anymore. Like all my front shocks are gone. He replaced my BRAND NEW shocks with ride tech (which I’ve been told are great) but I was fine with the brand new suspension I had. Now I have only the back installed and nothing is tightened up. I don’t even know what is missing. Like this picture of the passenger front shock area. Like WTH all is missing here? |
09-13-2022, 11:48am | #225 | |||||||
Dogface
09-13-2022, 12:02pm | #226 | |||||||
Gameroom Barn Bucks: $311064
The Following 2 Users Say Thank You to RMVette For This Useful Post: |
09-13-2022, 12:49pm | #227 | ||||||
I get it, but AIM pics don’t help keep all that much.
It would be like me handing you a Netters anatomy book and a few surgical tools and telling you to do an appendectomy. You all are good at this stuff but I’m a moron with very little knowledge. Here are some videos, the best I could get with the car not on stands… From the front: From the middle looking forward to front suspension. While I was under there, took a video of the rear suspension area. I see shocks but not sure what all might be missing. Nothing is tightened down, why crap came apart on our way home. |
The Following 2 Users Say Thank You to C3C7NIC For This Useful Post: |
09-13-2022, 12:55pm | #228 | ||||||
The only thing missing on the bottom of the front shock mount you posted the pic of is a shock.
09-13-2022, 1:16pm | #229 | ||||||
I see alot of upgraded good parts with new fasteners on alot.
Tubular lower A arm a big upgrade on these. I saw new brake lines (flexible at least). Besides missing frt shocks bottom end looks pretty complete to me. |
09-13-2022, 1:18pm | #230 | |||||||
They keep finding parts so hopefully they will mail them soon. There are gonna be a shit ton of parts to mail. |
09-13-2022, 1:25pm | #231 | ||||||
09-13-2022, 2:30pm | #232 | ||||||
I couldn't see brake calipers on the front?
The exhaust appears to be hanging in the air? Do you have the braces or straps, etc...to attach to frame? Any painted panel that is flat white in appearance has been sanded. Next step is to buff with compound and buffing pad. The process for color sanding. First you sand to eliminate orange peel and trash if possible. Look at the door jambs. See how the paint looks like the peel of an orange or moon surface? All bumpy looking. Sanding takes it down flat. Just like making a mirror. You take it down perfectly flat. Then you polish that for a mirror finish with compounds and pads on a buffing machine. There is no harm in buffing the paint on the car if the guy wants to do it that way. It's just his preference. Maybe he will put it on a lift to get good access to the lower parts. Maybe it's his workflow, etc..just examine SEVERAL cars that he has done and whoever you hire to do the job. Look at some of their work. The glossy line on the rear qtr. may have come from someone or something scratching it. I think it will be fine. But, it was probably sanded and then something scratched it. Buffing should fix it. You should do something with anything that is bare metal. I noticed steel washers, etc...with surface rust already on them. Clean it with a brush and hit it with a little clear coat from a can or wax or something. You can't leave bare metal exposed. |
09-13-2022, 2:31pm | #233 | |||||||
So I have one shock, based on schematic, is hardware on the car? I guess I’m Not seeing how it attaches on the lower end. |
09-13-2022, 2:34pm | #234 | |||||||
I assume you are referencing the rusted parts on the suspension. Yes, I noticed that. What kind of wax should I use? I’m a little nervous to use any spray as I’m not sure I’ll be able to control overspray. |
09-13-2022, 2:41pm | #235 | ||||||
See on your diagram where it says "Bolt set" by the bottom of the shock? There are two bolts that hold the bottom in place. The shock gets fed up through the large hole in the bottom and then bolted in place with two bolts in the threaded holes. The only hardware required is those two bolts.
09-13-2022, 2:47pm | #236 | |||||||
09-13-2022, 2:52pm | #237 | |||||||
09-13-2022, 2:58pm | #238 | ||||||
I would also say anything with a cotter pin has been torqued to spec. Any suspension/chassis fastners without a cotter pin should be torqued with car sitting on
it's wheels on the ground. |
09-13-2022, 3:05pm | #239 | |||||||
So you were absolutely right. We will have everything looked over to make sure everything is tight when we get to that point. |
09-13-2022, 3:07pm | #240 | ||||||
Maybe he doesn't want to fool with aligning and shimming the panels to make them fit. You need to ask him if he is going to do the panel alignment/shimming or someone else?
