Meatloaf..
So what's the secret to a good meatloaf?
Any hints? |
Mom.
I like to use bacon grease, oats, and a package of dry lipton onion soup mix.
:yesnod: |
I like it when you take a slice of meatloaf, cooked, then grill it so the outside gets nice and crispy! |
....left over meatloaf sandwiches....Mmmmmm!
And remember, never let your meat loaf.....:lol: |
Ranch Meat Loaf 1-1/2 cups soft bread crumbs 3/4 cup milk 2 lbs. ground beef 1 medium carrot, peeled and grated 1 small onion, minced 2 eggs, beaten 1/4 c ketchup 3 tablespoons brown sugar 2 tablespoons prepared mustard Heat oven to 325 degrees Put bread crumbs in a large bowl and pour the milk over them. Stir in ground beef, grated carrot, onion, and beaten eggs. Mix thoroughly. Shape the mixture to make an oval loaf. The less you handle the mixture, the juicer it will be. Place in shallow baking pan. Mix ketchup, brown sugar and mustard and spread it over the top of the loaf. Bake for 1-1/2 hours. Yum! |
This is my meatloaf. I cooked it for friends last weekend. It's good.......:D
Meatloaf Serves 8 to 10. * 4 slices white bread, torn into pieces * 2 1/4 pounds ground beef 80% makes a juicer loaf * 1 medium yellow onion, peeled and cut into eighths * 2 cloves garlic * 3 stalks celery, cut into 2-inch pieces * 1 large egg * 1/2 cup ketchup * 2 tablespoons Worcestershire sauce * 2 teaspoons dry mustard * 1 tablespoon coarse salt * 2 teaspoons freshly ground black pepper * 12 rectangles of Velveta cheese Topping * 2 tablespoons brown sugar * 1 teaspoon dry mustard * 1/2 cup ketchup Directions 1. Heat oven to 375 degrees. Place bread in the bowl of a food processor fitted with the steel blade; pulse until fine crumbs form. Transfer to a medium bowl, and add ground beef. 2. Place onion, garlic, and celery, in the bowl of a food processor fitted with the steel blade; pulse until fine. Add to meat mixture, using hands to mix well. Add egg, 1/2 cup ketchup, Worcestershire sauce, 2 teaspoons dry mustard, salt, and pepper; use hands to combine thoroughly. 3. Line a large cookie sheet (with sides) with aluminum foil. Form a long oval with 3/4 of the mixture (@ 5" x 10"). Push chunks of the velveta into the loaf, and cover with the remaining meat mixture. 4. Combine 1/2 cup ketchup, 1 teaspoon dry mustard, and 2 Tbls. brown sugar in a bowl; stir until smooth. 5. Spoon mixture over meatloaf; place in the oven. Cook until a meat thermometer inserted in the center reads 160 degrees, about 90 minutes. If top gets too dark, cover with foil, and continue baking. |
Did anyone else's Mom used to put a hard-boiled egg in the middle of the meat loaf?
I do my meatloafs a little differently. I turn the loaf out onto parchment before baking - it's not as greasy (my wife does need to watch that sort of thing for health reasons). It's just as juicy and tasty.
Well here's another thing me and the wife seem to notice. Most recipes feed an army. We only need enough for us and a little for the baby, and mabye some left over for the next day to take to work for lunch.
It's meatloaf, put whatever you have in the cabinate in there :leaving:
I do remember Alton Brown using beef/pork/lamb mixture. I tried beef pork/once, not too bad. |
Good Eats Meatloaf Recipe : Alton Brown : Food Network |
I made an italian meatloaf out of a marlboro cookbook that was real good. I'll have to find that.
That's the nice thing about meat loaf. You can let your imagination run wild to incorporate any country's seasonings. If you want it less greasy for health reasons use extra lean or lean and increase the moisture with stock or whatever, and, sear the bottom on a skillet first and use a rack inside your baking pan to keep it up off the bottom....no grease.:cheers:
