power steering pump pulley
Anyone removed the power steering pump pulley ? If so what type puller did you use?
Jeff |
Thanks for the offer Thegreenman, but I need some more tax deductions.
I am buying new tools to be able to tinker, I rather do stuff myself.
MATCO tools has a really nice install/removal set for around $100.
I got mine at Handsontools.com, another source to check.
Advance Auto has one, BUT it's really cheap. I tried one and it one worked one time, after that the threads where screwed up.
Since I had mine out, and on the bench, I took a hammer and smashed the plastic pulley off it's hub. Didn't take long to make it 2 pieces. :D From there, any appropriately-sized 2 or 3 jaw puller will remove the hub from the PS shaft. http://img25.imageshack.us/img25/2439/pspulley.jpg I used the Advance tool to draw the new (aluminum) pulley on the PS pump shaft, but still had to heat the pulley to get it to go, as I would have broken the tool otherwise. (Synister PS pulley - it was a VERY tight fit). http://img25.imageshack.us/img25/7316/newpsbracket.jpg :cheers: |
