Other Car/Truck Brands Non-Corvette Content, Daily Drivers, Winter Beaters, Work Trucks, Tow Vehicles |
04-19-2010, 7:05am | #1 | ||||||
Gameroom Barn Bucks: $1005893
FS: Miscellaneous 1st Gen Chevy Parts
Here is a copy of the Miscellaneous Chevy Parts I have for sale. The price to the right is my selling price shipping. The (*) means that the part has been
sandblasted and primed.. If you have any questions contact me. I have a simple policy. If you do not like what you buy, once I receive it back in the same condition I sent it, you get your money back. You can check out my Website as well....I have been around a while 2000 MILLENIUM YELLOW Corvette,1996 Impala SS, 1972 El Camino, 1968 Camaro & Car Parts. Miscellaneous 1st Gen Chevy Parts Mechanical parts 14" dia. Open Element Air Cleaner 6.00 50.00 ea. (4) 14" x 7" Rally Wheels (B/DOT made in Canada 1991 M5/2 DO) H Stamped in Spoke M5/2 (valve stem stamp) 8AJ, 1395 lbs. max - 35 psi, 14 x 6.00 R1--'82 - '91 S-10 Rims 30.00 ea 40.00 ea (4) Trim Rings 10.00 ea (2) Black Center Caps 15.00 ea 327 CID Small Block (#3782870) 2-Bolt Main Crankshaft GM151 #3782680, forged, small journal ,3.25” stroke 1962 $150.00 Intake, 2 BBL Stock Cast Iron P/N 3918318GMT4, Cast #L2909 30.00 DS Cast #0210, GM8, 0J390 Heads, 376445 100.00 pr PS Cast #0210, GM26, 011480 A & C18, Cast #376445 Intake 1.72" Exhaust 1.50"(hardened seats) Carb, 2 BBL 70401361873DF1 30.00 Flexplate (2) Small Block, (1) 400 CID 168 Teeth 30.00 ea. 8 Pistons and Rods 100.00 Harmonic Balancer Cast #3896988A6, 2225 on Front & L4F 50.00 DS Exhaust, Exit Out Rear 50.00 Water Pump GM 6263701 Cast # 80B240 10.00 Oil Pan 35.00 Small Block Stock Valve Covers Chevy Orange $20.00 Distributor 11120029H14 25.00 Timing Chain Cover 7.00 Coil 10.00 Oil Pump w/ Rod 10.00 Starter w/o Solenoid #1107367 6B7 BADS 25.00 Carb. Linkage for Gas Pedal w/Brkt 25.00 Edelbrock Street Master Q-Jet Alum. Intake Single Plane, 100.00 Cast #3225 Oil Dipstick, Upper & Lower Tube 10.00 Choke Kit Assembly 10.00 Exhaust Manifold #364753LH5 D.S. 76-81 350 Cast. J10E $50.00 Exhaust Manifold #3942529 LH D.S. '69 Camaro w/ Small Crack 307-350 cid Cast. 013 ,CON7 $50.00 9" Open Element Air Cleaner $10.00 Chrome Turbo 350 Trans. Tube & Stick $8.00 '66 Nova Carter AVS 4 BBL #4027S $40.00 Trim Rings (6) 15", (3) 14" $10 - $20.00 ea. *Misc. Wire Loom Brackets $5.00 ea. Dome Lamp Bulbs (2) $1.50 ea. Dist. Hold Down Clamps (2) $3.00 ea. *Dist. Coil Brackets (2) $15.00 ea. INTERIOR PARTS LH/RH '71 - '81 Tan Camaro High Back Bucket Seats (gd. cond.) 100.00 ea Electrical parts 1963 Electric Westclox Clock Assembly $65.00 EXTERIOR CHROME LH/RH 68-69 El Camino ¼ panel emblems. 10.00 ea. |
